Pullstart
Shop project...
SylvanLakeWH
19 minutes ago, ebinmaine said:
How do you get the parts you need? Easy to find?
Have you seen his parts "inventory"? :scared-eek:
Easy to find? Well... just past Colleen, take a left, under the stock car and over the... :eusa-think:
  • Haha 3
ebinmaine
Accurate
adsm08
On 9/10/2026 at 3:58 PM, Pullstart said:
Got a call about an hour ago.  Little girl in tears.  “Daddy I did something really bad!”  “Are you ok?” Was my response.  She’s fine, we’re on the way.
It hasn’t been running amazing, and has stalled a few times still.  It stalled in the intersection, she maybe panicked, the transmission snapped something inside.  We’ll be looking at a 5 speed swap soon… :lol:
Wait, did she break the S-10, or did the 10L80 fail?
Pullstart
The S10 broke, it has a $75 junk yard 700R4 in it.  I’m guessing output shaft broke, it has 6 neutral positions and no park, forward, or reverse.  :lol:
  • Sad 1
adsm08
Yup, something broke between the park gear and the wheels. Time for a turbo 350.
Pullstart
NV3500.  B)
Pullstart
 We found the pedal assembly we need, on eBay.  That deal is complete, we are just waiting on shipping.  It’ll be time soon to pull the trans, and swap the flexplate out for a flywheel.  B)
adsm08
11 hours ago, Pullstart said:
NV3500.  B)
4R100.
  • Confused 1
CRF857
Muncie 4 speed
Hurst shifter with an 8 ball knob
12 bolt or Ford 9” axle
M/H cheater slicks
Crager SS wheels, or chrome reverse with baby moons.
Dual exhaust with Hush Thrush mufflers
and don’t forget the fuzzy dice.
adsm08
34 minutes ago, CRF857 said:
Ford 9” axle
The 9-inch is not actually the strongest medium duty axle Ford ever put out. The 8.8 is better in most applications, stronger, and more versatile.
The 9-inch got it's reputation because it's a 3rd member design that allows for swapping gear ratios in minutes by having several 3rd members set up and ready to go.
CRF857
Had  3.25, 3.50, and 3.73.
ran the 3.73 behind a 4 speed. When I went to an automatic I switched to a 3.25.
Pullstart
Good news / bad news?
We already bought the pedal assembly… so there’s that.
I pushed the truck inside today and looked underneath.  Tires roll, driveshaft doesn’t spin.  Rear end issue, not trans.  We’ll probably go through with the trans swap anyway, we’ve thought about that for a long time.
adsm08
8.8 swap.
ebinmaine
2 hours ago, adsm08 said:
8.8 swap.
Go big. 10.25 Ford/Sterling axle. :lol:
  • Haha 1
adsm08
It would never break under an S-10, but it is a good bit wider. The 8.8 can be had in S-10 is width with the same 31-spline components an f-150 got.
Pullstart
13 hours ago, adsm08 said:
8.8 swap.
Is the plan.   We have a very extensive you pull it yard nearby.  I am hoping to find a 3.08:1 or 3.27:1 ratio and gov lock would be even better!
The S10 has(had) a 3.73:1 ring and pinion, 3.06:1 first gear, and .70:1 overdrive.
The NV3500 has a 4:02:1 first and .73:1 OD.  A higher ring and pinion would put acceleration right in the same spot, but improve OD cruising speeds by up to 16%.  Nerd math B)
adsm08
@Pullstart
I would limit the search to Explorers. All Explorers got the 31-spline axles, and the set up and dimensions are going to be really close for an S10. This does however mean you are unlikely to find 3.27 or 3.08 gears. They were used but mostly in F150 or 2wd, 4.0 equipped Rangers.
Rangers almost universally got 27 spline axles.
I used to have a Ranger 3.27 axle, but I got rid of it years ago.
Pullstart
7 hours ago, adsm08 said:
@Pullstart
Good stuff to know!
So that gives me 5 options still…
Red is optimal, yellow acceptable.
Edited by Pullstart
adsm08
Good stuff to know!
If you really want to have some fun with this project, while you are out there look for an FX4 Level II Ranger and grab the carrier out of it.
If it hasn't been molested it will be a Torsen limited slip unit.
If you can't find an LSD I think I have a clutch style carrier I'll let you have. But I have to find it.
Edited by adsm08
Pullstart
Part 4 of the video series…
Pullstart
Just a few progress pictures on the truck…
  • Sad 2
953 nut
I see an A-60 :scared-shocked: in the background, are you keeping it or just holding it for Uncle Jim?
Pullstart
It’ll deliver to WI soon.  :handgestures-thumbupright:
  • Heart 1
adsm08
Yikes and Yikes!
That pinion needs a pinion, and that underside needs an e-tank.
Pullstart
50 minutes ago, adsm08 said:
Yikes and Yikes!
e-tank?  Luckily it’s surface rust… mostly.  Some of the sheet metal is soft underneath, but the frame is solid.  I know it’s all relative, but remember a few years back I scrapped a ‘99 Silverado with 92k miles because the frame was junk.  I’m happy with this, and aware of what bad is..
  • Similar Content
    • DennisThornton
      By DennisThornton
      1947 Empire (Jeep) Tractor
      The Empire tractor consisted of military power components from World War II-era jeeps. It had a 4-cylinder, 40 hp Willys-Overland engine, a Model T-84 Spicer 3-speed transmission, Spicer transfer case with high and low speeds, Willys rear end, steering column and gearbox. It also had PTO, individual clutch-type rear brakes with a stop provided for parking and a rear belt pulley. The fuel tank and an Empire-style seat were mounted on a large operator's platform (made from Navy ship decking). Its simple, basic gauges (ammeter, oil pressure and temperature), ignition switch and starter button also came from the jeep. The Empire tractor was originally made for exportation in the Lend-Lease Program after World War II.
      If I had to mention a couple of things that made the Empire Tractor really unique, one would be the straight bar hitch that pulled from under the center of the tractor (patented) thus making an overturn nearly impossible. The other selling point was, of course, the Willys engine and drive train made famous in the Jeep during World War II. The Empire was a well equipped tractor, very reliable and versatile with its wide range of speeds. Today this tractor draws a lot of attention at shows and is very sought after by collectors commanding higher than average prices.
      $5k
    • CRE1992
      By CRE1992
      Well fellas I decided to buy a jeep wrangler as a new toy. I have always been into the off-roading scene since I was a kid. I always loved trucks, jeeps, atvs. Recently a friend of mine traded his mustang for a lifted wrangler and its a blast to go off-roading in or wheeling as they like to put it.
      I couldn't help myself and wanted to join in so I bought a 1993 with 153,000 miles on it with a ton of add ons for a great price. It has a 5.5" suspension lift, a 2' body lift and rides on 35" tires. She has 4.56 gears which are awesome for crawling, 4wd low range and 1st gear and you don't even have to touch the gas pedal. It is a 4.0L 6 cylinder engine back by a 5 speed manual trans. The rear drive shaft is a custom cv drive shaft with a slip yoke eliminator. The rear axle is a ford 8.8 limited slip with disc brakes out of a ford explorer. The frame is perfect not a spec of rust and was coated with POR-15.
      She does have her fair share of issues but I am working on getting those straightened out! I just had the front drive shaft rebuilt and balanced. I ordered all new extremely heavy duty shocks. I need to fabricate 2 custom rear shock mounts as the "custom" ones that were on it broke off lol. She needs 2 new leaf spring packs in the rear. Some body work. A good cleaning after this weekend. Some fender flares. Etc!
      If anyone has any good oh crap off-roading or wheeling stories with their jeeps or pictures please share. After this past Sundays experience I could probably top them lol.
      I hope you enjoy the pics and the video my jeep was the main attraction. (I did not edit the video a friend did, so turn down the volume or the music might scare you)
      LINK FOR VIDEO: http://s1201.photobucket.com/user/silveradostud/media/Jeep%20Fun/IMG_31371_zps0e82da88.mp4.html
