Rich16
Valve Adjust 520h
Rich16
Hi All,
Looked on the site (and YouTube) and can't find anything comprehensive about adjusting valves without taking things apart - most are with engine removed I don't want to do.
Can you adjust the valves with engine on by just taking off the air cleaner unit to expose the valve covers and take the plugs out?
Can Top Dead Center be found without removing anything else or does the flywheel canopy have to be removed?
I've adjusted valves on cars, etc and it's easy and straightforward - but I don't want to have to take anything apart that's unneccesary.
Many thanks!
WVHillbilly520H
Find the Onan engine manual(here in the manuals section) and download it. But usually the intake and exhaust manifolds are removed to make things easier to get to, while you're at might as well pull the heads and decarbon as well @richmondred01, just did one not too long ago I'm sure he can give you better details as I have yet to have my engine apart myself yet in 20 years of ownership.
lynnmor
It is nearly impossible to do a valve adjustment with the intake and exhaust in place.  Even if you could, keeping dirt out of the engine just won't happen.  Like said above, pull the heads to decarbon, then check for loose valve seats, ask me how I know this.  Pull the intake and check the split for possible leakage and check it where the exhaust shield may be cutting into it.  Pull the muffler, glass bead then paint with high temperature paint, these mufflers are expensive to replace.
I go a bit farther and do a valve job and replace the intake valve seal while things are down.  I also open the carburetor, clean it out and adjust the float.
Use genuine Onan gaskets, especially the intake ones as the imported gaskets turn to mush.
Rich16
Appreciate the comments and now I know what I'll be getting into.
Pretty major job and it's running great but has around 650hrs and I know from above what happens if you don't do all of this.
It's kinda crazy but the manual says 'Remove all parts necessary to gain access to valve tappets' - not particularly helpful.
This forum is terrific!
  • Similar Content
    • Chaz54
      By Chaz54
      Full set of NOS Wheel Horse Chrome Embossed Hubcaps for a 520H.
      Let me know if you have questions, need more information, pictures, etc.
      Buyer pays shipping. Located in Washington, MO 63090
    • Gettysburg Axel
      By Gettysburg Axel
      In search of a mule drive for a 60 inch deck for my 520. Located near central Pa or able to ship if possible. Also would be interested in trading parts for the mule drive if wanted.
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
