WVHillbilly520H
Caddilac kind?
posifour11
On 7/29/2018 at 6:22 AM, ebinmaine said:
Some awesome cars there guys!
Jeff I think you could fix that tire but it would take more Gorilla tape than usual.
Like the caddy rims !!
Throw a tube in it. It'll be fine.
  • Haha 3
WVHillbilly520H
Did a little detailing in the engine compartment, after a Purple Power bath and drying I used a product for motorcycles and ATVs called Top Kote to help repel dust/dirt/grime ect, I think it turned out rather well for a 12 year old vehicle (sorry didn't take any before pics) and yes that is a cold air intake on a 4.3 V-6, Jeff.
Edited by WVHillbilly520H
  • Like 4
  • Similar Content
    • Fordiesel69
      By Fordiesel69
      Need a pair or rear rims for 518xi, 520Lxi, 522xi, 523dxi, GT18, GT20, GT22, GTD23D, tractors.  Can take new old stock, nice used, or used that need refurbishing.  Anything will be fine.  Needs to be within 2 hrs of Erie, PA, or shipping available.
      Thank you,
      Mike.
    • MachXXII
      By MachXXII
      I’m trying to restore my grandfathers old 252-H to use around my property. The tires are shot and the rims aren’t too far behind. Anyone have any recommendations for rims and tires that would fit well on it?
      right now it has 22 x 7.50 - 12 on the back and 15 x 6 - 6 on the front.
    • r1jakecfd
      By r1jakecfd
      Hi Guys,
      I just bought some Carlisle Turfmaster 24x12-12 rear tires to replace the 23x8.50-12 tires I have on there now. I was wondering which rims I should buy to fit these bigger tires. The charts say an 8.50 width rim but should the offset stay the same or does it need to change? Any other dimensions I should be concerned about?
      Thanks in advance.
      Hope everyone is healthy and well!
      John
    • Spini
      By Spini
      I'm thinking about going with 7.50 tires on the front with the 8" stock rims.  I mow in a wet area and am thinking if I increase the surface area, I'll be less likely to sink.  I already went wider in the rear, which seems to work well.  I'm also running lower pressures all around.
      My main concern is if the slightly wider tires will clear the mower deck when I make tight turns.  As it is, the 6.50 clears only by about an inch.
      I'd like to go with the 7.50 Carlisle Turf Masters, the mounted width is 7".  Currently I am running the stock tires, which are Turf Savers, and according to Carlisle, the mounted width is 6.6".
      I guess if that's the case, it may not make much difference in surface area, and I would be risking rubbing the tires on the deck.  I have a 42" deck.
      If anyone is using (or knows for sure if) 7.50 Turf Masters on an 8" wheel with a 42" deck on a 416-8, please let me know how well it works.  Obviously
      I can't risk "tire rub".
      I also welcome any other suggestions for mowing wet ground.  Thanks in advance.
    • porschpow
      By porschpow
      Good Morning everybody!
      I am in the process of sharpening the blades for my mowing deck (Model 78360 - Serial 7904987) and I noticed that the deck has a crack in it right where the bracket to the mounting hardware (to the tractor) is. SO I know I have to get that repaired.
      But while I was at this, I thought I could do a good quick once over on the deck to make sure I am ready for the season.
      What I would like to do is the following:
      Change the bearings for the spindles (or pack them with more grease)
      Get new rear tires (since they squeak)
      And that's about it
      If anyone here thinks I should do anything else, I would love to hear it!
      Where does everyone get the hardware (bearings, wheels for these rebuilds?)
