ronhatch 407 #1 Posted September 21, 2018 (edited) After years of feeling around under my 867 gas tank for the gas shut off valve, I've final decide to do something about it. And yes, I tightened the packing nut to stop it from leaking but then it becomes difficult to turn, so it's time to make life easier. The first step after removing the tank was to unscrew the 51 year old gas valve from the bottom of the tank so I could install a new Facet brand gas filter that has 1/8" NPT on one end and a 1/4" hose barb on the other. From there, a short hose goes to a new flush mounted 1/4 turn gas valve with a nice red handle that is installed under the serial plate on the front panel of the steering tower, and finally the hose follows the right side of the engine to the fuel pump. No more smelly gas fumes and/or fishing around under the tank. The shut off/on handle is right in front of me, PLUS the wife isn't complaining about the gas smell. The total cost was only $15. for the filter, valve and shipping thanks to the reasonable prices at Aircraft Spruce. IMHO, this up grade is a no brainier. Edited September 23, 2018 by ronhatch 6 Share this post Link to post Share on other sites
posifour11 723 #2 Posted September 21, 2018 @ronhatch, this is a very good tip to give folks! Without giving away info about how my brother did his thing, (but, I'm sure it does, anyway.) 1 Share this post Link to post Share on other sites
Tankman 3,523 #3 Posted September 22, 2018 Did you use a 90 degree fitting? Great idea! 1 Share this post Link to post Share on other sites
ebinmaine 74,896 #4 Posted September 22, 2018 I'd love to see pics of the finished job Share this post Link to post Share on other sites
Retired Wrencher 6,098 #5 Posted September 22, 2018 ronhatch Good job. 1 Share this post Link to post Share on other sites
Daron1965 644 #6 Posted September 22, 2018 3 hours ago, Retierd Wrencher said: ronhatch Good job. Share this post Link to post Share on other sites
ronhatch 407 #7 Posted September 22, 2018 (edited) No 90 degree fitting Tankman. The filter comes straight down out of the tank. I like to keep it simple with a minimal amount of fittings and hopefully, less leaks. Edited September 23, 2018 by ronhatch 1 Share this post Link to post Share on other sites
ronhatch 407 #8 Posted September 23, 2018 (edited) The 1/4 turn shut off valve I used for $8.75. It requires a 9/16" hole.And the Facet fuel filter for $4.45. Edited September 23, 2018 by ronhatch 1 Share this post Link to post Share on other sites
