old5foot
Tires & Rims on a 312-8, Kenda Terra 502
old5foot
Anybody had any success mounting Kenda Terra 502 tires on 7.5 x 12 Wheel Horse rims?
Kenda says the tire needs a 8.5 x 12 rim. They spec. out as 23 x 10.5 x 12.
My 318 rims measure 7.5" from inside of bead to inside of bead. So they just might work.
Reason for all this being I have some steep slopes down to the lake.  Yard has a toboggan run slope, a couple of  8 - 10 foot drops with flat areas in between.
Total drop of about 20 feet in about 100 feet. Plus the soil is Michigan sand.  Grass is thin and the old original Carlisles just aren't cutting it anymore.
Looking for a more agressive tire for turf.  Have read some goon reviews of the 502's on this forum.  But not much detail on the rims they were mounted on.
Any experiences good or bad would be appreciated.
Thanks
Old 5 Foot
RandyLittrell
They will work on the narrow rims, but will be a little more rounded and a greater tendency to roll over. They would be better on a wider wheel, but I would do it if I didn't have access to wider wheels.
Randy
bmsgaffer
I mounted them on the wider wheel of the 522xi. They are awesome! Just go up and down the slopes unless you have plenty of weight. If you lighten up and spin on one wheel it will dig a hole pretty quick.
I think you will technically have better traction if you find a wider wheel as they will stay pretty flat. If you look for rims from any XI seriels, 1991+ 520H, 1988+ 520HC, 418C, and a few other misfits it should be the wider 8.5" rims.
However, other than fender clearance I cant see why it would not work.
  • Similar Content
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      Two 3 Rib Firestone Tires, 16x6.50-8, 2 of them mounted on OEM Wheel Horse Rims, NEW!
      These tires are New, Never Used! Not the cheap China ones, these are High Quality Firestone Tires!
      Great for any Garden Tractor or Riding Mower
      They are mounted on original Wheel Horse wheels that have been sandblasted & epoxied, and painted with ivory colored paint, note there are a few chips along the inside bead from mounting the tires. The rims will need your specific size wheel bearings installed.
      $99.00 Call Tim @ 1-313-460-8858        (Local Pick-Up Only, No Shipping)
    • MainelyWheelhorse
      By MainelyWheelhorse
      Hi All, I’m a member of the RedSquare Facebook group, some of you may have seen My tractor there. I have a 1992 312-8 with a 37 inch deck. It came with a house my brother bought, and was given to me. It needed work but just minor things. I mow my lawn with it, and I just bought a plow to push snow/dirt so it’s a working restoration. It was relatively well taken care of by the previous owners so it really just needed a refresh. Anyway see you around the site!
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
