LengerichKA88
Charger 10 Trans: Where to start?
LengerichKA88
I liked, but didn’t find an applicable thread, so I made a new post.
We got a 69 Charger 10 last Friday. The brakes don’t really stop it, kinda slows it to an idle speed. Still too fast for the brakes to be engaged. FIL did some reading and it’s apparently the gears that stop the tractor, so now we’re looking at servicing and possible actually doing work on the trans. That’s fine, not a problem, figured we’d get into this eventually, so with the one known issue at hand, how would/have you gone about tackling this trans?
Trying to get voices of experience that might be able to save us a headache or two lol. TIA!
pfrederi
There are no brakes on a Charger 10.   there is a parking brake if you trtry to apply it while moving it grinds itself to death on  a gear in the tranny.  spewing metal shavings that circulate through the system eventually destroying the hydro.
The "brake pedal merely moves the motion control to neutral and the hydro action stops the tractor.  it will not hold on a hill.    Does it still have reasonable power when heated up?  If you put it against a fixed object will she spin her wheels with you on it???
953 nut
On page three of this manual you will find a procedure for setting the "Neutral Adjustment" which will stop the tractor. To hold mine in place on a hill I lower the FEL bucket or drop a 4 X 4 on a string that I carry. A bit crude but it works.
pfrederi
You know Rich you could always replace/repair the parking pawl:P some what classier than a 4x4
  • Haha 4
LengerichKA88
It’s got some other issues with it, so I don’t think it’s quite running at full steam as it is anyway. I DO know not to attempt to engage the parking break while in gear/moving. That was a very loud lesson I learned as a kid 😂😂.  The way it sounded when my FIL explained it, I was under the impression that something in the trans locked up when you depressed the clutch/brake, so that may have been the “brake”down in communication. Everything on this tractor is original. It still has the “Wheel Horse” branded tires all around, and with its general state, we just assumed (I know what that makes me 😂) that maybe something wasn’t engaging like it was supposed to.
It does still creep forward even when on a level surface, but it was during unloading that I noticed it, which was on a slope.
Awesome! Maybe this will set us straight!
LengerichKA88
Seems the Neutral Adjustment got her right! Thanks fellas!
pfrederi
Does you parking brake work ???
953 nut
This is on the GT-14 with front end loader (sub-frame goes from front of frame to the rear axle), Three point hitch, loaded tires and the WW-93 15"wheel weights. By the time I removed all of that to remove the rear end It wouldn't be worth it.
I may want to paint the 4 X 4 RED to make it a bit more classy.              :ychain:
LengerichKA88
Yes it does! Sorry, I forgot to say in my initial response, but the parking brake has worked since we got it, and still does. 🤞🏻
  • Similar Content
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • giant_g2
      By giant_g2
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The kit operates very simply and similar to modern tractors. When the pedal is pushed forwards the tractor will move forwards. When the reverse pedal is pressed downwards, the tractor will moved in reverse. If the operator takes his foot of the pedal at any time, the pedal will automatically center itself and the hydrostatic transmission will return to neutral (stop). This enables the operator to use both hands on the steering wheel or one hand on the wheel and the other operating an attachment like a snow blower, plow, etc.
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      The pedal kit fits the following series tractors with Eaton hydrostatic transmissions: C-1X5, 300, 400, 500.
      My kit can be adapted to older hydrostatic tractors with the Sundstrand transmission, however, you will need to find an updated hydro cam commonly found on ebay. Message me for more information.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      If anyone has any questions please feel free to PM me or post your question here and I will be glad to help. Or you can email me at mattdarling02@hotmail.com.
      Thanks!
      Below are pictures of the complete kit and the pedal installed on the tractor. Some modifications have been made since these pictures were taken. For example, the reverse pedal is now cast in aluminum instead of the steel pedal shown below.
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
