moe1965 774 #1 Posted December 25, 2018 I purchased this tractor about a month ago and put a few posts up that some of you might have read and responded to a few of my questions. Thank you all by the way. Here is where I am at now I was told that the engine was running about a year ago I doubt that because of the things I have found wrong with it such as the exhaust valve was stuck in the open position I have corrected that problem among a lots of other things lap the valves and today I fired it up for the first time it's at and purred like a kitten. I rewired the ignition switch and put in a solenoid which was a chore for me because I'm not that good with electrical. I'm trying to work out as many bugs as I can before spring such as I have to replace all of the seals in the rear end which is my next project come springtime it's going to get a total paint job pictures to follow. Here is another question what spark plug is correct for this engine it currently has a j19lm Champion spark plug in it. Thanks in advance Merry Christmas to all. 6 2 Share this post Link to post Share on other sites
ebinmaine 80,468 #2 Posted December 25, 2018 Nice looking ride and good work so far. Plug should be a J8C I believe. Replacing transmission seals will be easy enough. Just be sure to put a piece of electrical tape or something over the groove of the shafts when installing the new seals to prevent cutting them. Pulling the hubs can be quite a challenge. Not sure if you have attempted that yet. 1 Share this post Link to post Share on other sites
moe1965 774 #3 Posted December 25, 2018 (edited) I have replaced seals in my other two tractors and made a puller out of a old hub. I know they can be a pain but I thank God I have a lot of patience because you don't want to force them. Edited December 25, 2018 by moe1965 2 Share this post Link to post Share on other sites
ebinmaine 80,468 #4 Posted December 25, 2018 1 minute ago, moe1965 said: made a puller out of a old hub Perfect !! Share this post Link to post Share on other sites
Pullstart 71,164 #5 Posted December 27, 2018 @moe1965 it’s your ride, do as you wish.... but if it were me I’d try to clean up that patina and let it be.. Share this post Link to post Share on other sites
WHNJ701 4,173 #6 Posted December 27, 2018 don't put a champion plug in it, go with a ngk or something better. I never had an issue pulling hubs off, spray them up good with pb blaster a week or so to let soak in. I would also take those goofy lights off it and box them up and send them to me for my 854! 1 1 Share this post Link to post Share on other sites
moe1965 774 #7 Posted December 28, 2018 Made a little more progress today. Tomorrow I'm going to replace all the seals. I ran the moter for about an hour yesterday. Charging system worked fine. It smokes a little on throttle up and throttle down. Not really sure if I'm going to go further on a engine rebuild or not. It's gona be more of a putter and maby a snow pusher on the winter. Any thoughts? 1 Share this post Link to post Share on other sites
ebinmaine 80,468 #8 Posted December 29, 2018 If you're really not gonna work it to hard.... Runnit.... 1 Share this post Link to post Share on other sites
WHNJ701 4,173 #9 Posted December 29, 2018 a ring could be hung up a little from sitting, I had a briggs that on tractor that must have sat for 25 years, it smoked liked crazy the first time I got it running again, each time it got better, added some marvel mystery oil into the oil, the engine runs with very little if any smoke now, didn't see a need to tear it down since it's on a limited use show tractor 1 Share this post Link to post Share on other sites
moe1965 774 #10 Posted December 29, 2018 Thanks jabelman. I did just that. I added mystery oil to the oil and gas hoping eventually after running it that might help. I put a post on here a while back about using Marvel Mystery Oil and peoples thoughts etc. I'm not much of a guy on Vudu or what not but it did work for me in my fuel system on a 141 took some time. I had some carburetor issues it ran fine at a high rpm but would never idle good. After about 4 tanks full it cleared right up. I'm hoping that it is a ring issue and it does clear up I had the head off of it and I could still see the hash marks in the cylinder walls leading me to believe that the cylinder and piston is still in good shape there was a lot of carbon buildup in this engine. 2 Share this post Link to post Share on other sites
moe1965 774 #11 Posted December 31, 2018 All this because my oil pan gasket was leaking then I found the steering was sloppy might as well fix that and I have an O-ring in my fuel bowl shutoff that was hard to get at to replace so I just took the tank off to make things easier I think I'm crazy 1 3 Share this post Link to post Share on other sites
ebinmaine 80,468 #12 Posted January 1, 2019 A never ending process..... I need to remove this to get to that.... Might as well fix these too... While I'm here I'll just take those off too.... 1 Share this post Link to post Share on other sites
WHNJ701 4,173 #13 Posted January 1, 2019 4 hours ago, moe1965 said: All this because my oil pan gasket was leaking then I found the steering was sloppy might as well fix that and I have an O-ring in my fuel bowl shutoff that was hard to get at to replace so I just took the tank off to make things easier I think I'm crazy looks good so far definitely makes it easier to degrease and start rubbing that Johnson paste wax into that frame 1 Share this post Link to post Share on other sites
moe1965 774 #14 Posted January 1, 2019 Steering issue solved ended up being a little bit of slop in the roll pin it's amazing how little slop transfers to a lot of slop on the other end I just jumped up one size in a roll pin seems to be enough meat on the cast iron part I don't think I'll have any issues now 1 Share this post Link to post Share on other sites
