JCM 11,253 #1 Posted January 2, 2019 (edited) Do any of you RS members have any experience with cover-it/shelter logic type portable garages for storing WH products,and what are the pros/cons on these types of stuctures. My yard has a lot of clay [poor drainage], what type of base would you recommend. Thank you for your input. Also would a quonset style be better than a garage style to shed snow Edited January 2, 2019 by JCM Share this post Link to post Share on other sites
953 nut 67,328 #2 Posted January 2, 2019 I don't have one of those, but to prevent rust and moisture problems you will want to put down a vapor barrier prior to adding any fill. 1 1 Share this post Link to post Share on other sites
WHNJ701 4,172 #3 Posted January 2, 2019 I bought a 12×20 in 2006 for temp storage for my mustang, here it is 2019 and 3 covers later and moving it to a new house it still going strong, I now have the heavy duty cover with 10 year rating and I added 2 rows of emt pipe along the roof to help with the snow load. that's the only pain is getting the snow off asap. other than that it's a cheap ugly tent building. I just have 3/4 crushed for the floor 1 Share this post Link to post Share on other sites
WHX?? 57,356 #4 Posted January 2, 2019 (edited) Quite a few of us have them. The biggest problem we see is how they will hold up to the uv rays of the sun. Mine is less that a year old so time will tell. I used 3/8 driveway gravel under mine but if drainage is a problem you could elevate it a tad and use a larger stone for the base. This one was put up on a foot or better drop in grade in 13 ft so I used landscape timbers I had lying around to level it out. It's a Shelter Logic from Northern Tool ...20 x 13 I believe and holds a dozen + or - tractors given size of tractor. Edited January 2, 2019 by WHX21 6 1 Share this post Link to post Share on other sites
wallfish 20,186 #5 Posted January 2, 2019 When I had mine,( 12 x 20 ) put down a tarp, then put down used pallets over the tarp and covered the pallets with 8' x 4' pieces of OSB. Made a nice easy, inexpensive floor and kept the moisture out. Added extra black steel pipe to the roof for snow load too. Pros-- keeps your stuff dry, fairly easy to put up Cons-- They're ugly, you need to knock off the heavy loads of snow 3 2 Share this post Link to post Share on other sites
Sparky-(Admin) 25,862 #6 Posted January 2, 2019 My 12x20 is on a wood deck. Pressure treated framing with an OSB wood floor. My tops last about 4 years before the sun and it’s UV rays wreck it. My zippered front door quit as well so it now has a T-111 wood front with a hinges door. 1 1 Share this post Link to post Share on other sites
Pullstart 70,529 #7 Posted January 2, 2019 18 minutes ago, wallfish said: When I had mine,( 12 x 20 ) put down a tarp, then put down used pallets over the tarp and covered the pallets with 8' x 4' pieces of OSB. Made a nice easy, inexpensive floor and kept the moisture out. Added extra black steel pipe to the roof for snow load too. Pros-- keeps your stuff dry, fairly easy to put up Cons-- They're ugly, you need to knock off the heavy loads of snow I had one fail due to snow load, that melted a tad then received rain by the bucket. A good 24” shop broom on the inside easily sweeps the snow off the outside. That hut lasted 4-5 years before failure, purchased from Tractor Supply. 1 Share this post Link to post Share on other sites
WHX?? 57,356 #8 Posted January 2, 2019 I figure I get 4 years out of it is doesnt owe me anything. Mine is supposed to be the "alpine" style and is supposed to shed snow. 1 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #9 Posted January 2, 2019 I've often wondered if a generous application of mobile home roof sealer... would would buy you some time, and extend the life of these covers. 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,735 #10 Posted January 2, 2019 1 hour ago, AMC RULES said: I've often wondered if a generous application of mobile home roof sealer... would would buy you some time, and extend the life of these covers. Craig- That will not work. If you are thinking about a coating then you need a urethane liquid applied coating. Problem is the cost of the coating is about the same as a new cover.... 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #11 Posted January 2, 2019 (edited) Adhesion problems and lack of flexibility limits what coating would hold up. Probably cheaper to replace the top but I'm all ears and anxious to be wrong! I have several buildings but also several tents. Trick is to keep sun off the tents and the tarps will last up to 10 years. Otherwise 3-5 up here in Northern NY. That trick is to place them in the shade! Most of my tents are under big pines. By the way, leave room between to allow for snow shedding and clearing. Edited January 2, 2019 by DennisThornton 1 Share this post Link to post Share on other sites
Ed Kennell 46,510 #12 Posted January 2, 2019 I get about 3 years out of my 12X20 boat tent. It's only up from April thru Oct. I take the cover off when I close camp. 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #13 Posted January 2, 2019 I built a "foundation" out of railroad ties then filled with gravel. The framework is bolted to the ties. It has been up for 6 or 7 years now. The cover is getting thin in places and probably needs replaced. Best storage area for the price. 1 1 Share this post Link to post Share on other sites
bottjernat1 2,196 #14 Posted January 2, 2019 (edited) For the cost i kept buying these cheaper things and i desided id be better off buying a shed. I ended up buying 2 sheds barn style when my dad passed away one i bought out right a 12x24 with a reinforced floor. the other is a 10x16 this is the best money i have ever spent. my 10x16 the payments are less then $100 a month. and they come with lifetime warranty on the roofs. and warranty on the door handles and hinges. I am very happy with what i have! Here is there web page they deliver and setup! https://easyrentalsllc.com/ Edited January 2, 2019 by bottjernat1 1 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #15 Posted January 2, 2019 Can't beat the price and time required! Placing in the shade keeps the UV from wrecking havoc so quickly and reduces snow accumulation but I'm planning on adding metal roofing on purlins. Heck, I might even side them. Could even frame up the ends and add a real door! 1 1 Share this post Link to post Share on other sites
WHX?? 57,356 #16 Posted January 2, 2019 13 hours ago, DennisThornton said: Probably cheaper to replace the top Guess I didn't know the tops were replaceable. Just like those canopies we use at tractor shows you can buy a whole new one for the price of the top..... E-Z ups anyway. I was also guessing that in 4 years when mine is shot it would be obsolete and a replacement top NLA. Jeff @WVHillbilly520H has a all metal instant garage he likes and I will be looking into one of those someday. They would be nice for keeping firewood under cover as well as tractors. 1 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #17 Posted January 2, 2019 5 hours ago, WHX21 said: Guess I didn't know the tops were replaceable. Just like those canopies we use at tractor shows you can buy a whole new one for the price of the top..... E-Z ups anyway. I was also guessing that in 4 years when mine is shot it would be obsolete and a replacement top NLA. Jeff @WVHillbilly520H has a all metal instant garage he likes and I will be looking into one of those someday. They would be nice for keeping firewood under cover as well as tractors. Jim, here is the company I used, you have to find an area "dealer" to order with 10-20% down then once the permits are in place they usually ship/erect/install within 6 weeks and pay the balance once standing...https://www.carolinacarportsinc.com/brochures... I'm sure there are others that may be better suited to your home state of Wisconsin. 1 Share this post Link to post Share on other sites
wallfish 20,186 #18 Posted January 2, 2019 Marine UV protectant spray https://www.amazon.com/30340CSR-Protectant-Plastic-Fiberglass-Leather/dp/B0004ELKC4/ref=asc_df_B0004ELKC4/?tag=bingshoppinga-20&linkCode=df0&hvadid={creative}&hvpos={adposition}&hvnetw=o&hvrand={random}&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl={devicemodel}&hvlocint=&hvlocphy=&hvtargid=pla-4584276297877716&psc=1 1 Share this post Link to post Share on other sites
WHX?? 57,356 #19 Posted January 3, 2019 (edited) Thanks Jeff, I found a guy local that has an auto body/repair shop that must sell these on the side. Be interesting if the same brand. Trouble is every time I swing in he ain't around. Looks alot like the one you have so might be. I wouldn't be beyond having two, having one enclosed for machinery and one open for wood, splitter ect. Thanks John that looks like the stuff another member was touting the other day. Swore by it. Edited January 3, 2019 by WHX21 1 Share this post Link to post Share on other sites
Sarge 3,473 #20 Posted January 3, 2019 303 would go a long way to prevent the sun from eating one of those tops - go directly to their site, there are ways to get larger bulk amounts for use in your own sprayer. https://www.goldeagle.com/product/303-aerospace-protectant/ I should start using the stuff to prevent my outdoor tarps from rotting away - storing several tractors out in our Illinois weather gets expensive as most of them only last maybe 2yrs at most. Sarge 1 1 Share this post Link to post Share on other sites
wallfish 20,186 #21 Posted January 3, 2019 7 hours ago, Sarge said: 303 would go a long way to prevent the sun from eating one of those tops - go directly to their site, there are ways to get larger bulk amounts for use in your own sprayer. A gallon on there is $85. Click on the Amazon link and you can find it for as low as $44 a gallon (128 oz) It's not cheap but... 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #22 Posted January 4, 2019 303 @ $50/gal would be worth it if would add a couple years life. Heck a qt might provide one coat and if that added a year... Share this post Link to post Share on other sites
WHNJ701 4,172 #23 Posted January 4, 2019 also too call shelter logic they are easy to deal with, the 10 year cover is pre sealed and very heavy duty and and for the money it be worth it rather than sealing the old one Share this post Link to post Share on other sites
buckrancher 2,697 #24 Posted January 4, 2019 best way to make the covers last is cover the top with the std flat tarps I have a 12x20 that put two 12x16 silver tarps on top(12 foot length ways will give over lap in middle) then change the flat tarps every 2/3 years have had my original cover for ten years now by doing this Brian 4 2 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #25 Posted January 4, 2019 19 hours ago, DennisThornton said: 303 @ $50/gal would be worth it if would add a couple years life. Heck a qt might provide one coat and if that added a year... When I had my small one (8x10/10x12?) I used "Black Magic" vinyl protectant about a week before a bigger snow storm, the snow did slide off better than not treating it, maybe that's why it lasted more than a year as opposed not treating it , something is better than nothing...now if those tops were made from marine grade vinyl like truck bed tonno covers they'd probably last 10+ years. Share this post Link to post Share on other sites
