ebinmaine 79,742 #1 Posted July 23, 2018 This might sound like a bit of an odd question but... what brings it up is that when I started the Briggs engine that I'm installing on my honey's 657, the exhaust started to fall when the engine got hot. This would be because the aluminum expanded at a far greater rate than the steel that the pipe is made out of and simply became loose. I do understand that. What I am wondering is - is there such a thing as turning that npt threaded muffler pipe in... Too far?? I am going to make up some kind of a flat steel bracket to support the pipe at a 90 degree angle. I just want to make sure that it is as tight as it should be. Share this post Link to post Share on other sites
KC9KAS 4,746 #2 Posted July 23, 2018 I have seen many a muffler pipes being held tight with a conduit nut. 2 2 1 Share this post Link to post Share on other sites
wallfish 20,237 #3 Posted July 23, 2018 Too tight and it can certainly crack that aluminum block. Get your self a "nut" and cinch the pipe. Also couldn't hurt to support it as well 1 2 1 Share this post Link to post Share on other sites
ebinmaine 79,742 #4 Posted July 23, 2018 Just now, KC9KAS said: I have seen many a muffler pipes being held tight with a conduit nut. I thought that would work too so I did put one on. Thing is, the direction of loosening is also the direction that is in favor of gravity. So when the motor got hot, the muffler just started to fall. 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #5 Posted July 23, 2018 2 minutes ago, ebinmaine said: I thought that would work too so I did put one on. Thing is, the direction of loosening is also the direction that is in favor of gravity. So when the motor got hot, the muffler just started to fall. Then a bracket is probably your best bet! We have to be fabricators sometimes to keep these horses alive and kicking! 5 Share this post Link to post Share on other sites
wallfish 20,237 #6 Posted July 23, 2018 Check out some pics of the older horses with Techy engines. Like a 654. Those aluminum block engines used an exhaust support from the factory. 3 1 Share this post Link to post Share on other sites
ebinmaine 79,742 #7 Posted July 23, 2018 5 minutes ago, wallfish said: Check out some pics of the older horses with Techy engines. Like a 654. Those aluminum block engines used an exhaust support from the factory. Ahhh... So my idea might even work!!! 2 Share this post Link to post Share on other sites
Machineguy 877 #8 Posted July 23, 2018 If you have room on the block at the exhaust port. You may be able to drill and tap a small grub screw hole to jam lock the conduit nut after it’s tightened. An 8-32 set screw with high temp copper anti-seize on it would allow it to be removed later. That would stop the rotation after it’s hot. For sure though, a tapered pipe thread on a steel pipe can definitely strip and or fracture aluminum blocks. 2 1 Share this post Link to post Share on other sites
WHNJ701 4,173 #9 Posted July 24, 2018 time for a big ,giant, chrome stack with a flapper 2 Share this post Link to post Share on other sites
ebinmaine 79,742 #10 Posted July 24, 2018 20 minutes ago, jabelman said: time for a big ,giant, chrome stack with a flapper ~I~ agree... But it's my honey's tractor.... Share this post Link to post Share on other sites
Machineguy 877 #11 Posted July 24, 2018 (edited) @953 nut Basically I was talking about putting a small screw tight against the conduit nut after it’s tightened flush to the block. Basically the little dot I crudely added to the pic is where a small set/grub screw could go in jamming the nut. Provided there’s enough room on the block. I hope that helps clear up my jibberish! Lol Edited July 24, 2018 by Machineguy 1 Share this post Link to post Share on other sites
ebinmaine 79,742 #12 Posted July 24, 2018 7 hours ago, jabelman said: time for a big ,giant, chrome stack with a flapper I'll try to remember to take a pic of the piece of chrome pipe I found at the recycling center. No idea what it was in it's useful life. Got weird fluted ends... When I saw it, exhaust stack was the first thing I thought of so I grabbed it. 2 Share this post Link to post Share on other sites
Pullstart 70,793 #13 Posted July 24, 2018 17 hours ago, ebinmaine said: I thought that would work too so I did put one on. Thing is, the direction of loosening is also the direction that is in favor of gravity. So when the motor got hot, the muffler just started to fall. Sometimes exhaust manifold gasket instructions and other high-heat items say to tighten, then bring up to operating temp, then tighten. I wonder if that conduit nut could get any more snug when it’s all good and hot? 1 Share this post Link to post Share on other sites
ebinmaine 79,742 #14 Posted July 24, 2018 3 minutes ago, pullstart said: Sometimes exhaust manifold gasket instructions and other high-heat items say to tighten, then bring up to operating temp, then tighten. I wonder if that conduit nut could get any more snug when it’s all good and hot? That's true that's true. 4 foot extension pipe should make that thing tight enough. 2 Share this post Link to post Share on other sites
