Machineguy
69 Workhorse K321 engine swap
Machineguy
Hello everyone!
I finally picked up a Workhorse 700 and I’m doing a restoration with the exception of a Kohler K321 in place of the scavenged Tecumseh. Anyone done a similar swap and had trans issues or breakage problems? This isn’t going to be a puller, just gonna keep a 42” snow blade on it  for small snows and use it for light duty towing and putting around. I have the engine sitting around from another repower project and I have access to a large variety of machine tools and fabricating equipment. Any thoughts?
Edited by Machineguy
953 nut
:WRS:         There should be no problem as far as the transmission goes, they were the same regardless of Horsepower. As you will probably be going from a magneto ignition to the battery powered the wiring will need to be changed. This thread will show you what is the same and what needs to be changed.
Machineguy
Thanks man!
You're correct about changing up for the battery powered ignition vs the magneto. I appreciate the info on the abilities of the trans too. I've got a good K301 if the rears in these were a little weak. But my 14hp has fewer hours on it and I thought since there's no hi/low range I might want that extra torque. My Grandad had an old Wheelhorse that slipped away from me before I was enough to do anything about it.  I just got started collecting little tractors and I'm up to 7 and I'm pumped about this one!
Thank you you for your service in our Military and for taking time to share a little knowledge with me!
Mike'sHorseBarn
If you put on a K321, I'm not sure the hood will fit back on. You might want to check that out. A k321 on a short frame should look pretty awesome though!
Mike
Machineguy
There’s a pic of the 700 and a Sears that I literally pulled from a scrap pile. I hate seeing solid, serviceable American Steel go to scrap! I consider these equipment, not appliances to be tossed out in 5 years like modern mowers
  • Like 7
Machineguy
Mike
I need to go measure that for sure. I think the Kohler is somewhere around 17” tall?
Mike'sHorseBarn
It's a shame someone would scrap things like that. Nothing wrong with that 700. Looks a like a good one to get going again.
I also can't believe that someone would scrap a sickle bar mower of any brand away!
The think the k321 will be too tall and too wide for the hood. You might have to find an 7 or 8hp kohler if you want the hood back on without being cut up.
Machineguy
Yeah, nothing set in stone yet. I’ll mock it up and see what’ll work without any hacking. About the only thing I’ve decided I’d modify sheet metal wise is the drive belt cover.
I’m glad I saved the Sears too. The sickle bar was frozen, tie rods broken thanks to being dropped by a loader. The loader picked it up by the steering wheel. People are so conditioned to think that hard work and effort is for fools. So most just scrap stuff and go finance new stuff.
  • Sad 1
Machineguy
I know it’s not a WH but after a couple weeks of wrenching and rewiring for a modern ignition switch and solenoid. You’ll be happy to know I got the sickle bar freed up and the HH120 running again.
That’s the short story skipping all the headaches! Lol
  • Excellent 4
Mike'sHorseBarn
And to think someone was just willing to melt it down. Great work!!
The Tuul Crib
That steering wheel on that suburban looks like someone hooked a change to it! Still a nice find!
  • Haha 1
Machineguy
It was actually picked up with a tooth on a loader bucket! Steering wheels don’t fare well holding up the weight of tractor and sickle bar!! lol
The Tuul Crib
Yep there ya go! Shows you how well built
things were back then!
The Tuul Crib
 You might be able to use that kohler  if you get the gas tank to go where it supposed to go.
R. L. Addison
K321as would probably fit. If I remember right, about 2" lower than K3212s.
Machineguy
The engines I do machine work on at my day job aren’t as easy to move around. That’s 8,000lbs of CAT 3520
  • Excellent 3
The Tuul Crib
Think I can fit that one on my 665!! Lol
very impressive!👍
  • Haha 1
Machineguy
very impressive!👍
Thanks man. I started machining stuff in high school for a 455 swap in my G-body Buick and I’ve made a career out of it.
Machineguy
Got the engine pulled last night and sheet metal. Gave it a good pressure washing too.
Tonight it’s dry fitting the Kohler and figuring what I’ve gotta move around to make it all look like it belongs there. This should be a fun little thing with either a small snowblower or blade. 1CFFDF6E-D825-4761-B243-44101EC95830.jpeg.09cfacb43ad679c134da4b144e07b7c4.jpeg
elcamino/wheelhorse
Looking good. You may want to move that Green Thing , horses have been know to kick them .:ROTF:
  • Haha 3
Machineguy
That’s supposed to be the wife’s mower. That’s why it’s sitting in the corner with the battery out of it and in one of my toys!
I put the bagger on it and pick up leaves in the fall. Works good for that!
  • Haha 2
dells68
I hate to admit it, but I'm digging that Sears!  Never cared for them, but with sickle bar attached it's mean looking😎!
Machineguy
Thanks! It was an unplanned purchase and project that I’m glad I got. Absolutely worth keeping out of the scrap yard for sure!
Machineguy
@dells68
Suburbans are rebranded Ropers. No family connection to the brand for me but the guy truly made me an offer I couldn’t refuse.
At that moment I understood how my wife feels at a two pairs for the price of one shoe sale!!! :ROTF:
  • Haha 5
  • Similar Content
    • Rob R
      By Rob R
      Hi Guys, got a K321 14HP Kohler in house with all the electrical components removed. I cleaned and aligned the points, added a 12v (resistor coil) positive 12V battery feed to positive terminal, ran a line from the negative side of the coil to the points. I know I have to add a condenser also to the negative side. My question is does location of the condenser matter i.e. next to the coil or is closer to the points better. Thanks Rob
    • Kyle G Cantrell
      By Kyle G Cantrell
      Trying to restore a 1971 Wheel horse Workhorse 800 model 0100, It has a tecumseh HH80-110112D.
      I cannot find any parts at all for this one, I’ve checked everywhere I can think online. This is my first restore, looking for some help to find parts or what I can use (swap) to keep it close to original but also functional.
      Also the fly wheel has two **** that stick up off it that the coil passes and one is broke off. Is that a problem, I’m a mechanic but this thing is old and with no info it’s a guessing game.
      Parts needed so far:
       right side running bored/footrest
      Left side engine cover
      right side pulley cover
      Ignition coil
      Main drive pulley bearings
      Hitch pin (goes through trans case)
      *NEW TO SITE, WILL CHANGE IF POST INCORRECT*
    • drewd
      By drewd
      I need to buy tubes or new rear tires for my 1971 Workhorse 800.  It has the original 22.5x7.50-12 Wheelhorse branded tires but sidewalls are leaking and one no longer holds air for more that two days.  Searching websites brings up various sizes but not the original.  Would a 23x9.50-12 fit this tractor?  I have a 36" RD deck on it.  Any other sizes work on this rim and tractor?
      Thanks!
    • kdeatrick
      By kdeatrick
      Well, I did another Work Horse over. This one I will use weekly at my Rental property. This started out as repairing the shifting linkage and brakes. While waiting on parts, I degreased it and thought, I might as well touch up the frame paint on the frame. Then I took the sheet metal off and bead blasted it. It now has base coat clear coat paint. All tires are used and in good shape for now. I chose not to fill in the rust pitting with body filler since it is going to be used and didn't want to get more time and money into it. So it has character, looks decent and will continue to work.
    • felker13
      By felker13
      I am very new to finding old tractors so I am not 100% sure if I got a deal or not. Today at an estate sale I was able to pick up a Work Horse GT-1100 for $65. It needs a lot of clean up, and as of right now I am not 100% sure of the working condition. It did come with the snow thrower attachment, and even though it isn't pictured, I also got the mowing deck as well. Not sure what these are worth, but any info would be much appreciated! I have attached some photo in its current condition.  Thanks!
