Horse Play 393 #76 Posted December 31, 2019 Also received a new, reproduction Cub Cadet steering wheel that will be modified to work on the RJ. 4 1 Share this post Link to post Share on other sites
WHX?? 56,049 #77 Posted December 31, 2019 (edited) Got a to those wheels Horse Play? Are they the ones with the splines inside? Like this? https://www.steinertractor.com/GTS002-Steering-Wheel Edited December 31, 2019 by WHX24 1 Share this post Link to post Share on other sites
ACman 7,719 #78 Posted December 31, 2019 15 minutes ago, WHX24 said: Got a to those wheels Horse Play? Are they the ones with the splines inside? Like this? https://www.steinertractor.com/GTS002-Steering-Wheel Jim those are the ones far as I know .... 1 Share this post Link to post Share on other sites
Lane Ranger 11,935 #79 Posted December 31, 2019 11 hours ago, Horse Play said: Also received a new, reproduction Cub Cadet steering wheel that will be modified to work on the RJ. I used one of these and it turned out great! 4 Share this post Link to post Share on other sites
Horse Play 393 #80 Posted January 3, 2020 Sorry for the late response... working night shift and remodeling the kitchen/living room for the wife. Yes, it is the same Cub wheel as posted above. The Cub hub is 11/16" 40-spline on the top half. But the bottom-half of the hub is a plain 3/4" diameter. I am going to have a local machine shop drill out the splines to a 3/4" diameter and also drill a roll pin hole. 2 1 Share this post Link to post Share on other sites
oliver2-44 11,390 #81 Posted January 4, 2020 On 7/8/2019 at 5:27 PM, Horse Play said: Tomorrow I will be doing the tank straps with some 3M Panel Adhesive. @Horse Play What 3M panel adhesive did you use? I went to the auto supply and they had several 3M adhesive products. Share this post Link to post Share on other sites
tom2p 2,394 #82 Posted January 4, 2020 On 7/9/2019 at 8:31 PM, Horse Play said: Too late, I already glued them in at 8:00am this morning; so we shall see... I worked at a Ford dealership body shop and this stuff was amazing. We replaced a damaged bed side on a F-150; a few months later the same bed side was hit again and had to replace the bed side and that adhesive was some powerful stuff. last time I talked to my body shop friends - they were using adhesives almost exclusively to install panels on cars - including door skins and rear quarters adhesives - instead of panel spot and / or braze new cars ... vintage / muscle cars ... etc customer cars - and their own cars adhesives have been used extensively in the aerospace and aviation industry for years Share this post Link to post Share on other sites
Horse Play 393 #83 Posted January 8, 2020 (edited) Sorry, I do not remember what exact type - all I remember it was a 3M panel adhesive. My buddy let me use a tube from his body shop one day. It was the commercial, two-part stuff that needs a mixer tip. Edited January 8, 2020 by Horse Play 1 Share this post Link to post Share on other sites
Horse Play 393 #84 Posted April 21, 2020 It appears the machine shop did a goo job on drilling the Cub steering wheel. It cost me a total of $45; $20 for the drill bit and $25 for the drilling. I then did had to do a little sanding and scuffing, then resprayed the spokes and hub due to a few nicks at the machine shop. 2 1 Share this post Link to post Share on other sites
Pullstart 69,639 #85 Posted April 21, 2020 Nice! Did you get to keep the drill bit? Share this post Link to post Share on other sites
Horse Play 393 #87 Posted April 21, 2020 Only a few more small bits left to do. I still need to track down a belt guard and heat shield. 1 1 Share this post Link to post Share on other sites
