TravelinJavelin 620 #1 Posted December 7, 2018 was wondering if anyone or knows anyone that has put a attach matic on the front there machine doing a trade this weekend and just currious if its possible or not a good idea on these? Share this post Link to post Share on other sites
19richie66 17,624 #2 Posted December 7, 2018 I put an attachamatic on my gt14 as Aldon also did. On the gt14 you would have to weld a thicker front plate. I believe the 953/1054 has a thick plate but the axle pin runs though it. I really dont see any problems other than possibility of the tire on the right hitting the pulley if you run a mule drive. Share this post Link to post Share on other sites
TravelinJavelin 620 #3 Posted December 7, 2018 well i do have set up where someone made a front mount that bolts in to the front not the sides and it sort of front tach but you just run your long pin through it just sticks out maybe 6" longer then normal wonder if the lift will bring it up all right? Share this post Link to post Share on other sites
19richie66 17,624 #4 Posted December 7, 2018 Any pics? Just trying to understand what tou have there. Share this post Link to post Share on other sites
"D"- Man 827 #5 Posted December 7, 2018 I purchased a used 1054 with a Wheel Horse attachment bracket thingy on the front but not sure if this is what you are referring to. Excuse the poor picture due to lighting conditions and it is sort of tucked away in my garage. 2 Share this post Link to post Share on other sites
TravelinJavelin 620 #6 Posted December 7, 2018 yup that is it huh looks like its bolted on from underneath? thanks for the pic on this .......if its not alot of trouble i'd be currious how that is mounted and wondering if that came off from D series tractor? Share this post Link to post Share on other sites
19richie66 17,624 #7 Posted December 7, 2018 (edited) Here is mine. 3 bolts through the front plate. My 953 and the 1054 will get them too. You can weld chain links to a piece of 5/8” rod and use it as a front tie down point also. Edited December 7, 2018 by 19richie66 3 4 Share this post Link to post Share on other sites
oliver2-44 10,679 #8 Posted December 7, 2018 2 hours ago, 19richie66 said: You can weld chain links to a piece of 5/8” rod and use it as a front tie down point also. @19richie66 Thats a great idea, thanks for sharing it. The fronts are always hard to tie down without the straps or chain scuffing some paint up. 1 Share this post Link to post Share on other sites
TravelinJavelin 620 #9 Posted December 7, 2018 hey Richard is the tach matic from a D series or C series tractor? or how about where can i get one? i have something simalar but its 2 bolt to the front plate on mine or is this like a gt -14 special? Share this post Link to post Share on other sites
ebinmaine 72,382 #10 Posted December 7, 2018 27 minutes ago, TravelinJavelin said: hey Richard is the tach matic from a D series or C series tractor? or how about where can i get one? i have something simalar but its 2 bolt to the front plate on mine or is this like a gt -14 special? B and C had them... Not sure about D. I may have one o' them around here. Do you have any pics of what you want? Share this post Link to post Share on other sites
TravelinJavelin 620 #11 Posted December 7, 2018 a front bolt on? Share this post Link to post Share on other sites
19richie66 17,624 #12 Posted December 8, 2018 (edited) Someone had put this on mine before I got it. There were three holes in the plate and bracket. I can’t say whether it was like that or if someone drilled it. I just removed it, welded the plate back on right and reinstalled it. I’ll try to get a better picture tomorrow. Edited December 8, 2018 by 19richie66 Share this post Link to post Share on other sites
TravelinJavelin 620 #13 Posted December 8, 2018 i got one on my charger 9 now but it bolts to the side of the frame and the bolt holes don't line up on my 953 1 Share this post Link to post Share on other sites
TravelinJavelin 620 #14 Posted December 8, 2018 44 minutes ago, ebinmaine said: B and C had them... Not sure about D. I may have one o' them around here. Do you have any pics of what you want? just like whats shown in the pic eric if you got one i'll take it Share this post Link to post Share on other sites
ebinmaine 72,382 #15 Posted December 8, 2018 41 minutes ago, TravelinJavelin said: i got one on my charger 9 now but it bolts to the side of the frame and the bolt holes don't line up on my 953 Have any pics of that? I know someone looking for one for an electro 12 33 minutes ago, TravelinJavelin said: just like whats shown in the pic eric if you got one i'll take it I have a C81 Parts Tractor out there that should have what you need. Share this post Link to post Share on other sites
TravelinJavelin 620 #16 Posted December 8, 2018 if it bolts from the front and not the sides.......my charger 9 bolts on the sides of the frame rails Share this post Link to post Share on other sites
ebinmaine 72,382 #17 Posted December 8, 2018 If the one on your charger could be for sale I know someone who might be interested. Share this post Link to post Share on other sites
TravelinJavelin 620 #18 Posted December 8, 2018 well i think i have it sold for sunday ......we'll see 1 Share this post Link to post Share on other sites
19richie66 17,624 #19 Posted December 8, 2018 (edited) This is what is on mine. The bottom one is off of a 418-A. I use the axle pivot pin hole for a tie down point. Edited December 8, 2018 by 19richie66 3 Share this post Link to post Share on other sites
TravelinJavelin 620 #20 Posted December 8, 2018 ordered off ebay just like it this one morning Share this post Link to post Share on other sites
19richie66 17,624 #21 Posted December 8, 2018 (edited) I just took this off a frame I stripped out. I would have given it to you. Dang🙈 Edited December 8, 2018 by 19richie66 1 Share this post Link to post Share on other sites
TravelinJavelin 620 #22 Posted December 13, 2018 well i appreciate that and thank you anyways Rich Share this post Link to post Share on other sites
