HorseWhisperer 243 #1 Posted August 31, 2018 Picked this up a couple months ago and was sceptical as I am of most Hydrogear Sunstrands.I have gone through all fluid/filter changes and got to the hydro inspection/tune.No relief spring issues,no broken pawl.This stud will climb a wall.I picked up several cat 0 implements but I just noticed there is no down pressure on this three point.Is there supposed to be?I had a 69 electro that had down pressure.Why wouldn't this beast 3 Share this post Link to post Share on other sites
19richie66 17,892 #2 Posted August 31, 2018 Looks like it would also pull down the wall! Looks like a boss.👍 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,276 #3 Posted August 31, 2018 The option in 1969 was model 5-5411 and know nothing about it. Click on the pictures. Garry 2 Share this post Link to post Share on other sites
HorseWhisperer 243 #4 Posted September 1, 2018 3 hours ago, gwest_ca said: The option in 1969 was model 5-5411 and know nothing about it. Click on the pictures. Garry This was an independent control lever option? Share this post Link to post Share on other sites
KC9KAS 4,746 #5 Posted September 1, 2018 There was another option for the GT-14....a 2nd hydraulic cylinder on the 3 pt lift with a 2nd control valve. This allowed you to have mid AND rear hydraulic lifting capabilities at the same time. 1 Share this post Link to post Share on other sites
HorseWhisperer 243 #6 Posted September 1, 2018 15 minutes ago, KC9KAS said: There was another option for the GT-14....a 2nd hydraulic cylinder on the 3 pt lift with a 2nd control valve. This allowed you to have mid AND rear hydraulic lifting capabilities at the same time. Omg,I dont jow how it would be better 1 Share this post Link to post Share on other sites
953 nut 66,602 #7 Posted September 1, 2018 13 minutes ago, KC9KAS said: There was another option for the GT-14....a 2nd hydraulic cylinder on the 3 pt lift with a 2nd control valve. This allowed you to have mid AND rear hydraulic lifting capabilities at the same time. The unit @HorseWhisperer has here is set up for that type hook up. The cylinder would connect to the two points I have circled in green. 1 2 Share this post Link to post Share on other sites
ztnoo 2,302 #8 Posted September 1, 2018 I don't see the second control valve handle on your machine either....... Cylinder needed is outlined in yellow. 1 1 Share this post Link to post Share on other sites
HorseWhisperer 243 #9 Posted September 1, 2018 1 hour ago, 953 nut said: The unit @HorseWhisperer has here is set up for that type hook up. The cylinder would connect to the two points I have circled in green. Sweet lord you guys are getting good at this technology stuff 🤣🤣🤣 1 Share this post Link to post Share on other sites
HorseWhisperer 243 #10 Posted September 1, 2018 44 minutes ago, ztnoo said: I don't see the second control valve handle on your machine either....... Cylinder needed is outlined in yellow. I thought that was for a 12v actuator option.Now I see the light.I had a commando 8 years ago that had a 12v electric brinley hitch much like that. Share this post Link to post Share on other sites
ztnoo 2,302 #11 Posted September 1, 2018 When you closely examine the file manuals Garry noted, you'll see lots of things I wasn't aware of. I've owned a GT 14 for going on 40 years now, but it was one without a 3 point hitch.....all I have ever done is mow with the tractor. So, the hook up and operational mechanism of how the three point actually functioned was really a mostly mystery to me. Actually it appears like the rear cylinder is an additional option to the first manual cited. What I'm really curious about is the distance range of motion for both set ups......whether they are about the same, or if the rear cylinder option offers more overall motion up and down. Hopefully some owners with these options will chime in on this because I'm very interested to know. Are there any other implements beside a tiller where the downward pressure afforded by the rear cylinder option would prove helpful? 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #12 Posted September 1, 2018 10 hours ago, HorseWhisperer said: Sweet lord you guys are getting good at this technology stuff 🤣🤣🤣 I have a 69 GT-14 that I removed the bar that operates the 3 point lift and installed a 2nd cylinder and control valve. It was VERY tight in the tunnel to get the valve mounted and the hoses connected, but I really like it after I got it done. The original hook-up (WH option) was a shaft running from the outside left hand side of the tunnel to the inside to operate the control valve. The valve handle was mounted on the outside left of the tunnel. I have photos of my set up but are in Photo Bucket, and we all know how that turned out!! 1 Share this post Link to post Share on other sites
HorseWhisperer 243 #13 Posted September 1, 2018 I have a box scraper with adjustable scarifiers,that unit itself doesnt need down pressure but as for the cultivator and york rake well they could use a little help.I have had a c160 for years and I have a 12v linear electric actuator lift on it.It never says no to up or down!lol Share this post Link to post Share on other sites
HorseWhisperer 243 #14 Posted September 1, 2018 I was MIA at work a couple years,what happened to the photobucket goodies KC? Share this post Link to post Share on other sites
KC9KAS 4,746 #15 Posted September 1, 2018 13 minutes ago, HorseWhisperer said: I was MIA at work a couple years,what happened to the photobucket goodies KC? They want to CHARGE us for using OUR photos. Share this post Link to post Share on other sites
ztnoo 2,302 #16 Posted September 1, 2018 3 hours ago, KC9KAS said: 3 hours ago, HorseWhisperer said: I was MIA at work a couple years,what happened to the photobucket goodies KC? They want to CHARGE us for using OUR photos. To the tune of $400 per year, I believe. That's enough to pay for 20 years of Supporter status here at Red Square. And as long as there's a Red Square, every picture posted here, will stay here. Period. _________ @KC9KAS Have you actually tried to access your Photobucket pics? I was able to get into my account within the last ten days or so, and saved everything there to file on an external hard drive, so I at least have all of those pics I stored there over the years. That doesn't help me with sites that require third party hosting, but at least I have everything I originally put on Photobucket. It would be fascinating to know how much they projected they could collect in new revenue with their new rip off program versus what they have actually received in revenue. My guess is its been like pennies on the thousands of dollars. It may have been the lead balloon of the decade. And they made lots of enemies in the process..... Regards, Steve 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #17 Posted September 1, 2018 27 minutes ago, ztnoo said: To the tune of $400 per year, I believe. That's enough to pay for 20 years of Supporter status here at Red Square. And as long as there's a Red Square, every picture posted here, will stay here. Period. _________ @KC9KAS Have you actually tried to access your Photobucket pics? I was able to get into my account within the last ten days or so, and saved everything there to file on an external hard drive, so I at least have all of those pics I stored there over the years. That doesn't help me with sites that require third party hosting, but at least I have everything I originally put on Photobucket. It would be fascinating to know how much they projected they could collect in new revenue with their new rip off program versus what they have actually received in revenue. My guess is its been like pennies on the thousands of dollars. It may have been the lead balloon of the decade. And they made lots of enemies in the process..... Regards, Steve I did recently save info that told me "how" to get my Photo Bucket photos saved elsewhere. Share this post Link to post Share on other sites
HorseWhisperer 243 #18 Posted September 1, 2018 I never used photobucket on here,I think I joined in 08.I always thought it was a little jenky.I didnt trust it for some reason.I was wondering why so many archive photos were unavailable.So anyone that uses photobucket on here lost or cannot retrieve the old photos until the loot is payed? Share this post Link to post Share on other sites
ztnoo 2,302 #19 Posted September 1, 2018 2 hours ago, HorseWhisperer said: So anyone that uses photobucket on here lost or cannot retrieve the old photos until the loot is payed? I didn't pay one red cent. I was simply able to get into my account, and when I could, I copied everything that was there to my outboard hard drive. End of my story and my use of Photobucket. Hasta la vista! 1 Share this post Link to post Share on other sites
