Oldcpecdr 255 #1 Posted January 25, 2018 Hey all My first of many questions !!!! I attached the plow and fired up the Hydro..... it really is a sweet machine. I'd like to put the seat back about two inches... is it sacrilege to just drill new mounting holes ? Should I make some extension brackets for the seat and NOT drill new holes ? Someone must have done this... suggestions ? And thanks... Mike B 4 Share this post Link to post Share on other sites
rjg854 12,511 #2 Posted January 25, 2018 I don't personally have a problem with that, many of these tractors have been modified by their owners over the years. You got to be comfortable when your on your tractor. 5 Share this post Link to post Share on other sites
KC9KAS 4,744 #3 Posted January 25, 2018 Some folks design a bracket/piece of steel that bolts onto the original seat location but allows more flexibility to move the seat itself farther back (or forward) if needed. You need to be creative! 5 Share this post Link to post Share on other sites
953 nut 62,119 #4 Posted January 25, 2018 Might cause a stress point by just drilling new holes. In addition to moving the seat back you can gain some leg room by raising it an inch or two. 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,722 #5 Posted January 25, 2018 I made brackets to mount a replacement seat because the next seat will likely require something different. Garry 2 Share this post Link to post Share on other sites
ebinmaine 74,516 #6 Posted January 25, 2018 @JimmyJam Maybe you could share what you did for your uncle.... I agree with trying not to drill holes. Not for the sake of originality but for the sake of strength. 3 Share this post Link to post Share on other sites
Sarge 3,470 #7 Posted January 25, 2018 Hunt around some of the tractor bone yards - some later models of various makes used a slider assembly that is about 3/4" thick. I put one of those on top of the seat springs on a C series and that raised the seat just a bit , but also allowed it to go quite a ways back. Made it a lot more comfortable to operate. Nice part - it allows someone of short stature to use it as well, wish they all would have had an adjustable seat on them. The old 1277 had it's seat bolted directly to the pan - it got a set of C series springs as well as spacer blocks , I'm 6' and can't sit with my legs bent tightly any more, so it helps a lot. Sarge 3 Share this post Link to post Share on other sites
JimmyJam 542 #8 Posted January 25, 2018 (edited) @ebinmaine Sure! So I needed to extend the seat of a Commando 800 for my 7' uncle. I originally added seat springs from a B-80, thinking it would add height. Next I took Ed Kendall's suggestion by ordering a pair of Unistrut channels and 4 hangers from McMaster-Carr. I ordered (2) 2-7/16" high channels (Part # 3548T213) and (4) 1/4"-20 Tab-Lock Nuts (Part #2233K11). You can even order them in powder-coated RED. They ship fast. I mounted the channels to the fender pan using original holes (channel has pre-drilled holes, some slotted), then I slid 2 hangers down each of the channels and tightened them down (up) to the seat spring holes and adjusted to the appropriate length. I did have to bolt down the fender pan for safety concerns that my uncle may accidentally hit the seat latch and find himself falling backward. Those Unstrut channels from McMaster-Carr are industrial strength, not like the whimpy U-shaped channels you find at a store. Edited January 25, 2018 by JimmyJam 2 3 Share this post Link to post Share on other sites
JimmyJam 542 #9 Posted January 25, 2018 BTW: TO ...another South Coast, Massachusetts member! 2 Share this post Link to post Share on other sites
Oldcpecdr 255 #10 Posted January 25, 2018 Thanks for the ideas !!! I'll whip up some extender brackets this weekend. Mike B 3 1 Share this post Link to post Share on other sites
paxz71usa 173 #11 Posted January 25, 2018 (edited) Just looked under mine a few minutes ago and there are four sets of holes for adjustment already there and they sure appear to be factory. Gary Edited January 25, 2018 by paxz71usa 3 Share this post Link to post Share on other sites
ACman 7,673 #12 Posted January 25, 2018 This is what I used on my 520 when I replaced my seat. Lots of holes for multiple mounting points. https://www.northerntool.com/shop/tools/product_200333225_200333225 2 2 Share this post Link to post Share on other sites
ebinmaine 74,516 #13 Posted January 25, 2018 1 hour ago, paxz71usa said: Just looked under mine a few minutes ago and there are four sets of holes for adjustment already there and they sure appear to be factory. Gary My b80 is also set up like that with multiple holes. Unfortunately some other owners have added multiple other holes... and I've drilled two more myself So it's beginning to look a bit like Swiss cheese 3 Share this post Link to post Share on other sites
Racinbob 12,233 #14 Posted January 25, 2018 I did this when I restored a Commando 800 for my grandson. The slots in the pan give you quite a bit of adjustment. The back of it is bolted directly to the fender pan since there's so need for it to flip up. I'm doing the same thing on my 500 Special. I was also concerned about the fender latch so I spring loaded it latched closed. 5 2 Share this post Link to post Share on other sites
paxz71usa 173 #15 Posted January 25, 2018 If I eat a few more pancakes and sausage for breakfast, I'll have the front wheels off the ground with seat back much further! Gary 2 Share this post Link to post Share on other sites
ebinmaine 74,516 #16 Posted January 25, 2018 8 minutes ago, paxz71usa said: If I eat a few more pancakes and sausage for breakfast, I'll have the front wheels off the ground with seat back much further! Gary I'm right there withya. .... 1 Share this post Link to post Share on other sites
JimmyJam 542 #17 Posted January 26, 2018 I that case add tombstone weights to the front! 1 for every stack you eat! LOL!!! 1 Share this post Link to post Share on other sites
roadapples 6,985 #18 Posted January 26, 2018 5 hours ago, paxz71usa said: If I eat a few more pancakes and sausage for breakfast, I'll have the front wheels off the ground with seat back much further! Gary Know what you mean. About two biscuits shy of wheelstands myself... 1 1 Share this post Link to post Share on other sites
AMC RULES 37,232 #19 Posted January 26, 2018 7 minutes ago, roadapples said: About two biscuits shy of wheelstands myself... 2 1 Share this post Link to post Share on other sites
