ebinmaine
Why does the plow angle lever hit my brake pedal?
ebinmaine
11 minutes ago, Blasterdad said:
Didn't the B-80 have a shorter frame than the C's ? That might be the problem...:confusion-confused:
They did... But ALL the difference was in front of the forward step mount.
It's been years since I did this thread and 4 or more tractors with that plow.. I don't remember what I did to solve the issue in the end.
Blasterdad
I didn't see that @Horse Newbie dug this up...:hide::rolleyes:
Tonytoro416
I recently ran into this on my raider 12.  I lucked out cause the plow I have has extensions on it for a 520 so I was able to simply move the plow forward one set of holes. (At rear axle)
Edited by Tonytoro416
mike avad
thanks for all info mine doing the same thing on my B-80 am make a new handle for one of my dozer plows
  • Similar Content
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      C - Series, Hood and Sheet Metal (square black insert) (also known as black hood models) for sale!
      This sheet metal set, including C Series Hood, Dash piece, Seat Bracket, and Left & Right-Side Covers, and Left & Right Floorboards was sandblasted, epoxy primed, and painted the OEM Wheel Horse Red Paint.
      The painted set is not perfect, a little metal pitting on one of the floorboards, a few little imperfections in the paint here and there as I'm a rookie painter, but this is a nice painted set of sheet metal to freshen up your C Series Wheel Horse!
      $140.00 O.B.O. Call Tim @ 1-313-460-8858        (No Shipping, Local Pick-Up Only)
    • ebinmaine
      By ebinmaine
      A HUGE thank you to Tony @Docwheelhorse for settin' me up here.
      The generosity of some of our members never ceases to amaze me.
      This here is another 1974 C160, but with the rare Tecumseh HH/OH160 OHV engine. Made one year only.
      It's rough. Very much in need of a full disassembly and restoration.
      When it came here it was missing one tie rod and the other was broken off one end.
      Today I popped used tie rods on and Trina used her 867 to drag it from the drive to the shed.
      The engine wouldn't move.
      Tin was near chock full of skeletal mouseseses and their house.
      Cleaned that out and the engine spins freely now.
      So progress has been made.
      It'll be a good long while before we get to this one but I just couldn't turn it down considering the rarity.
    • Brian33
      By Brian33
      Hello,
      I am hoping someone can help my. I recently acquired a c160 for the engine for another tractor. So I did a motor swap and wanted to see what the hydro was like. I put a plow on it C-160 (which now has a 12hp engine on it). I did a quick test run and everything was good. I drained the fluid and change the filter (Napa 1410 filter and sae 30 transmission fluid as it stated to only use this fluid on the tractor.) everything was working great after the fluid change. I plowed two driveways and the sidewalks near my house... all the sudden the tractor would not go forwards or in reverse. I tried to pick the plow up and nothing... I checked my drive belt it was turning like it should. I started to push the tractor and the rear was engaged so it would not move. Of course I was 400’ from my driveway and the plow was down which made it fun. I put the tractor in forward and started to push it and the thing took off. So I hopped on and took it to the front of the garage. I put it in revers and it cut out again so I pushed it in the garage. Today I went out to check the tow valve. I took it out and cleaned the threads up put it back in and it did not change anything. According to the dipstick I have the proper amount of fluid in it. I did have a drip that I fixed on the cylinder still nothing... does anyone out there have any tips to help me out? I’ve never had a transmission like this only manual transmissions. The model of this transmission is the sundstrand 90-1140.
      Any help would be greatly appreciated.
      Brian
    • mhlmeader
      By mhlmeader
      Hi folks, me and the gal pal were on our way to the wheelhorse motherland ( southbend), to shop for some wedding rings.  So we go down little country road see a barn sale, turned around cause I spy a wheelhorse.  I ask how much , he said 400$, but someone was suppose to be picking it up.  Turns out it came with a sickle bar too. My ears kinda perked up then , cause my dad wants on for his 702.  They call the other fella,  he passed on it, I offered 300$, we settled at 350$. Tractor runs pretty good,  lil smoke when ya goose it, but runs and cuts pretty good.  I'm hoping the sickle bar will fit my dad's 702, it's a 50 inch bar.  Anywho, here's some pics a serial numbers if anyone has some additional info, or point me in the right direction,  would be appreciated,  thanks!!!
    • ebinmaine
      By ebinmaine
      I have at least 7 hubs on different tractors that I would like to add a second set screw to.
      I have an older but good quality floor model drill press.
      I have the tap set.
      I don't recall ever using the tap set to do anything other than clean out threads. Not make my own thread set.
      Can anybody give any particular advice?
