Solze1267
D250 restoration
Solze1267
Well a little late to post this (actually months late but hey life happens) but I purchased this D250 which runs rough and is stuck in low range but still moves. Over the next few months myself along with my father are going to tear this beast down and completely rebuild this back to its former glory. I also have the original mower deck to go along with it. If anyone has any incite on these tractors feel free to comment. I will post pictures along the way.
  • Like 6
Terry M
I have always liked the looks of this model Wheel Horse:).....Looking forward to following the restore!
ebinmaine
I know very little about the bigger hosses but I'll be here watching.
Good luck!!
Super-C 4 me
Hey Don,
Brian from Mass. You grabbed a headlight and cables from me.
I'm guessing that's you.
I'll be following this thread also.
Good luck, Give me a holler if you need anything.
B
Solze1267
@bmiller0457 yep its me. Luckily i believe i still have your number if i need to pick your brain. Glad you can be along for the ride
Solze1267
Ok so a little update on the restoration. Due to overtime at work and some unforeseen family emergencies I haven’t been able to do much on the tractor. BUT I was able to finally meet up with @bmiller0457 and snag this snow blower and parts tractor off of him. I am also working with my paint supplier on a color match for the tractor since under the seat pans on both tractors is not faded out at all. I will post a formula for it once we have it. Progress will be slow but continued until overtime slows down at work then watch out!
Edited by Solze1267
  • Excellent 2
Super-C 4 me
It was nice to finally meet you @Solze1267 , Good Luck with the rest of your project.
Let me know if there is anything else I can help with.
Solze1267
Well more pieces are rolling in. For some reason I always get some of the finishing pieces first...always have doesn’t matter what it is. Got my decals in today from Redoyourhorse and they look great. Now to get to the point of being ready to put them on.3370E29C-74DF-4422-B605-D7CC646EA606.png.48bb9de83bf81010e4326657566b78f2.png
  • Excellent 2
Solze1267
Finally the D250 is back in the shop to get worked on and is joined by it's little brother rj58 who goes perfectly up on the work bench... Slow and steady wins the race
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • ccs002
      By ccs002
      Looking for a complete hydro pump for a D-160. Tractor is missing everything from the rubber coupler disc back. Also willing to buy a complete tractor for parts, the closer to Harrisonburg VA the better. Thank you.
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
