lynnmor 8,076 #26 Posted December 29, 2022 7 hours ago, MIKES695 said: I would like to purchase some if you have them available quim1217@yahoo.com PM sent. Share this post Link to post Share on other sites
peter lena 9,452 #27 Posted December 29, 2022 @lynnmor, congratulations on making up vital replacement part ! hope all those interested members also go over related possible service areas , pete Share this post Link to post Share on other sites
don mcc 0 #28 Posted August 24, 2023 I am looking for snow blower Chute retainer #25-5450..3 total..thanks Share this post Link to post Share on other sites
lynnmor 8,076 #29 Posted August 24, 2023 2 hours ago, don mcc said: I am looking for snow blower Chute retainer #25-5450..3 total..thanks I have none in stock right now, I will be producing some in a few weeks. PM me with your information and I will contact you when guides are available. @don mcc Share this post Link to post Share on other sites
don mcc 0 #30 Posted August 26, 2023 On 8/24/2023 at 6:05 PM, lynnmor said: I have none in stock right now, I will be producing some in a few weeks. PM me with your information and I will contact you when guides are available. @don mcc Share this post Link to post Share on other sites
BEEJ 0 #31 Posted October 20, 2023 Any more available? I"m in need of a set also. Share this post Link to post Share on other sites
lynnmor 8,076 #32 Posted October 20, 2023 31 minutes ago, TinkerWiddit said: Any more available? I"m in need of a set also. PM sent. Share this post Link to post Share on other sites
WHorsey91 0 #33 Posted November 26, 2023 @lynnmor Do you have any more? I would like a set. Share this post Link to post Share on other sites
lynnmor 8,076 #34 Posted November 27, 2023 19 hours ago, WHorsey91 said: @lynnmor Do you have any more? I would like a set. PM sent. Share this post Link to post Share on other sites
Jason Hunt 3 #35 Posted December 4, 2023 @lynnmor I have a question regarding these. Do they help the chute stay centered so as the gear notches on the chute stay engaged with the gear that turns the chute? Share this post Link to post Share on other sites
lynnmor 8,076 #36 Posted December 4, 2023 25 minutes ago, Jason Hunt said: @lynnmor I have a question regarding these. Do they help the chute stay centered so as the gear notches on the chute stay engaged with the gear that turns the chute? If your old ones are severely worn or cracked, then gear engagement would be improved with new ones. My guides have a bit more surface to center the chute. You might be able to adjust the amount of clearance for the gears by moving the worm bracket #6. Share this post Link to post Share on other sites
Jason Hunt 3 #37 Posted December 5, 2023 I actually moved the worm gear as close as possible and shimmed the right side of bracket #6 and it works so far. Just dont know how it will hold up when the white stuff starts flying. I appreciate your response and will keep your product in mind and may oder some in the future if you have em on hand. Again, thank you for your time and input. Greatly appreciate it! 1 Share this post Link to post Share on other sites
ebinmaine 74,528 #38 Posted January 1, 2024 @lynnmor I'd take a set of these when you can. Share this post Link to post Share on other sites
lynnmor 8,076 #39 Posted January 1, 2024 4 minutes ago, ebinmaine said: @lynnmor I'd take a set of these when you can. PM sent. 1 Share this post Link to post Share on other sites
ebinmaine 74,528 #40 Posted February 3 @OldWorkHorse 1 Share this post Link to post Share on other sites
OldWorkHorse 3,096 #41 Posted February 3 (edited) Thanks for the tag @ebinmaine! Hello @lynnmor I was looking to see if you had any sets of the tall chute snowblower guides mine are seeming a bit worn! Thank you. Edited February 4 by OldWorkHorse 1 Share this post Link to post Share on other sites
lynnmor 8,076 #42 Posted February 3 4 hours ago, OldWorkHorse said: Thanks for the tag @ebinmaine! Hello @lynnmor I was looking to see if you had any sets of the tall shoot snowblower guides mine are seeming a bit worn! Thank you. I sent you a PM. Be aware that the guides have plenty of clearance from new, I make them with the same clearance. 1 Share this post Link to post Share on other sites
OldWorkHorse 3,096 #43 Posted February 4 2 hours ago, lynnmor said: I sent you a PM. Be aware that the guides have plenty of clearance from new, I make them with the same clearance. That's fine worse case I have a spare set. Mine have sum pretty good groves cut into them from wear and allow the chute to move around to point gears won't engage. 2 Share this post Link to post Share on other sites
Plantman 7 #44 Posted yesterday at 05:43 PM Hello, I just broke one of these, do you have a set available? Thanks, Rob Share this post Link to post Share on other sites
lynnmor 8,076 #45 Posted 22 hours ago 7 hours ago, Plantman said: Hello, I just broke one of these, do you have a set available? Thanks, Rob I have none in stock right now, I expect to make a batch in a few weeks. 1 Share this post Link to post Share on other sites
Plantman 7 #46 Posted 13 hours ago 8 hours ago, lynnmor said: I have none in stock right now, I expect to make a batch in a few weeks. Thanks for the reply, let me know when you have them back in stock. Share this post Link to post Share on other sites
AHS 1,559 #47 Posted 11 hours ago @lynnmor ill take two sets, when you get em back in stock, please. Share this post Link to post Share on other sites
