Similar Content
			By aaronthomas57
Hello Everyone,
The information here has been invaluable as far as getting this old wheel horse I purchased back in service. Some parts home made, the motor generator is ripped off a 2013 Yamaha, some salvaged parts.
I bought this little bastard some months ago, it had to be dug out of the previous owners yard and lifted with a backhoe. It had not ran in about 40 years.
Thanks for taking a look.
			By MachXXII
I’m trying to restore my grandfathers old 252-H to use around my property. The tires are shot and the rims aren’t too far behind. Anyone have any recommendations for rims and tires that would fit well on it?
right now it has 22 x 7.50 - 12 on the back and 15 x 6 - 6 on the front.
			By tomabrown77
my 1067 stopped moving; limited slip had worn out long ago; now input pully is turning , but tractor doesnt move --- very slight motion forward or backward if on level ground with no resistance. Enough to tell me shift lever is actually changing gears.
I suspect input shaft woodruff keys but might be something worse ... i am interested in perhaps buying a new, used,or rebuilt transaxle if someone has one they would part with. And any advice on opening up the transaxle and looking inside . Or where i can find parts to rebuild it myself...
ps i was on forum about 5 years ago, forgot my username so i joined again
			By Jeff_B
Where's your go-to source for QUALITY 103119 bearing shaft assemblies? Also, I don't have my deck apart yet, but seem to remember they're tough to remove from the housings. Any tips or tricks? Finally, just recently I've had a couple of the center bearings go loose on two different decks. Once is one thing, but twice? More than a coincidence? Should I be releasing tension on the belt by loosening the mule drive when not in use? We've had WH tractors for over 40+ years and I've never done that before! THANKS in advance!
			By BAM1
Starting a slow restore to a C-160, Today she got a new fuel tank, and different tires. Started it up and went for a ride under her own power, first time since '08.
Next comes finding the fuel leak, looks like a bad hose. and maybe some cleaning of the oily parts.
