ebinmaine 77,069 #1 Posted September 26, 2018 I still need a crankshaft for Trina's 657. What engines can I get a donor from? @A-Z Tractor @pfrederi @WHX20 Or anyone who knows tecchys.... thanks Share this post Link to post Share on other sites
WHX?? 54,508 #2 Posted September 26, 2018 I know squat about techys EB, other than the lone one I got runs pretty good but smokes like the devil! Mike @squonk might know abit about them? 1 1 Share this post Link to post Share on other sites
pfrederi 19,785 #3 Posted September 26, 2018 Probably limited selection as WH used 1" cranks most other techy users had 3/4" Probably will have to find a ex WH motor. There is no nice crank manual for Techy like the Kohler one Share this post Link to post Share on other sites
ebinmaine 77,069 #4 Posted September 26, 2018 2 hours ago, pfrederi said: Probably limited selection as WH used 1" cranks most other techy users had 3/4" Probably will have to find a ex WH motor. There is no nice crank manual for Techy like the Kohler one Paul is that just the pulley mount or the bearing point as well ? Like if I changed pulleys could I use something else? Share this post Link to post Share on other sites
pfrederi 19,785 #5 Posted September 26, 2018 The 1" goes into the bearing end plate so it is 1" oil seal and I assume bearing. I have no idea if 3/4inch crank ends were turned down after the bearing end plate or back into the end plate and bearing itself. You would have to search model numbers of donor engines and see if the oil seal is the same part number as the one on the wheel horse model. Share this post Link to post Share on other sites
ebinmaine 77,069 #6 Posted September 26, 2018 1 hour ago, pfrederi said: The 1" goes into the bearing end plate so it is 1" oil seal and I assume bearing. I have no idea if 3/4inch crank ends were turned down after the bearing end plate or back into the end plate and bearing itself. You would have to search model numbers of donor engines and see if the oil seal is the same part number as the one on the wheel horse model. That works for me. Thank you sir. 1 Share this post Link to post Share on other sites
squonk 45,371 #7 Posted September 26, 2018 6 hours ago, WHX20 said: I know squat about techys EB, other than the lone one I got runs pretty good but smokes like the devil! Mike @squonk might know abit about them? All I know about Tecky's is this: My dad bought a 604 brand new in 64. When the house was sold in 77 the 604 wwnt with it. It was on it's 4th motor and sixth carb 1 Share this post Link to post Share on other sites
ebinmaine 77,069 #8 Posted September 26, 2018 8 minutes ago, squonk said: 4th motor Ouch I'm hoping I'll be able to get a crankshaft and some other stuff from A - Z tractor. It would be nice to get this Tecumseh back up and running again. At that point I'll just take the Briggs back off and set it aside for a future project of some sort or another. Share this post Link to post Share on other sites
pfrederi 19,785 #9 Posted September 26, 2018 2 hours ago, squonk said: All I know about Tecky's is this: My dad bought a 604 brand new in 64. When the house was sold in 77 the 604 wwnt with it. It was on it's 4th motor and sixth carb My father bought my L107 in 1967 Still running.. is on its second engine mainly because my brother and i thought he needed ACR (he was too frugal to buy electric start) 1 Share this post Link to post Share on other sites
