JoeB 34 #1 Posted November 18, 2018 Has anyone used synthetic oil in their horse? I'm thinking it might make for better starting and running in the cold. thanks, job Share this post Link to post Share on other sites
The Tuul Crib 7,354 #2 Posted November 19, 2018 (edited) I've always used a straight 30 weight oil in all my kohler motors. Edited November 19, 2018 by The Tool Crib 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #3 Posted November 19, 2018 If it's a old engine DO NOT RUN SYNTHETIC OIL. Synthetic is smaller particles will make engines smoke / or more smoke on worn engines. Now if you have a rebuilt engine been bored out go for it after break in. NEVER USE SYNTHETIC TO BREAK ENGINES IN RINGS WILL NOT SEAT 1 1 Share this post Link to post Share on other sites
WHNJ701 4,173 #4 Posted November 19, 2018 10-30 conventional in everything. I had an old briggs I put Lucas no smoke in once, it cleared it up. I haven't heard any benefits of synthetic in small engines, I don't even use it my vehicles 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #5 Posted November 19, 2018 43 minutes ago, jabelman said: 10-30 conventional in everything. I had an old briggs I put Lucas no smoke in once, it cleared it up. I haven't heard any benefits of synthetic in small engines, I don't even use it my vehicles Share this post Link to post Share on other sites
Tankman 3,528 #6 Posted November 19, 2018 30w unless a long cold spell, then 10w30 always conventional. I'm with TheTool Crib on this subject, "never synthetic". Particularly if you are following a PM (preventative maintenance) schedule. Why spend the extra loot? At Camp Lejeune motor pool we had 30w Texaco, if you preferred we had 30w Texaco, for combat vehicles we used 30w Texaco. On extra night duty we invented Jiffy Lube! We used 30w Texaco! Bring your car and a six pack, oil change, high tech 30w Texaco! With three grandsons, our PM schedule runs double time! Keeps the brats boys busy doing something nice worthwhile. Better than playing Nintendo games, I think. 2 2 Share this post Link to post Share on other sites
JoeM 10,318 #7 Posted November 19, 2018 I use it in all the pressurized oil system engines, and I have used it in the old Koehler Engine too. No issues. I do know we had switched to synthetic in pump gear boxes at work and they ran a good bit cooler. Transfers the heat better. 2 Share this post Link to post Share on other sites
KC9KAS 4,746 #8 Posted November 19, 2018 @Tankman Sounds like the government bought a freight trail load of Texaco 30 W oil! 1 Share this post Link to post Share on other sites
peter lena 10,109 #9 Posted November 19, 2018 oiluj52, rebuilt a lot of gear drives and pumps, changed over to royal purple oils, the bearing failures , stopped. first thing was the temperature unit drop, then the electrical power draw was lower, the system was happy. I was too, the oil change ,all but stopped late night call ins for pump failures. that's only me, pete 1 Share this post Link to post Share on other sites
bds1984 1,519 #10 Posted November 19, 2018 As long as you run the appropriate grade oil, it really makes no difference. I usually run 10W30 or 15W40 synthetic year round in all of my Wheel Horses (some with newly rebuilt engines and others with over a thousand on the clock) up to a brand new 2015 Simplicity with 5W30 syn. Before everyone here gets their undergarments in a bunch, yes, I have performed used oil analysis in the past on engines running synthetic with no issues what-so-ever. What people get so worked up over synthetics is they have an extreme ability to clean and wind up cleaning sludge/deposits away that were holding back oil from leaking out of an older engine thus condemning running synthetic oils in older engines. Mainly I run synthetic because I get it cheap at the Kmart in the town I work in and the local independent auto parts store is a perennial favorite I like to support because of a knowledgeable staff and they have a ginger parts counter cat on standby. 1 1 Share this post Link to post Share on other sites
pfrederi 21,308 #11 Posted November 19, 2018 Synthetics are very good but cost more. i would rather use the extra $$ to change the conventional dead dinosaur stuff more often...especially in older engines with no filters.... Share this post Link to post Share on other sites
Tankman 3,528 #12 Posted November 20, 2018 Used to deliver 80w90 Mobil I synthetic gear lube to UPS. Their system database proved 3 times the life of gear boxes on their trucks. Engines used non-synthetic oils. Share this post Link to post Share on other sites
