Anvil
Speed of blade set on a 48" deck
Anvil
I would like to check with you guys about the pros and cons of increasing the speed of the deck blades, possibly by increasing the diameter of the drive pulley on the PTO clutch. Anybody do this????? I'm not so worried about the spindle shafts on the deck as I grease the heck out of them on a regular basis. The Mule longevity however, without a grease fitting concerns me. Your thoughts????
  • Confused 1
gwest_ca
First thing I would do is put a tachometer on the engine and find how fast it is running. Then see what rpm the spindles are turning with the engine at operating speed. That way you can calculate how far off the 19,200 maximum feet per minute the blade tips are travelling.
Garry
JoeM
There is a pretty good thread on this subject here. Not sure what the title was maybe someone will know.
gwest is right, you need to avoid excessive blade tip speed. All the engineering is done using the pulleys installed from the factory.
I have two different decks, 42 and 48 side, both run and cut great. Checking the RPM of the engine is a great place to start.
Marv
:text-yeahthat:
Marv
953 nut
:WRS:
The engineers at Wheel Horse and other manufacturers didn't just randomly decide what size pulleys to use. I think they actually used laws of physics and a bit of common sense. You have to take into consideration the fact that our mower blades are not dynamically balanced and any imbalance will be magnified with increased speed. The resulting vibration can crack the deck and destroy bearings.
Slow down, relax and enjoy some quality seat time.
wallfish
All of the above and sharp blades will do wonders as well.
To increase the size of the PTO pulley, you'll need to machine a whole new bell. Smaller pulley on the deck will probably be much easier to do.
Why are you looking for more blade speed?
  • Excellent 1
Anvil
Thank you all for your input. I will begin with the basics as suggested. I did move the PTO drive belt out to the outer pulley, which is slightly smaller and it appeared to cut better. Which pulley should the drive belt be on? The C-141, 312-8, and 417-8 all had the belts on the second or inner pulley. When I moved the belt to the outer or smaller pulley the belt appeared to ride just fine so aside from a bit more tension against the PTO shaft bearing I didn't see any negative effects. I also know that the effects can be cumulative over time increasing wear but to what extent....2%???
953 nut
The larger PTO pulley is for mowing, the outer on for snow blowers. If you are finding the smaller one gives you better results then stick with it.
  • Similar Content
    • GeoC-120
      By GeoC-120
      The time has come for me to part with my trusty Wheel Horse and find it a new home. I am the second owner (since 2003) and it has always been stored in a garage.
      I am located about 20 minutes south of Rt 80 or 15 minutes north of Rt 78 near Rt 33.
      1975 C-120 Special, 8-speed (Model 1-0375, Ser. # 133357). Running (no smoke) 12 hp Tecumseh (Model HH120-120180E, rebuilt 1986). Rebuilt carb, new fuel pump, and new ignition module (in 2006). Good used replacement tank, original tank is included in the sale.  Brand-new battery, fuel filter, and shutoff valve installed 5/26.
      Solid 42” side discharge deck (Model 5-1010) bearings replaced in 2005. Extra set of Gator mulching blades and spare hi-lift blades included. Deck works as it should and is ready to cut.
      42” snow/dozer blade (Model 86-42BC01) with Rear weights, tire chains and hardware. Blade angles left and right and lifts correctly and is ready to plow.
      Parts: 4 NOS belts and 2 good used belts, NOS taillight lenses, used starter, used ignition module, more (see pic).
      1975 C Series Owner’s manual, 1975 WH accessory catalog, 5-1010 deck manual, original HH-120 manual, updated Tecumseh HH-120 technicians handbook.
      Selling entire package for $300 Or Best Offer.
      Will deliver within 50 miles of zip 18064. Delivery over 50 miles is negotiable.
      Please PM to contact
      HH120_running.mp4
    • morePEdal
      By morePEdal
      *16 HP Onan Engine, 665.4 Hours
      *8 Speed Transmission
      *48” Snow Plow- Works Great! Set up and READY TO GO BEFORE THE SNOW!
      *Nice 42” Mowing Deck, no rot or welds, smooth spindles
      *OEM Wheel Weights, 50 lbs. Each
      *Chains
      *Valves adjusted this summer, runs great!
      *Good battery
      *Tires All Hold Air
      *LED lights all the way around
      *Manuals included
      Bought a Honda tractor with 4WD and 4WS with deck, plow and snowblower so I don’t need this tractor.
      Cash Only!
      *WILL NOT RESPOND TO “IS THIS STILL AVAILABLE?”
      *COMING SOON:  Also selling a Wheel Horse 520H with a 2-Stage Snowblower. Check out that listing if you want a snowblower garden tractor!
    • cJ_3D
      By cJ_3D
      Hello helpful Wheel Horse enthusiasts!
      Maybe you all could help me figure something out. I don't think I am installing the mower deck properly on my 1989 252-H and I don't know if the PTO clutch is adjusted right.
      So referencing this image here from the service manual for the mower deck (37"):
      What exactly am I doing with this adjustment knob and how does it fit into this piece?
      Also for the PTO clutch where am I sticking the feeler gauge exactly and do I need to do all 3 springs? Or does adjusting the one in the manual adjust all three?
      Much obliged for the help!
      CJ
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I’m having trouble with getting my deck to raise up and lock and I think it might have to do with the deck being incorrectly set up.
      Based on the picture, does my mower deck look incorrectly positioned? That is, should the pivoting support bar be positioned above or below the wheel support pin?
      Brian
