AMC RULES 36,945 #26 Posted November 17, 2018 Should work fine, until you find one. Wonder if Terry, our vinylguy... could make up a decal that could be applied right over the lexan cover? Mimic that factory lens. 3 Share this post Link to post Share on other sites
TravelinJavelin 620 #27 Posted November 17, 2018 erictrying to adapt my plow on my charger 9 and this is a story all its own glad your's is working out 1 Share this post Link to post Share on other sites
ebinmaine 63,166 #28 Posted November 17, 2018 1 minute ago, TravelinJavelin said: erictrying to adapt my plow on my charger 9 and this is a story all its own glad your's is working out Thanks Brandon. What can we do to help you out? Share this post Link to post Share on other sites
TravelinJavelin 620 #29 Posted November 17, 2018 Ebin you just must be entertained by my posts lol i'll start a new thread here shortly 2 Share this post Link to post Share on other sites
ebinmaine 63,166 #30 Posted November 17, 2018 4 hours ago, AMC RULES said: Should work fine, until you find one. Wonder if Terry, our vinylguy... could make up a decal that could be applied right over the lexan cover? Mimic that factory lens. I'll bet he could... Share this post Link to post Share on other sites
ebinmaine 63,166 #31 Posted November 17, 2018 Just now, TravelinJavelin said: Ebin you just must be entertained by my posts lol i'll start a new thread here shortly Call me in on it when you do. 2 Share this post Link to post Share on other sites
Vinylguy 4,666 #32 Posted November 18, 2018 What if I sent you a template to cut your lexan once you have your led light bezel mounted this black and chrome decal could be applied over the lexan to give it a more original look without sacrificing lumins like the original lens? 4 2 Share this post Link to post Share on other sites
ebinmaine 63,166 #33 Posted November 18, 2018 1 hour ago, Vinylguy said: What if I sent you a template to cut your lexan once you have your led light bezel mounted this black and chrome decal could be applied over the lexan to give it a more original look without sacrificing lumins like the original lens? You are some awesome Terry. @AMC RULES too. So here's a question... Keeping in mind that the led lamp has two lights that would be partially blocked by a center Wheelhorse emblem... Is there a way to make the center section a reverse or negative of itself? Have the square be clear and the emblem -only- be black so I don't lose as much light? 3 Share this post Link to post Share on other sites
Pullstart 59,735 #34 Posted November 18, 2018 59 minutes ago, ebinmaine said: You are some awesome Terry. @AMC RULES too. So here's a question... Keeping in mind that the led lamp has two lights that would be partially blocked by a center Wheelhorse emblem... Is there a way to make the center section a reverse or negative of itself? Have the square be clear and the emblem -only- be black so I don't lose as much light? He wants his own Bat Signal. 1 5 Share this post Link to post Share on other sites
PeacemakerJack 10,671 #35 Posted November 18, 2018 Well played Kevin!!!! We need an emoji for that...Craig @AMC RULES? 3 Share this post Link to post Share on other sites
Vinylguy 4,666 #36 Posted November 18, 2018 1 hour ago, ebinmaine said: You are some awesome Terry. @AMC RULES too. So here's a question... Keeping in mind that the led lamp has two lights that would be partially blocked by a center Wheelhorse emblem... Is there a way to make the center section a reverse or negative of itself? Have the square be clear and the emblem -only- be black so I don't lose as much light? Yes I will reconfigure it and repost. Will be gone tomorrow but will post back sunday. 3 Share this post Link to post Share on other sites
AMC RULES 36,945 #37 Posted November 18, 2018 (edited) @PeacemakerJack @pullstart Edited November 18, 2018 by AMC RULES 1 4 Share this post Link to post Share on other sites
