Chuck14025
GETTING AT 9 PIN CONNECTOR ON 520H
Chuck14025
Can anyone tell me how to get at the 9 pin connector under the battery platform on my 520H. I have pulled the battery out and the front plate off the dash (under the gauges) and the left side panel. Do I have to take the entire center of the tractor apart?
WHX??
Yeah I can tell ya Chuck. ..with great difficulty sometimes. It seems like of all my 3 520's some lay out there right in front of you some a real pain to get at ... Best advice I can give you is loosen up the harness up enough to get on it and check it out. Shouldn't have to take the the hood stand off in mose cases. Check for cable holders in places in ungodly places that will free it up enough to work on it.  Seems like the ones  easier to get at are ones a PO might have already gotten up front.
WVHillbilly520H
Of the 3 I have owned, NONE were so bad that you would have to remove the hoodstand or the hood, maybe the battery, but not really anything else...
Chuck14025
Thanks for the input guys.
I had to pull the battery.
Found the 9 pin connector under the plate that supports the battery.
Could not get the plate out without dismantling the guts of the tractor.
Tried to take the sheet metal off the left side. Not a good idea.
Will try to free up the cable brackets to free up the connector.
Chuck14025
Thanks also for the photo of the connector. That helps.
SPINJIM
My two 520s have a reasonable amount of slack to the 9-pin.  I suspect that yours might be secured with a nylon tie somewhere up under the battery tray.  Might have to use a mirror to trace the wires to see where they lead, but you shouldn't have to dismantle any sheet metal.   Good luck.
   Jim
lynnmor
Is this an older 520H?  My 91 thru 97's all have the connector right in front of the top edge of the battery with the wiring zip tied to the cross piece.
  • Similar Content
    • Chaz54
      By Chaz54
      Full set of NOS Wheel Horse Chrome Embossed Hubcaps for a 520H.
      Let me know if you have questions, need more information, pictures, etc.
      Buyer pays shipping. Located in Washington, MO 63090
    • Gettysburg Axel
      By Gettysburg Axel
      In search of a mule drive for a 60 inch deck for my 520. Located near central Pa or able to ship if possible. Also would be interested in trading parts for the mule drive if wanted.
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
