Dakota 71 #1 Posted July 29, 2018 Does anyone have any info as to what model this blade was designed for or how rare they are? I’ve never seen one like this before. They guy said it raises and lowers by a triangular piece connected to the deck lift lever pushing a brass colored rod to the front pivot point. He said he even has the original owners manual. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,458 #2 Posted July 29, 2018 Looks like this one for the late vertical shaft models Garry 1 Share this post Link to post Share on other sites
Dakota 71 #3 Posted July 29, 2018 @gwest_ca Would it fit my 73’ medium frame? I can get the blade and a set of wheel weights for $90 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,458 #4 Posted July 29, 2018 Not without a lot of fabrication. The late long frame blades for the 300-Series are likely more plentiful. You could always use the weights if they fit your wheels and find a 260 owner wanting the blade. If you do get it study the parts list to make sure you get all the pieces. Trying to find a missing part later may be impossible. Garry 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #5 Posted July 29, 2018 It fits the 26x series lawn tractors, it is basically the same as the "long" frame B,C,3,4$OR500) series blades, I actually converted one like that over to work on said long frame tractors notice how the rear attachment point is different of that of medium or long frame plow frame... Share this post Link to post Share on other sites
953 nut 68,534 #6 Posted July 30, 2018 1 hour ago, Dakota said: blade and a set of wheel weights for $90 Are the rear tires on the seller's 12" like yours or ate they 10"? Share this post Link to post Share on other sites
Dakota 71 #7 Posted July 30, 2018 Thanks for the info everyone! I think I just pass on the blade and find one made for model of tractor since there are a lot for sale around me. @953 nut I believe they are 12”, there are wheel horse brand as well 1 Share this post Link to post Share on other sites
