JayB 5 #1 Posted July 19, 2018 Can a sickle bar modle SMS50 fit a tractor modle C-160 or a Tach A Matic Share this post Link to post Share on other sites
953 nut 63,556 #2 Posted July 19, 2018 The frame on the 953/1054 is wider than the frame on your C-160, may need to compensate for that. You would probably need to remove the Tach-A-Matic and will need to drill a few new holes but it is a belt driven implement so with a bit of ingenuity it can be done. 1 Share this post Link to post Share on other sites
martinarcher 59 #3 Posted July 20, 2018 Thanks 953 nut. Jay has an SMS-50 and I have the C-160. We're trying to figure out what it will take to get the sickle running on my C-160. My concern now that I've studied more pictures is my brake pedal is on the right (clutch left) so I'm concerned the pulley idler pedal and the brake will be trying to occupy the same space. If I can get the actual hardware to mount up and clear the brake pedal itself throughout it's throw I think I can just skip the idler pedal and use the standard PTO lever on the C-160 to engage the sickle and just run a belt direct to the mule pulley from the PTO pulley (eliminating the pedal and pedal pulley. Anyone done anything like that? I found a YouTube vid of a guy hedge trimming with a C-160 and a sickle but it's a view from his fender as he's cutting. No picks of the set-up at all. Thanks all! Share this post Link to post Share on other sites
953 nut 63,556 #4 Posted July 20, 2018 You will need a method of tensioning the belt from the PTO. Share this post Link to post Share on other sites
martinarcher 59 #5 Posted July 20, 2018 I'm wondering if the box I make for the frame could be slotted and able to "slide" tension the belt. It's too bad I can't somehow incorporate the mule drive tensioner on the front. It works so slick. Share this post Link to post Share on other sites
953 nut 63,556 #6 Posted July 20, 2018 Here is one from our Gallery that uses a tensioner that pivots forward. Looks good to me. 3 Share this post Link to post Share on other sites
martinarcher 59 #7 Posted July 20, 2018 Thanks for the pic! That one looks very well implemented. 1 Share this post Link to post Share on other sites
martinarcher 59 #8 Posted July 21, 2018 Is that your Horse 953nut? Share this post Link to post Share on other sites
953 nut 63,556 #9 Posted July 22, 2018 22 hours ago, martinarcher said: Is that your Horse 953nut? No! I found the photo in our gallery. It belongs to @Stormin. http://www.wheelhorseforum.com/gallery/category/3-mower-decks/ Share this post Link to post Share on other sites
Stormin 9,987 #10 Posted July 22, 2018 That's my '79 C-81 with a '62 sickle bar. There was no mule drive with it when I got it and would have been of no use if there had. Foot rests on the tractors it was designed for and foot plates on the C-81. Don't know how to add links, but if you go on our sister site, myoldmachine (top of page) you'll find my topic on the rebuild and fitting. Wheel Horse Sickle Bar. October 2015. Maybe give you some ideas. Norm. Share this post Link to post Share on other sites
953 nut 63,556 #11 Posted July 22, 2018 4 hours ago, Stormin said: Don't know how to add links, but if you go on our sister site, myoldmachine (top of page) you'll find my topic on the rebuild and fitting. Wheel Horse Sickle Bar. October 2015. Maybe give you some ideas. Here you go Norm, thanks for passing this on to us. http://myoldmachine.com/topic/2361-wheel-horse-sickle-bar/?tab=comments#comment-26123 1 Share this post Link to post Share on other sites
martinarcher 59 #12 Posted July 23, 2018 You guys rock! Thanks for the pics and the thread link. That will be a huge help getting my C-160 set-up. I really appreciate it. 1 Share this post Link to post Share on other sites
IndyFord2 51 #13 Posted July 29, 2018 I just posted some pis'c in the gallery for another "horse lover" I mounted a sickle bar on my C-120. (Sat.) Might help a bit. 1 Share this post Link to post Share on other sites
martinarcher 59 #14 Posted July 30, 2018 Thanks! Are they in the implements section or the regular section? Share this post Link to post Share on other sites
IndyFord2 51 #15 Posted August 1, 2018 picture gallery, implements 1 Share this post Link to post Share on other sites
