trailhopper 50 #1 Posted January 18, 2019 So I recently picked up a 1991 520H and was looking forward to having full instrumentation, but the tachometer was non-functioning. After some troubleshooting (using this site), it appears as the actual tachometer is burnt up. After this discovery, I searched for a replacement and found this place selling new Toro tachometers (part #78-006) for a reasonable price. I haven't hooked mine up yet, but did receive it and looks perfect, Not my site, not my product. Just thought that I would share. https://www.marine-surplus.com/product/teleflex-marine-toro-0-4000-rpm-tachometer-gauge-78-0060/ -Scott 4 1 3 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #2 Posted January 19, 2019 That does seem to be a great price and thanks for sharing the link, Jeff. 2 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #3 Posted January 19, 2019 21 minutes ago, trailhopper said: So I recently picked up a 1991 520H and was looking forward to having full instrumentation, but the tachometer was non-functioning. After some troubleshooting (using this site), it appears as the actual tachometer is burnt up. After this discovery, I searched for a replacement and found this place selling new Toro tachometers (part #78-006) for a reasonable price. I haven't hooked mine up yet, but did receive it and looks perfect, Not my site, not my product. Just thought that I would share. https://www.marine-surplus.com/product/teleflex-marine-toro-0-4000-rpm-tachometer-gauge-78-0060/ -Scott I might have a tack if you need one PM me . 1 1 Share this post Link to post Share on other sites
trailhopper 50 #4 Posted January 19, 2019 (edited) 25 minutes ago, The Tool Crib said: I might have a tack if you need one PM me . Thanks for the offer, but I actually bought 2 through the link. They look new and in perfect shape. I just need to get one hooked up now... Edited January 19, 2019 by trailhopper spelling 3 1 Share this post Link to post Share on other sites
Shuboxlover 490 #5 Posted January 19, 2019 PLEASE let us know if they are compatible...That's a FANTASTIC price!!! GREAT FIND!!!!!!!!!!!!!!! 1 Share this post Link to post Share on other sites
oliver2-44 11,662 #6 Posted January 19, 2019 Forget me if I'm stealing this thread, but I've wanted a tach for my c-160. Can any of the 520 guru's tell me how that toro Tach gets it signal and could it be retrofit to a K341? 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #7 Posted January 19, 2019 38 minutes ago, oliver2-44 said: Forget me if I'm stealing this thread, but I've wanted a tach for my c-160. Can any of the 520 guru's tell me how that toro Tach gets it signal and could it be retrofit to a K341? I'm not a guru by any means but I believe it gets its signal from the voltage regulator because when the VR is bad the tach does not work also on the Onan the coil fires both cylinders simutaniously, maybe Kyle @fast88pu or @cleat could cast some light on the subject. 1 Share this post Link to post Share on other sites
cleat 9,093 #8 Posted January 19, 2019 Tach gets it's signal from the AC from the charge coil. I had a Wheel Horse tach in my Ford LGT165 with a Kohler K341 and it worked perfectly. Cleat 2 1 Share this post Link to post Share on other sites
cleat 9,093 #9 Posted January 19, 2019 3 hours ago, trailhopper said: So I recently picked up a 1991 520H and was looking forward to having full instrumentation, but the tachometer was non-functioning. After some troubleshooting (using this site), it appears as the actual tachometer is burnt up. After this discovery, I searched for a replacement and found this place selling new Toro tachometers (part #78-006) for a reasonable price. I haven't hooked mine up yet, but did receive it and looks perfect, Not my site, not my product. Just thought that I would share. https://www.marine-surplus.com/product/teleflex-marine-toro-0-4000-rpm-tachometer-gauge-78-0060/ -Scott Holy, Used ones go for more, that seems like a price too good to be true. 2 Share this post Link to post Share on other sites
trailhopper 50 #10 Posted January 19, 2019 9 hours ago, cleat said: Holy, Used ones go for more, that seems like a price too good to be true. I thought so too. That's why I waited until I had them in hand to post. Now I just need the time to get one installed. Share this post Link to post Share on other sites
fast88pu 3,394 #11 Posted January 19, 2019 10 hours ago, WVHillbilly520H said: I'm not a guru by any means but I believe it gets its signal from the voltage regulator because when the VR is bad the tach does not work also on the Onan the coil fires both cylinders simutaniously, maybe Kyle @fast88pu or @cleat could cast some light on the subject. Yes the 520 does from the regulator. If it was a magnum single you can get it from the kill wire buy on an old K series I'm not sure. I would ask in the pulling section. I run a tach on my predator and tiny tachs on the rest. Share this post Link to post Share on other sites
cleat 9,093 #12 Posted January 19, 2019 Just connect to one of the AC lines coming from the charge coil to the regulator. If one does not work, try the other one. Mine worked perfectly but there may be charge coils with different number of windings that could cause tach to read differently. Cleat Share this post Link to post Share on other sites
bds1984 1,516 #13 Posted February 1, 2019 I have a tachometer on my C165 that is connected to one of the AC terminals on the regulator and it works fine. I believe the issue is the flywheel has to have six magnets on it for the tachometer to read correctly. I am going to buy a tachometer and install it on my 315-8. Thanks for the link! Share this post Link to post Share on other sites
formariz 12,381 #14 Posted February 13, 2019 @trailhopperCurious as to how gauge worked out. Share this post Link to post Share on other sites
hihousej 0 #15 Posted July 15, 2020 I bought the gauge from Marine-Surplus and it works perfectly in my 520H. Had to run a small drum sander in the dash hole for a half a minute to wallow it out a tad. Wiring was there and it went slick and looks great. This one hasn't had a tach since the turn of the century. Share this post Link to post Share on other sites
International Harvester 1 #16 Posted September 18, 2020 Got mine today! They can be found here: https://www.marine-surplus.com/product/teleflex-marine-toro-0-4000-rpm-tachometer-gauge-78-0060/ Only $50.00 bucks. 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #17 Posted September 18, 2020 (edited) Just phishing people. Reported to the moderators. Edited September 18, 2020 by AMC RULES Share this post Link to post Share on other sites
WHX?? 57,644 #18 Posted September 21, 2020 Me thinks @International Harvester works at Marine Surplus and is trying to move some inventory? Share this post Link to post Share on other sites
AMC RULES 37,259 #19 Posted September 21, 2020 Here's thinking they haven't read our forum rules. https://www.wheelhorseforum.com/guidelines/ Share this post Link to post Share on other sites
