pfrederi 20,675 #1 Posted September 21, 2018 Over the last few years I have been converting my under seat gas tank horses to electric pumps. 3-4 year ago I did 2 C-175s and a 418A I used Facet Posi-Flo pumps. Being a cheap SOB and having seen other folks using no name Chinese pumps I bought 2 and put one on a C-175 in the spring. Worked OK (but looking back she only got a couple hours use this year). Last week put the second cheapy on a C-141. worked fine...for about 3 hours total then died several hundred feet from the shop. Pump simply stopped working no noise no pumping. Dead horse recovery is normally done by the FEL on the D200. Strap around the front axle of the sick horse pick it up and drive the D200 backwards to the shop. However the C141 had the front mount deck so that wouldn't work.. Took some jumper wire out figuring electric issue.. no go. I had left the mechanical pump on figuring in the future would make a cover plate. Had to take fender and seat off then bypass the electric pump and reconnect the mechanical one. No matter how i tried to figure what I needed multiple trips back for tools were in order. Got her running and didn't feel like putting the seat and fender back on so put it in low range 2nd and walked her back. Put a Posi-Flo on and all is well. Sometimes it is worth spending more Now I am wondering if i should take the cheapy off the one C-175 or take my chances... https://www.ebay.com/itm/2-Pcs-12V-Low-Pressure-Electric-Fuel-Pump-Diesel-Gas-Fuel-Oil-for-Universal-car-/182455270871?hash=item2a7b2e7dd7 . Share this post Link to post Share on other sites
squonk 46,876 #2 Posted September 21, 2018 I had one of those Facet pumps fail last winter after 3 yrs. of use. Bought another one though as my Napa stocks them and they are 10 min from my house. Share this post Link to post Share on other sites
953 nut 66,621 #3 Posted September 21, 2018 Paul, sorry to hear this. I have had one on my GT-14 with FEL for about five years and had no issues. Also have one on the 953 Custom that I use to cruise shows and flea markets which has been on for about three years. Hope yours is an exception, I have recently put them on a couple others and have been telling others about them. Share this post Link to post Share on other sites
wallfish 20,050 #4 Posted September 21, 2018 Bought 4 of the cheap pumps just like yours and had one lock up too. Running perfectly fine then just instantly stopped. Out of the box you can blow air straight through the check valves, after it locked up no air could be blown through. Haven't had the chance to open it up yet to see what's going on. Share this post Link to post Share on other sites
oldlineman 1,735 #5 Posted September 22, 2018 Just for my info. what presure and flow rate should these pumps be rated at. Might be putting on a 1979 c-101 in the future. Thanks for any info. Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #6 Posted September 22, 2018 15 minutes ago, oldlineman said: Just for my info. what presure and flow rate should these pumps be rated at. Might be putting on a 1979 c-101 in the future. Thanks for any info. Try to keep it 3psi and under. 2 2 Share this post Link to post Share on other sites
pacer 3,180 #7 Posted September 22, 2018 I had about 3 failures with that round type pump. Had another cheapo type (see pic) that had been on my D-180 for some 10-12 yrs so in replacing the round types with the 'square' type I have been having better luck 2 2 Share this post Link to post Share on other sites
Machineguy 877 #8 Posted September 22, 2018 (edited) 10 minutes ago, WVHillbilly520H said: Try to keep it 3psi and under. A return bypass line will help regulate that along with a properly vented fuel cap. Edited September 22, 2018 by Machineguy 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #9 Posted September 22, 2018 Just now, pacer said: I had about 3 failures with that round type pump. Had another cheapo type (see pic) that had been on my D-180 for some 10-12 yrs so in replacing the round types with the 'square' type I have been having better luck They have a low pressure version of that at Advance and Auto Zone under "Mr Gasket" brand...https://www.holley.com/products/fuel_systems/fuel_pumps_regulators_and_filters/fuel_pumps/carbureted_fuel_pumps/carbureted_electric_fuel_pumps/parts/42S 1 Share this post Link to post Share on other sites
Sarge 3,471 #10 Posted September 22, 2018 There are two main versions of the Facet pumps - those that fail are imported, the ones that last a long time are made here in the US. Price is triple on the US made unit - so that decision has to be made. For my D, due to its weight, size, and difficult to move if its dead, US made one. I still run the mechanical pumps on everything else, they just work and now we can get rebuild kits for them. Sarge Share this post Link to post Share on other sites
KC9KAS 4,746 #11 Posted September 22, 2018 18 hours ago, pfrederi said: Now I am wondering if i should take the cheapy off the one C-175 or take my chances... Guess it depends on how far from the work shop you want to be when it quits! 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #12 Posted September 22, 2018 19 hours ago, WVHillbilly520H said: They have a low pressure version of that at Advance and Auto Zone under "Mr Gasket" brand...https://www.holley.com/products/fuel_systems/fuel_pumps_regulators_and_filters/fuel_pumps/carbureted_fuel_pumps/carbureted_electric_fuel_pumps/parts/42S @WVHillbilly520H Have you ever used one of these Mr. Gasket pumps ? 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #13 Posted September 22, 2018 5 minutes ago, elcamino/wheelhorse said: @WVHillbilly520H Have you ever used one of these Mr. Gasket pumps ? A long time ago on a small block chevy was the 4-7 psi though, it actually was quite adequate for a stock engine. 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #14 Posted September 22, 2018 Pretty sure the pump on my 310 is on its last legs , Going to replace with electric . May try the Mr. gasket. since the Advance is 1/8 from the house will not have to pay shipping. 2 Share this post Link to post Share on other sites
pfrederi 20,675 #15 Posted September 23, 2018 On 9/22/2018 at 8:49 AM, Sarge said: There are two main versions of the Facet pumps - those that fail are imported, the ones that last a long time are made here in the US. Price is triple on the US made unit - so that decision has to be made. For my D, due to its weight, size, and difficult to move if its dead, US made one. I still run the mechanical pumps on everything else, they just work and now we can get rebuild kits for them. Sarge The ones I have used the box says designed and manufactured in the US 1 Share this post Link to post Share on other sites
Sarge 3,471 #16 Posted October 1, 2018 If you don't mind - what is your source for the US made pumps? Prices seem to vary wildly on the 'net.... Sarge Share this post Link to post Share on other sites
pfrederi 20,675 #17 Posted October 1, 2018 4 minutes ago, Sarge said: If you don't mind - what is your source for the US made pumps? Prices seem to vary wildly on the 'net.... Sarge https://www.aircraftspruce.com/catalog/eppages/solidstatepump.php?gclid=EAIaIQobChMI5uyO2qTl3QIVSlgNCh2M1wRKEAQYAyABEgJp2PD_BwE 1 Share this post Link to post Share on other sites
illinilefttackle 399 #18 Posted October 1, 2018 These guys have reliable low pressure pumps. https://www.dbelectrical.com/products/posi-flo-solid-state-fuel-pump-12v-1-2psi-24-min-dry-lift-15-gph-60246n.html Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #19 Posted October 1, 2018 I just purchased my Facit pump from Aircraft Spruce to replace the mechanical pump on my 310-8 .Ordered last Wednesday evening and go it in the mail on Saturday. Made in the USA. I have the same pump on my 416-8 for 3 years with no problems, Share this post Link to post Share on other sites
squonk 46,876 #20 Posted October 1, 2018 8 hours ago, pfrederi said: https://www.aircraftspruce.com/catalog/eppages/solidstatepump.php?gclid=EAIaIQobChMI5uyO2qTl3QIVSlgNCh2M1wRKEAQYAyABEgJp2PD_BwE Those are some good prices for those pumps. 1 Share this post Link to post Share on other sites
Tuneup 1,459 #21 Posted October 3, 2018 You know, gasoline not being a lubricant, maybe adding a little Marvel or even oil/trans fluid to the tank would provide a little added lubrication to the pump for longevity? Just thinking about it - don't know the failure cause. For me, a pump would help on the C125 - I have to shut off the feed valve at the tank or it'll take moons to start. A little circuit and a pump bypass with check valve to give it a 10 second pump shot at start would be nice and would save the pump. You could have a toggle switch just for the pump if you couldn't build the one shot circuit. For those with pumps that are weak but adequate when running. Just thinking on it - nothing better to do at 4:45 AM and my coffee cup's empty. Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #22 Posted October 3, 2018 I picked up the first pump because it too for ever to start the 416-8 , some one ( i forget who ) recommended the Facit pump. I very satisfied with its performance. @WVHillbilly520H recommended the Mr. Gasket pump. I checked pricing and it was around $42.00 plus state tax. I got the Facit pump for $39.40 that included shipping. The new purchase is going on the the 310-8. 1 Share this post Link to post Share on other sites
Sarge 3,471 #23 Posted October 7, 2018 Excellent prices will be putting a couple on the shelf for spares - thanks Paul. Sarge Share this post Link to post Share on other sites
oldlineman 1,735 #24 Posted October 12, 2018 If you dont mind me asking what model # Facit pump did you order Elcamino/wheelhorse? Share this post Link to post Share on other sites
