19richie66 16,943 #51 Posted October 29, 2018 (edited) https://www.wheelhorseforum.com/applications/core/interface/file/attachment.php?id=90962 Edited October 29, 2018 by 19richie66 Share this post Link to post Share on other sites
ZXT 2,394 #52 Posted October 30, 2018 (edited) Thanks for that photo! I came across it once when I first started working on it but couldn't find it in a manual again. I need to improve my searching skills. Does the pivot lever button simply adjust out against the plastic slide piece for friction? In order to get everything properly placed, I suppose I'll need to drill a new hole for the ball stud to the left of the current one. Thanks! EDIT: Thanks for the link to the manual! I didn't realize the thread had spilled over onto a new page. Edited October 30, 2018 by ZXT Share this post Link to post Share on other sites
19richie66 16,943 #53 Posted October 30, 2018 The friction you speak of should be in the motion lever itself. It has a male/female cone that you tighten with the spring and jam nut. Page 10 of this “essential “ gt14 thread there are some good hydro shots. I have a photo somewhere of the lever assembly disassembled that I saw somewhere on here and saved but cannot find at the moment. 2 3 Share this post Link to post Share on other sites
ztnoo 2,298 #54 Posted October 30, 2018 (edited) 12 hours ago, ZXT said: I need to improve my searching skills. @ZXT, Just a tip in case you haven't quite absorbed all the nuances of the forum layout and structure. It's certainly not something I learned overnight. One thing that helps me greatly here at RS is to "Follow" posts I find of particular interest, especially when it comes to GT 14 threads, as well as certain specialized areas of repair, electric clutches being one example. I use this feature much like a "bookmark" feature in a browser. The difference being it is in essence being bookmarked here within the Red Square format instead of your browser. "Follow" can be accessed in any thread in the upper right hand portion of every forum thread page. If you choose that option, you can also choose to be automatically notified when a new comment is made in that thread. To access threads you have chosen to "Follow", simply go to the very top right corner of a page. To the right of your avatar and user name, you will see a downward pointing triangle, which indicates a drop down menu. Click on that and click on "Manage Followed Content". That will then open to a catalog list of all the threads you have chosen to "Follow". Search within, by title, for the topic you seek, and click on it to open the thread. This feature can save you tens of minutes or more in searching for something you want to refer back to refresh your memory about a specific subject or specific topic. Try it! I think you will like the feature. Regards, Steve btw, do you have a real first name, ZXT??? Edited October 30, 2018 by ztnoo 1 1 Share this post Link to post Share on other sites
ZXT 2,394 #55 Posted October 30, 2018 Richie, I thought it seemed odd the way I was describing it. Thanks for clearing it up! Thanks, Steve! I found the follow feature and I've been using it. I didn't know about the manage feature, but I do now! Yep, I do have a name. It's Jonah. 1 Share this post Link to post Share on other sites
19richie66 16,943 #56 Posted October 30, 2018 Here they are Jonah. I knew I had them somewhere. Hope this helps. 1 1 Share this post Link to post Share on other sites
Aldon 4,826 #57 Posted October 30, 2018 I will say that I have taken several of these GT14’s apart and in 80 percent of the cases I find that someone has been in there previously and left the woodruff key out. It it makes a difference but I was never able to get to get the friction as sticky as I would prefer. 2 Share this post Link to post Share on other sites
ztnoo 2,298 #58 Posted October 30, 2018 @19richie66, That looks like two of Dave Luzier's great descriptive pics. They are always super informative and instructional in detail. 1 Share this post Link to post Share on other sites
ZXT 2,394 #59 Posted October 31, 2018 Thanks for the pictures, guys! I drilled a hole in the shifter mechanism so that I could use the side hole in the slide cam, and now everything lines up and works good, with the exception of one thing. When I took it on its maiden voyage, I forgot and left the one of the retainers and screw for the slide cam on the tractor and they vibrated off. I can make on easily enough, but it's still aggravating. I also changed the pump input shaft seal and it no longer leaks like a sieve. Its coming together slowly but surely! 2 Share this post Link to post Share on other sites
swisstrac 49 #60 Posted November 2, 2018 Thank you Richie for the nice description and pics of the sundstrand motion control ' what a big help I was lubing the sh.. out of them to no avail. now if will rectify the problem/ 2 1 Share this post Link to post Share on other sites
