Pullstart
Shop project...
Pullstart
The cam is in.  I’m soaking the lifters in fresh 5W30 Mobil1 Synthetic oil before I drop them in.
The clear-ish plastic bottle allows me to monitor the bubble action.  No more bubbles = saturated (primed) lifters.
  • Like 4
Pullstart
Edited by Pullstart
ebinmaine
Lifters get coated in any assembly lube or just the oil?
Pullstart
The cam was granted plenty of lube for dry start.  I’ll probably drop the lifters in as is, then dab some assembly lube on the tips of the push rods too.  Overkill likely, but worth not having to open it back up!  When I set the cam timing (which the gear was right on the money in the chain first try!) I spun the engine over a good handful of times cleaning any grime from the rings from cleaning the deck surface and also checked the timing marks every other revolution.
Pullstart
Heads are torqued.  Push rods and lifters are going back in.  Speed square was used for the torque to yield fasteners.  22 lb ft is the only torque number for the head bolts… then it’s two rounds of spinning them a certain degree.
  • Like 3
Pullstart
The top end is reassembled.  The intake had a TON of oil in it.  I should check the air filter, I wonder if there’s a severe blockage.  I need a longer bolt to re-install the harmonic balancer, need to put the front cover, water pump and front accessories back on, fix some broken studs on the down pipes then install the exhaust manifolds, install the coil packs and install the cooling system.  Then fresh oil, then break in the cam, then change the oil.  Wow, I thought I was getting close to the end but now it sounds like it’ll be a while!
Pullstart
Looking more like a runner!
I’m not looking forward to getting the loose stripped driver’s side manifold nuts and studs apart… but I have new hardware to go in.
Pullstart
That wasn’t as terrible as I figured!  :banana-wrench:
  • Like 3
Pullstart
It’s very difficult to see the cam and crankshaft timing marks while the engine is in the vehicle.  I made an executive decision that it was in time using points of reference on the block for the crank marks and cam marks… along with using cylinder one and six as a tdc reference.  It seemed that the cam marks hit the crank marks just barely after tdc, as to not allow pre-detonation.  I put the truck mostly together but didn’t put coolant in.  It runs!
  • Excellent 3
Pullstart
We’ve got 3 gallons in the rad, time to bring it up to temp, check coolant level and run around 2k rpms for 20 minutes or so to break in the cam.
  • Excellent 1
Pullstart
8ntruck
1 hour ago, Pullstart said:
Was the new cam a stock replacement, or a 'specialized/improved' cam?
Edited by 8ntruck
Pullstart
Stocker.  This is a “budget” repair though I cut no corners…. there wasn’t funds available to upgrade or tune.  We agreed that the stock one lasted 216,000 miles.  If the truck makes it to 400k it’ll be a miracle anyway.
Pullstart
I ran it a few miles and changed the oil again.  We’re all good now!
  • Excellent 2
Handy Don
Good plan comes together.
About how many hours did it take you vs. the rate book?
Pullstart
I did a quick search and cam/lifters is quoted 20-21 hrs.  First time and it took me 26.  I charge less than most shops because my overhead is much less, so the extra 5 hours is still a huge savings for the customer.  They purchased the majority of the materials (so they could put it on their card) and my bill will be around the quote for diagnosis alone.
  • Thanks 2
Pullstart
Here we are with the 2010 3500HD Chevy.  No idea what the dude did, I’ve never heard an engine knock this bad without extra vents in the block!
Pullstart
The cab is off, almost time to pull an engine.
Pullstart
Accessories are off the front.  I need to pull the torque converter bolts, engine mounts and bellhousing bolts and it should pluck right out.
Pullstart
Broken crankshaft.  Unreal.
  • Sad 1
953 nut
58 minutes ago, Pullstart said:
Broken crankshaft.
:confusion-confused:           That would explain the knock!     :angry-tappingfoot:    But how did manage to bust up the balancer end of the crank.     :confusion-scratchheadyellow:     Guess it dosent take too many folks like this to keep your shop going.
  • Haha 1
Pullstart
I found a few images of the cranks in this era LMM engine twisting.  2” or so main journal and all that metal has to go some place.  I’m guessing the snap is not perfectly flush.
953 nut
Strange  that this seems to be bit more common than you would think.
The crankshaft usually breaks near the number one rod journal due to a combination of excessive rpm and the large external counterweight. A factory firing order that beats up the front area of the crankshaft has also been blamed for imposing undue stress on the crank.
Will you be rebuilding this engine or just replacing it with a short block?
https://www.drivingline.com/articles/5-fatal-flaws-of-the-duramax-and-how-to-fix-them/
Pullstart
@953 nut I’m not sure what to think about that link… I just hope Norman isn’t a hypochondriac and starts feeling like a broken crank!  :lol:
  • Haha 4
Pullstart
I got out in the shop for a couple hours this morning and finished pulling the 2010 Duramax engine.  This truck is used all summer long for pulling a heavy trailer and skid steer for the guy’s excavation company.  After reading @953 nut’s link about the 5 plagues of a Duramax engine, I got to wondering what happened to pop this crank.  Well, pulling the engine and not needing to loosen motor mount bolts, that kind of explains it!  Both mounts were torn all the way through.  Bad mounts can cause all kinds of funky movements, along with irregular harmonics.  I had a bad transmission mount kill a flex plate in my old plow truck.
On the other hand, I noticed that this owner was moments away from catalytic converter theft!  The pipe is cut most of the way through on the front and back sides of the converter!
  • Thanks 1
  • Confused 1
  • Similar Content
    • DennisThornton
      By DennisThornton
      1947 Empire (Jeep) Tractor
      The Empire tractor consisted of military power components from World War II-era jeeps. It had a 4-cylinder, 40 hp Willys-Overland engine, a Model T-84 Spicer 3-speed transmission, Spicer transfer case with high and low speeds, Willys rear end, steering column and gearbox. It also had PTO, individual clutch-type rear brakes with a stop provided for parking and a rear belt pulley. The fuel tank and an Empire-style seat were mounted on a large operator's platform (made from Navy ship decking). Its simple, basic gauges (ammeter, oil pressure and temperature), ignition switch and starter button also came from the jeep. The Empire tractor was originally made for exportation in the Lend-Lease Program after World War II.
      If I had to mention a couple of things that made the Empire Tractor really unique, one would be the straight bar hitch that pulled from under the center of the tractor (patented) thus making an overturn nearly impossible. The other selling point was, of course, the Willys engine and drive train made famous in the Jeep during World War II. The Empire was a well equipped tractor, very reliable and versatile with its wide range of speeds. Today this tractor draws a lot of attention at shows and is very sought after by collectors commanding higher than average prices.
      $5k
    • CRE1992
      By CRE1992
      Well fellas I decided to buy a jeep wrangler as a new toy. I have always been into the off-roading scene since I was a kid. I always loved trucks, jeeps, atvs. Recently a friend of mine traded his mustang for a lifted wrangler and its a blast to go off-roading in or wheeling as they like to put it.
      I couldn't help myself and wanted to join in so I bought a 1993 with 153,000 miles on it with a ton of add ons for a great price. It has a 5.5" suspension lift, a 2' body lift and rides on 35" tires. She has 4.56 gears which are awesome for crawling, 4wd low range and 1st gear and you don't even have to touch the gas pedal. It is a 4.0L 6 cylinder engine back by a 5 speed manual trans. The rear drive shaft is a custom cv drive shaft with a slip yoke eliminator. The rear axle is a ford 8.8 limited slip with disc brakes out of a ford explorer. The frame is perfect not a spec of rust and was coated with POR-15.
      She does have her fair share of issues but I am working on getting those straightened out! I just had the front drive shaft rebuilt and balanced. I ordered all new extremely heavy duty shocks. I need to fabricate 2 custom rear shock mounts as the "custom" ones that were on it broke off lol. She needs 2 new leaf spring packs in the rear. Some body work. A good cleaning after this weekend. Some fender flares. Etc!
      If anyone has any good oh crap off-roading or wheeling stories with their jeeps or pictures please share. After this past Sundays experience I could probably top them lol.
      I hope you enjoy the pics and the video my jeep was the main attraction. (I did not edit the video a friend did, so turn down the volume or the music might scare you)
      LINK FOR VIDEO: http://s1201.photobucket.com/user/silveradostud/media/Jeep%20Fun/IMG_31371_zps0e82da88.mp4.html
