austin joe 11 #1 Posted February 27, 2019 I have a C-160 that starts and runs anywhere from 20 to 60 minutes then dies and shows no spark. After sitting for 20 minutes will start and run again the mechanic thinks it is the ignition coil. I have always thought they either work or don't and are not intermittent. Any ideas on this or where to find a replacement coil? Share this post Link to post Share on other sites
pfrederi 20,669 #2 Posted February 27, 2019 11 minutes ago, austin joe said: I have a C-160 that starts and runs anywhere from 20 to 60 minutes then dies and shows no spark. After sitting for 20 minutes will start and run again the mechanic thinks it is the ignition coil. I have always thought they either work or don't and are not intermittent. Any ideas on this or where to find a replacement coil? See also my response to your other post Heat can affect coils and the stator windings that power the coil. There are some diagnostics you can run try them hot and cold see page 45-46 The basic test is unfortunately replace with known good coil and see if the problem resolves. https://www.wheelhorseforum.com/search/?q=cast&type=downloads_file&nodes=15 2 Share this post Link to post Share on other sites
austin joe 11 #3 Posted February 27, 2019 Thank you on your other post you mentioned someone who makes these for less is there a way to contact them? Share this post Link to post Share on other sites
pfrederi 20,669 #4 Posted February 27, 2019 2 minutes ago, austin joe said: Thank you on your other post you mentioned someone who makes these for less is there a way to contact them? Came up on an ebay search for your part # Share this post Link to post Share on other sites
wildman 205 #5 Posted February 27, 2019 Sent you a PM with info on coil 2 Share this post Link to post Share on other sites
pfrederi 20,669 #6 Posted February 27, 2019 7 minutes ago, wildman said: Sent you a PM with info on coil Have you used one of his devices. i am interested in getting one as I have two techies that use them and it is only a matter of time before I need one. Share this post Link to post Share on other sites
daveoman1966 3,883 #7 Posted February 27, 2019 (edited) This comment deleted...my bad. Edited February 27, 2019 by daveoman1966 my bad Share this post Link to post Share on other sites
pfrederi 20,669 #8 Posted February 27, 2019 6 minutes ago, daveoman1966 said: Is there a condensor next to the coil... Old condensors break down after years and years...spend $6 bux for a news one. Of course, could be the coil. I ahve a good used one if wanted...$25. Dave there is no condenser this is the infamous Tecumseh Solid state ignition system if you have a working used one it is worth a lot more than $25 Share this post Link to post Share on other sites
daveoman1966 3,883 #9 Posted February 27, 2019 17 minutes ago, pfrederi said: Dave there is no condenser this is the infamous Tecumseh Solid state ignition system if you have a working used one it is worth a lot more than $25 MY BAD.... I was thinking a coil for a Kohler.... I'll delete my reply. Share this post Link to post Share on other sites
wildman 205 #10 Posted February 27, 2019 45 minutes ago, pfrederi said: Have you used one of his devices. i am interested in getting one as I have two techies that use them and it is only a matter of time before I need one. I have not but says he uses automotive components that are available Share this post Link to post Share on other sites
wildman 205 #11 Posted February 27, 2019 If i needed one i wouldn't be afraid to try one of them from overnight solutions. Share this post Link to post Share on other sites
austin joe 11 #12 Posted February 27, 2019 I contacted overnight and they are sending the instructions to see if it will work. I will post the results. Thanks to all who have responded. Share this post Link to post Share on other sites
roadapples 6,987 #13 Posted February 27, 2019 (edited) Log on to. brokndwn64@gmail.com Or call Mike Brooks 585-243-7765 @pfrederi Edited February 27, 2019 by roadapples 1 Share this post Link to post Share on other sites
seven 202 #14 Posted March 1, 2019 Check your battery and clean the points first Share this post Link to post Share on other sites
chip61 666 #15 Posted March 2, 2019 I have one of the kits from Overnight on my HH120-easy to install and works well. I used a toggle switch for battery power instead of getting a new ignition switch Share this post Link to post Share on other sites
austin joe 11 #16 Posted March 2, 2019 First I would like to thank everyone for the advice and suggestions. After talking to Overnight Solutions and Jacks Small Engine Repair it seems the ignition coil on this "lasts forever". Their suggestion it was in the ignition switch or wiring. So we put a new switch in and replaced any connection plugs and wrapped wires in electrical tape and made sure no wires were touching the engine. This is a working tractor I use to move feed, fence panels and manure with on a ten acre small farm. I went out today and did all of that and drove about 1-1.5 hours and ran perfectly. Previously it would run 15 minutes at most. So long story short success I would not have been able to get this done without this forum. I would not hesitate to use Overnight for a replacement or Jack's for a used one if needed both are very knowledgeable . Below is a picture of the old girl after a workout I taped the wires afterward just for insurance. 1 Share this post Link to post Share on other sites
