Handy Don 17,226 #24601 Posted September 24, 2025 10 hours ago, Blue Chips said: The rust isn't as deep as it looks in the photos, Sure and I don’t have a blasting option to hand but those look like perfect candidates for a paint stripping disk in an angle grinder. They are available in different “grits” depending on how aggressive you want to get. 3 Share this post Link to post Share on other sites
Blue Chips 826 #24602 Posted September 24, 2025 1 minute ago, Handy Don said: Sure and I don’t have a blasting option to hand but those look like perfect candidates for a paint stripping disk in an angle grinder. They are available in different “grits” depending on how aggressive you want to get. Oh, yes. Angle grinders are among my most-used tools. I'll probably go over it lightly with a 5" flap disk to quickly knock off the worst of the rust, then go to a paint stripping disk like you mentioned, which will conform fairly well to the depressions without doing much damage to the good metal, and then use an acid bath to remove the rest of the rust in the small pits. With this approach I should be able to get most of the rust off with the angle grinder so that it doesn't have to sit very long in the acid bath. The original rubber mats will cover almost all of the repaired rust spots, except for a few small spots on the outer edges, which I'll touch up with a dab of Bondo. 1 Share this post Link to post Share on other sites
953 nut 68,254 #24603 Posted September 24, 2025 11 hours ago, Blue Chips said: . I think I'll try a less aggressive approach, like soaking the foot rests in paint remover overnight, A needle scaler will remove the paint and rust, works well. Rather than a rubber mat you could use some Anti-Skid paint additive and roll on the final finish on the treads using the same paint color or black. 3 Share this post Link to post Share on other sites
ebinmaine 80,148 #24604 Posted September 24, 2025 3 minutes ago, 953 nut said: needle scaler I've had mixed results with those. How much air pressure do you run? Share this post Link to post Share on other sites
Blue Chips 826 #24605 Posted September 24, 2025 Just now, 953 nut said: A needle scaler will remove the paint and rust, works well. I've found a needle scaler useful on lots of occasions. Its effectiveness seems to depend on the type and depth of rust and the type of substrate. Sometimes it has worked well, and sometimes not. I might try a quick shot with the scaler just to see what happens. It's fairly thick sheet metal, so I don't think the scaler would stretch it unless I overdo it with the pressure. If it were thinner sheet I'd avoid using a scaler. Just now, 953 nut said: Rather than a rubber mat you could use some Anti-Skid paint additive and roll on the final finish on the treads using the same paint color or black. That's very useful stuff, although the original mats are still in good shape...still pliable and no cracks...and I like their looks. I found new plastic push pins/clips for them that are a good match to the originals. 1 Share this post Link to post Share on other sites
sqrlgtr 3,649 #24606 Posted September 24, 2025 Started rebuild of fuel pump on the 857. Had crank case full of oil . I ordered another kit from then and now auto because I cant find the kit I already had on hand lol…. 7 1 Share this post Link to post Share on other sites
Lee1977 7,744 #24607 Posted September 25, 2025 I did a little tree trimming on the live oak yesterday, today I'm taking it easy. 6 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,027 #24608 Posted September 26, 2025 Since we're catching up on the rain here we didn't get this summer. I made a list of the stuff to be done on the Black hood and the C-141 once I pay my taxes at the end of the month. 1 Share this post Link to post Share on other sites
sqrlgtr 3,649 #24609 Posted September 26, 2025 While waiting on fuel pump kit, done a chem dip on carb and reset points on the 856 I brought home from big show. Sure is a sweet runner. IMG_7488.MOV 2 2 Share this post Link to post Share on other sites
Blue Chips 826 #24610 Posted September 26, 2025 (edited) Painted the rear body/fender of my GT18 today with three coats of New Holland-approved paint. I used up almost three rattle cans on this body part. In hindsight, I should have just ordered a quart or two of paint and used an HVLP spray gun for this project, but it came out OK...no runs and pretty shiny. What looks like wrinkles in the paint is just the masking tape on the data labels. The GT18 came with rear-facing reflectors, which are essentially taillight lenses with a piece of white (now yellow with age) plastic behind them. Here are the original reflectors (which are still in pretty good shape): I thought I'd upgrade the GT18 by replacing the reflectors with "real" taillights, like those on my 522xi. I did a bit of searching and found a set (see part number in photo): I just ordered a set of lamp sockets for the new taillights, and I plan to add the taillight wiring when I have a moment. The taillights will come on when the headlights are on. The total current for the headlights and taillights together should be less than the original headlights alone, since I've switched to LED bulbs for the headlights. Edited September 26, 2025 by Blue Chips 3 5 Share this post Link to post Share on other sites
MainelyWheelhorse 3,027 #24611 Posted September 27, 2025 Today I got the group out in the sun for Front End Friday. I worked some on the C-141 rerouting the gas line to make it start easier, which was a success. I also worked more on the C-85 getting it to the point where its easier to move around. I also started a bit of disassembly on the shaker motor mount as I'm going to set it up like the others. I also removed the PO added external idle handle. 2 6 Share this post Link to post Share on other sites
squonk 47,811 #24612 Posted September 27, 2025 Somebody told me recently that I needed to fill a spot in my 875 dash! 7 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,523 #24613 Posted September 27, 2025 Picked up one today. More to come soon 6 5 Share this post Link to post Share on other sites
Sparky-(Admin) 26,195 #24614 Posted September 27, 2025 Moved the 2” receiver from the Workhorse to the 520-8. 13 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,027 #24615 Posted September 28, 2025 I wasn’t happy with the way the paint job on the C-141 came out so I figured I’d fix it. It’s supposed to be nice the next few days so I figured I’d give it another shot before it gets cold. That might be a tomorrow morning or Monday project. It’s a learning curve….right😁 8 2 Share this post Link to post Share on other sites
kpinnc 18,860 #24616 Posted September 28, 2025 2 hours ago, MainelyWheelhorse said: It’s a learning curve….right😁 I've painted and stripped the hood on my current project 3 times now. It's primed, sanded, and ready to go. I'm gonna wait for a cooler evening later this week so I won't get bug tracks in it. Good luck to us both! 5 1 Share this post Link to post Share on other sites
peter lena 9,998 #24617 Posted September 28, 2025 @ebinmaine @Blue Chips , good job on the oiling , personally think the hot sun bake in , is the finish you want , my decks are stained black , with oil bake in , never really did more than a thorough cleaning , of deck bottom , before 2 stage , penetrant , open gear oil set up . did the lighter oil first , sun just abot evaporated it , deck hot , then over spray ,gear oil , to same baking effect . amazing durability , have to break the " GRUNGE CYCLE " with oiled heat base . of course , experimenting with a repetitive problem, IS WHAT YOU WANT ! ground zero , did a lot of " what if,s " on refitting , you know what fails , very often just a DETAILING TO FUNCTION , is what makes it bombproof / easier function. very simple / easy trial spot , EXPERIMENT , is PTO LEVER START AREA , SIDE OF BATTERY TRAY , simple / easy . this converted me , pete 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,027 #24618 Posted September 28, 2025 17 hours ago, kpinnc said: I've painted and stripped the hood on my current project 3 times now. It's primed, sanded, and ready to go. I'm gonna wait for a cooler evening later this week so I won't get bug tracks in it. Good luck to us both! @kpinnc I think I’ve redone mine 4 or 5 times now due to outside variables like excessive trash in the paint, the difference between a spray gun paint, and spray can, or bad bondo. The surface was significantly pitted as well. I learn something new every time though. Good luck on your paint job top too. 1 1 Share this post Link to post Share on other sites
c-series don 12,333 #24619 Posted September 28, 2025 I took out some tractors I had stored in my enclosed trailer to put different ones in to go to a show yesterday. When I got home I didn’t feel like reloading them so I just put them in the garage. 1 13 Share this post Link to post Share on other sites
MainelyWheelhorse 3,027 #24620 Posted September 29, 2025 All painted……for now. It’s a worker but it seems to be better than the last paint job so far.. And I preliminarily painted the belt cover with a spray can for The C-85 since it was off a Workhorse. Your turn @kpinnc.😁 7 1 Share this post Link to post Share on other sites
kpinnc 18,860 #24621 Posted September 30, 2025 2 hours ago, MainelyWheelhorse said: Your turn @kpinnc. I know, I know... I have no indoor spot to paint and I'm waiting until the bugs are too cool to be out. End of the week is supposed to see temps dip to the high 40s at night. Fingers crossed! 2 Share this post Link to post Share on other sites
Bar Nuthin 2,965 #24622 Posted September 30, 2025 Decided to tackle this non-running C-141A I bought Friday. Looks like the original owner had starting issues and took the wrong turn at every step along the way. They even went so far as to direct wire a push-button start (with 12 gauge wire)! So, I basically cut away a half mile of unnecessary wiring, rerouted the remaining wires where they belonged. Also swapped out an incorrect coil, solenoid, condenser, and fried points. Set the points timing, fuel looked and smelled fresh, so I just replaced with a proper filter. Oil in engine and hydro looked new, Hit key - started! Aired tires, drove tractor, tested hydraulic lift, attached deck, and mowed several strips in the empty park behind our property. Outstanding day 1 results! 2 8 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,195 #24623 Posted September 30, 2025 2 hours ago, MainelyWheelhorse said: All painted……for now. It’s a worker but it seems to be better than the last paint job so far.. And Yourturn @kpinnc.😁 @MainelyWheelhorse. If you want to change up the hood, and your cool with not being 100% original maybe add stripes ? 5 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,027 #24624 Posted September 30, 2025 10 minutes ago, Sparky said: @MainelyWheelhorse. If you want to change up the hood, and your cool with not being 100% original maybe add stripes ? @Sparky Hmmm, maybe… between the dash panel, it’s setup, the shift plate, the headlight lens and all the wiring it’s about 50% original. Once the decals go on we’ll see what it looks like. It’s still a pretty big blank canvas. 3 Share this post Link to post Share on other sites
MainelyWheelhorse 3,027 #24625 Posted September 30, 2025 51 minutes ago, kpinnc said: I know, I know... I have no indoor spot to paint and I'm waiting until the bugs are too cool to be out. End of the week is supposed to see temps dip to the high 40s at night. Fingers crossed! Good luck, I figured I’d do it today as it was almost 80. The temps overall are starting to drop here too. It’s supposed to be high 60’s and low 70’s the next week and a half here. The nights are in the 40’s too. Hopefully it’s plenty of time for the implement paint to set up fully or close to it. 2 Share this post Link to post Share on other sites
