TJ5208 1,841 #12676 Posted September 5, 2021 Some pics of Buddy and Rebel 1 3 Share this post Link to post Share on other sites
WheelPuke 78 #12677 Posted September 5, 2021 Thanks for the extra tip @peter lena I have that grease on had already. Share this post Link to post Share on other sites
nylyon-(Admin) 9,059 #12678 Posted September 5, 2021 Let's keep the topic on track gang. 2 Share this post Link to post Share on other sites
8ntruck 9,296 #12679 Posted September 6, 2021 Got my C-195 back together today. Drove it around my property parameter a couple of times. The hydro linkage is working fine, the electric fuel pump seems to keep up, but something is off with the carb. The idle is too rich, the choke linkage is weird, and it is not starting as easily as it was before I started working on it. Looks like there might be some trailer work for it tomorrow. 4 Share this post Link to post Share on other sites
953 nut 69,299 #12680 Posted September 6, 2021 8 hours ago, 8ntruck said: something is off with the carb. Try some Sea Foam gas treatment, works well for me. 3 Share this post Link to post Share on other sites
WheelHorse520H 710 #12681 Posted September 6, 2021 30 minutes ago, 953 nut said: Try some Sea Foam gas treatment, works well for me. I always put gas, and a little SeaFoam in, keeps everything clean and running smooth. I usually just put some in the gas can and forget about it. 3 Share this post Link to post Share on other sites
SylvanLakeWH 32,503 #12682 Posted September 6, 2021 (edited) Ready for the party…! Post party post: Perfect day!!! Great train ride through the neighborhood to the lake… Kids had a blast as well as the adults - including my 94 1/2 year old Dad who had his first ride on the SL&WHN RR…! IMG_0826.MOV Edited September 6, 2021 by SylvanLakeWH 3 7 1 Share this post Link to post Share on other sites
Stormin 9,988 #12683 Posted September 6, 2021 C-125 has been rather reluctant to start for a while. A lot of winding up, throttle and choke juggling, fire a little then stop. Yesterday after the usual palaver, I sprayed some petrol into the carb mouth. Started then, so I'm thinking weak fuel pump. So today I changed the pump. Did start a bit better and time will tell. Maybe invest on an electric pump at some future time. 3 Share this post Link to post Share on other sites
8ntruck 9,296 #12684 Posted September 6, 2021 4 hours ago, 953 nut said: Try some Sea Foam gas treatment, works well for me. I'm running my usual mix of 5 gallons of rec gas with 1/2 can of Sea Foam. 2 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #12685 Posted September 6, 2021 43 minutes ago, Stormin said: reluctant to start Primer bulb might help too Norm. 1 Share this post Link to post Share on other sites
Stormin 9,988 #12686 Posted September 6, 2021 2 minutes ago, ebinmaine said: Primer bulb might help too Norm. Has one. 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #12687 Posted September 6, 2021 (edited) Cleaned the old girl up... Don Edited September 6, 2021 by Snoopy11 swapping pictures... 3 2 2 Share this post Link to post Share on other sites
stevasaurus 23,856 #12688 Posted September 6, 2021 Cleaned up the snow blade on my 857. Regal Red painted with a 3" roller and the help of a brush. No snow sticking this year. 13 6 Share this post Link to post Share on other sites
Snoopy11 5,731 #12689 Posted September 6, 2021 13 minutes ago, stevasaurus said: Cleaned up the snow blade on my 857. Regal Red painted with a 3" roller and the help of a brush. No snow sticking this year. 2 1 Share this post Link to post Share on other sites
squonk 48,123 #12690 Posted September 6, 2021 Starting another 8 Horsie. 8 5 Share this post Link to post Share on other sites
balconio 606 #12691 Posted September 6, 2021 (edited) My 312-8 with 1654 hours got a new electric fuel pump today. The cheapest one I could find on Amazon, $9.98 for an "HEP-02A" pump. Some kind Wheel Horse engineer designed the frame with 2 perfect mounting holes, knowing I'd be ditching their mechanical pump 30+ years later for a $10 Chinese deal 🙄. I have an inline fuel filter before and after the pump- the 2nd one was really just used as a hose splice where I bypassed the old pump. No relay, this only draws 1 amp so I didn't see the need. I do need to wire an inline fuse though and solder it up. Also for those who've gone electric, did you remove the old pump or just leave it as is? Edited September 6, 2021 by balconio 2 2 Share this post Link to post Share on other sites
8ntruck 9,296 #12692 Posted September 6, 2021 I had the top off of my mechanical pump when I decided to replace it. I used the fuel hose barbs on the electric pump, so I made a block off plate to replace the top of the fuel pump. Share this post Link to post Share on other sites
Gregor 4,848 #12693 Posted September 6, 2021 I have tried those $10 Amazon pumps. They didn't work out well for me, hope you have better luck. I always block off the original pump opening. 3 Share this post Link to post Share on other sites
pfrederi 21,150 #12694 Posted September 6, 2021 (edited) 42 minutes ago, Gregor said: I have tried those $10 Amazon pumps. They didn't work out well for me, hope you have better luck. I always block off the original pump opening. 500 ft from the shop $10 pump failure... Facet posiflo made in USA is all I use now Some i made block offs some i left... Edited September 6, 2021 by pfrederi 3 3 Share this post Link to post Share on other sites
Rob R 989 #12695 Posted September 7, 2021 22 hours ago, Stormin said: C-125 has been rather reluctant to start for a while. A lot of winding up, throttle and choke juggling, fire a little then stop. Yesterday after the usual palaver, I sprayed some petrol into the carb mouth. Started then, so I'm thinking weak fuel pump. So today I changed the pump. Did start a bit better and time will tell. Maybe invest on an electric pump at some future time. Stormin I have see q 22 hours ago, Stormin said: C-125 has been rather reluctant to start for a while. A lot of winding up, throttle and choke juggling, fire a little then stop. Yesterday after the usual palaver, I sprayed some petrol into the carb mouth. Started then, so I'm thinking weak fuel pump. So today I changed the pump. Did start a bit better and time will tell. Maybe invest on an electric pump at some future time. Stormin I have seen quite often the fuel pump is NOT the problem they are great pushers but poor pullers. Check the flow of fuel all the way from the tank to the pump, replace the fuel lines and check any valves and or added filters..... just saying.... 2 Share this post Link to post Share on other sites
squonk 48,123 #12696 Posted September 7, 2021 As they used to say in NASCAR. "She done blowed up Cale!" Tore @D_Mac 's blown 875 engine apart to save anything salvageable. Block not only had a chunk out of the cylinder but it is cracked about 3/4 of the way around! Piston is going in my "Haul of Fame! 1 7 Share this post Link to post Share on other sites
Handy Don 17,474 #12697 Posted September 7, 2021 I reckon that cylinder 'bout lost it head, sir! 2 Share this post Link to post Share on other sites
Pullstart 71,235 #12698 Posted September 7, 2021 21 hours ago, balconio said: Also for those who've gone electric, did you remove the old pump or just leave it as is? I’ suggest a block off. If the pump diaphragm is torn, it could be a point of entry for debris and whatnot. At the very least, put a short hose from one end to the other. 1 Share this post Link to post Share on other sites
stevasaurus 23,856 #12699 Posted September 7, 2021 Nice paper weight collection you have there Mike. 3 Share this post Link to post Share on other sites
Stormin 9,988 #12700 Posted September 7, 2021 Drill holes in the piston crowns and you'll have handy pencil/pen holders. 2 2 2 Share this post Link to post Share on other sites
