Larry Chamberlain 29 #1 Posted January 23, 2019 Ok just put my new fuel pump on and it fired right up now the muffler is red and it shoots out sparks any clue what's going on I'm thinking the mixture isnt right I only had running for a couple minutes enough for the smoke to clear it's a fresh rebuild 10 over Share this post Link to post Share on other sites
ebinmaine 80,783 #2 Posted January 23, 2019 If the muffler is red it's likely too lean Share this post Link to post Share on other sites
Larry Chamberlain 29 #3 Posted January 23, 2019 Now what screw do I adjust this with or should I just take it to a small engine guy and have him do it Share this post Link to post Share on other sites
ebinmaine 80,783 #4 Posted January 23, 2019 You can do it yourself if you take a look at the Kohler manual or search here on the site for the directions. I think I'd start with Both screws about 1.5 turns out but I don't know for sure on your engine. Share this post Link to post Share on other sites
Larry Chamberlain 29 #5 Posted January 23, 2019 Ok I'll look it up tonight and try to get it tuned tomarrow after work thanks 1 Share this post Link to post Share on other sites
Howie 900 #6 Posted January 23, 2019 Initial settings on that carb is, 2 1/2 turns out on idle screw and 2 turns out on the high speed screw. High speed screw on top of carb, idle screw on side at an angle. Check point setting also. 3 Share this post Link to post Share on other sites
Mikey the Monkey 701 #7 Posted January 23, 2019 1 4 Share this post Link to post Share on other sites
953 nut 69,592 #8 Posted January 23, 2019 @Mikey the Monkey has provided the proper information on carb settings. If your engine has a battery ignition system with points they may also need attention, the points setting will also set your ignition timing. If tuning the carb does not clear the problem up let us know and we will fill you in on the points procedure. 2 Share this post Link to post Share on other sites
ebinmaine 80,783 #9 Posted January 23, 2019 1 minute ago, 953 nut said: will fill you in on the points procedure. Richard, if you have that handy I'd like to see it. 1967 Kohler 8 and a 1974 Kohler 16 1 Share this post Link to post Share on other sites
953 nut 69,592 #10 Posted January 23, 2019 16 minutes ago, ebinmaine said: Richard, if you have that handy I'd like to see it. 1967 Kohler 8 and a 1974 Kohler 16 No problem! Kohler static_timing.pdf 1 1 Share this post Link to post Share on other sites
ebinmaine 80,783 #11 Posted January 23, 2019 @953 nut Thank you sir!! 1 Share this post Link to post Share on other sites
pacer 3,180 #12 Posted January 23, 2019 Should also be pointed out that its not that unusual at higher rpms for the exhaust pipe to glow red at/near the outlet --- and occasionally to spit sparks out. Would imagine you guys using your snow plows/throwers at night running at high throttle can attest to that. 1 Share this post Link to post Share on other sites
rjg854 13,386 #13 Posted January 23, 2019 Funny that you mention that, I just happened to notice my stack glowing red this morning before sunrise. Share this post Link to post Share on other sites
Larry Chamberlain 29 #14 Posted January 24, 2019 I believe I cleared it up did the 2 1/2 to 2 and seems to be running pretty good it has a very dim glow in the exhaust once in a while will see a blue burst in the pepper can runs very smooth no missing at all Share this post Link to post Share on other sites
Larry Chamberlain 29 #15 Posted January 24, 2019 Thanks all Share this post Link to post Share on other sites
