DerrickH
312-8 Headlights
DerrickH
Still learning about my WH 312-8. Where do i start looking to figure out how to get headlights to work without buying new lights right away?
Jerry77
   First, check the fuse...if good..  with the headlight switch on,  jump across the headlight switch. if they don't work, then ohm the headlights themselves..if you get a dead short it is time to check out the wiring...:twocents-02cents:
pfrederi
What is the model number of you 312-8 (Should be on a sticker under the seat.  Some 312-8s had head lights that ran off the AC stator on the engine not the battery,  Those lights would only work when the engine was running.
WHX??
:text-yeahthat:some of my newer verticals are like that. Get us your model and we'll see about getting you a manual/wiring diagram.
While your at the fuses check the socket. often times they get corroded. If you have a multimeter or even a simple tester check for power at the light and work backwards down the wiring to you find 12 volts. If you don't have a simple tester get one.  Handy for other automotive stuff too.
:WRS:
DerrickH
Thanks fellas! model # 3112K804
gwest_ca
Click on the picture
Garry
peter lena
@DerrickH  while I  agree with others on ideas , mine is to move wire connections , like dielectric  grease  to enhance connections , enhance grounding , don,t count on original ground areas , typically rusty / paint / corrosion . like alligator wire clip test wires , to jump over  areas . connected most of my grounding directly to battery ground bolt / cable point . test / check as you go . pete
  • Similar Content
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
    • Aaron Coffman
      By Aaron Coffman
      Hi Red Square Community,
      I am looking into purchasing the below pictured "POND" Walk Away. The unit itself has the cast in “POND” on the chain reduction housing. The two main things I am looking to learn are what value is typical for these to sell for. This one has a Briggs & Stratton model “N” engine. It runs and drives, but the throttle linkage needs some adjusting. It comes with a cultivator and plow implement.
      Secondly, I was wondering if there is any way to determine what year specifically this Pond is from. The seller believes late 1940s and not 1950s. I am new to these machines, so I am looking for some guidance. Thank you in advance!
    • MainelyWheelhorse
      By MainelyWheelhorse
      Hi All, I’m a member of the RedSquare Facebook group, some of you may have seen My tractor there. I have a 1992 312-8 with a 37 inch deck. It came with a house my brother bought, and was given to me. It needed work but just minor things. I mow my lawn with it, and I just bought a plow to push snow/dirt so it’s a working restoration. It was relatively well taken care of by the previous owners so it really just needed a refresh. Anyway see you around the site!
