Pullstart 68,707 #5751 Posted July 15, 2020 11 hours ago, Ro-Go said: Added RV antifreeze as ballast to the new tires, front and rear. Got a transfer pump for $60 online, so tiny and cheap. Ugh. It worked, but the tires and tubes wanted to push the ballast back out; I did shut pump down 1/2 way to release air...but it still kept wanting to push out of the valve -- was there something I did wrong? 4 hours ago, ebinmaine said: @pullstart could explain how he set one up... I pushed the fluid right through the normal Schroeder valve, with the core in place. I have a portable air tank and removed the air outlet fitting and used a funnel to fill the tank with fluid. After reinstalling the outlet stuff, I charged it with 20-ish psi of air. Be careful to not over charge it, the water doesn’t compress very easy! Tip the tire up on a 45 degree or so angle, so the valve stem is high as you can get it. Tip the charged and full air tank upside down and proceed to fill the tire like normal. You may need to put some more air in occasionally but it forces the fluid right through. 3 Share this post Link to post Share on other sites
Achto 30,689 #5753 Posted July 15, 2020 (edited) On 7/14/2020 at 5:55 PM, johnnymag3 said: I need to learn this talent of welding....PREP PREP PREP Dang chicken poop welds.....I never seem to get it right !!! "Grinder & paint makes me the welder I ain't" Edited July 17, 2020 by Achto 3 1 Share this post Link to post Share on other sites
pfrederi 19,663 #5754 Posted July 15, 2020 23 minutes ago, Achto said: "Grinder & paint can makes me the welder I ain't" I go through grinding disks faster than weld sticks.... 2 2 1 Share this post Link to post Share on other sites
Stormin 9,987 #5755 Posted July 15, 2020 (edited) Had another go at trying to improve the C-125's starting and running. Removed the carb' and the mixture screws along with the float bowl. Bowl was very clean with just one tiny speck of dirt. Blew out the passage ways with the airline and checked the face for flatness. Holes in main jet needle all check for being clear. Reassembled and stared up. After warming up adjusted the mixtures. Seems to start better and runs smoother, picking up without any hesitation on opening the throttle. Idle still a bit faster than I would like, but I can live with it. Edited July 15, 2020 by Stormin 6 Share this post Link to post Share on other sites
pfrederi 19,663 #5756 Posted July 15, 2020 Was finishing up mowing yesterday C141 started to die like she was out of gas. Headed back to shop the thene engne started to race Throttle had no effect. Pulled some choke that slowed it down limped in to the shop. Lost the E clip that holds the governor arm to Carb linkages.... Nice to have an easy fix once and awhile and a failure near the workshop... 14 Share this post Link to post Share on other sites
squonk 45,232 #5757 Posted July 15, 2020 51 minutes ago, pfrederi said: Was finishing up mowing yesterday C141 started to die like she was out of gas. Headed back to shop the thene engne started to race Throttle had no effect. Pulled some choke that slowed it down limped in to the shop. Lost the E clip that holds the governor arm to Carb linkages.... Nice to have an easy fix once and awhile and a failure near the workshop... That reminds me of when the carb fell apart on my 701 at our steam show and it was like 2 miles back to my canopy and tools. Good thing the tractor was light! 1 1 2 Share this post Link to post Share on other sites
AMC RULES 37,254 #5758 Posted July 15, 2020 Got my big old plush W-H love seat cover installed today.Oh...and a matching PMCO bullet tail light to finish off my recently installed HL-5 light kit. 4 8 Share this post Link to post Share on other sites
echris 1,426 #5759 Posted July 17, 2020 (edited) On 7/15/2020 at 11:52 AM, pfrederi said: Was finishing up mowing yesterday C141 started to die like she was out of gas. Headed back to shop the thene engne started to race Throttle had no effect. Pulled some choke that slowed it down limped in to the shop. Lost the E clip that holds the governor arm to Carb linkages.... Nice to have an easy fix once and awhile and a failure near the workshop... Best kind of fix. Simple. And if you don't have the correct clip a piece of ~18g copper wire wrapped around the groove and twisted a few turns will do the trick! Edited July 17, 2020 by echris 3 Share this post Link to post Share on other sites
echris 1,426 #5760 Posted July 17, 2020 I mowed today for the first time in a few weeks. Not much growing with the heat. (except weeds) Remember my broken shifter retaining set screw that I was going to drill out this winter? No need. I took about 2 passes across the front yard, switched gears and she wouldn't move. Of course, first thing I do is lean to the right and look for bits of drive belt. Go to shift back to 2nd from R, oops... Shifter is all wobbly. The set screw worked itself out. Problem solved. Or it will be when my Flea-spray order shows up. I was able to get it back into 2nd and finish the job. No backing up, DO NOT try to shift. heh. 6 Share this post Link to post Share on other sites
19richie66 17,774 #5761 Posted July 17, 2020 (edited) So I’m one of those guys that names his tractors. I decided to make “license plates” for them with thier names on them. Finished the first one for my 953. I named it after my ex-father as he was a very hard worker, simple and no frills kinda guy...... same as this tractor. A fitting tribute to the man. Edited July 17, 2020 by 19richie66 No, I didn’t weld it 😁 7 4 4 Share this post Link to post Share on other sites
WHX?? 54,209 #5762 Posted July 17, 2020 You ain't doing a very good job being busy not to be busy Ritchie! Tell ya right now guys are gonna be pestering you with orders! 2 1 2 Share this post Link to post Share on other sites
Ed Kennell 44,444 #5763 Posted July 17, 2020 First there was @wallfish tooth pick art, then @Dan.gerous swizzle stick art, now we have @19richie66 tig art. What a bunch of talented artists. 5 3 3 Share this post Link to post Share on other sites
19richie66 17,774 #5764 Posted July 17, 2020 1 minute ago, Ed Kennell said: First there was @wallfish tooth pick art, then @Dan.gerous swizzle stick art, now we have @19richie66 tig art. What a bunch of talented artists. Thanks Ed but that’s all my son’s handywork with the tig torch. I cut, scribed it out and he zapped it. 6 minutes ago, WHX24 said: Tell ya right now guys are gonna be pestering you with orders! My son said bring it on! 7 Share this post Link to post Share on other sites
AMC RULES 37,254 #5765 Posted July 17, 2020 Got me thinking... some custom W-H signage here. 1 1 Share this post Link to post Share on other sites
oldredrider 2,553 #5766 Posted July 17, 2020 Plucked an old 12hp Kohler off the shelf to replace a worn out and tired Briggs in a GT1142. Converted wiring for mag ignition to battery type. Basically, turned the old girl into a 312. Ready to go back to work. 7 5 2 Share this post Link to post Share on other sites
19richie66 17,774 #5767 Posted July 17, 2020 4 minutes ago, AMC RULES said: Got me thinking... some custom W-H signage here. It’s been on my mind for a while. Got three designs already thought out. Hit me with an idea and we’ll see if it can happen 1 Share this post Link to post Share on other sites
WHX?? 54,209 #5768 Posted July 17, 2020 1 hour ago, 19richie66 said: Thanks Ed but that’s all my son’s handywork with the tig torch. I cut, scribed it out and he zapped it. My son said bring it on! He is good Ritchie those beads look very uniform. 1 Share this post Link to post Share on other sites
19richie66 17,774 #5769 Posted July 17, 2020 2 minutes ago, WHX24 said: He is good Ritchie those beads look very uniform. Thanks Jim! He does this 10 hours a day making ski towers for high end ski boats. Definitely gets more practice than me. 5 Share this post Link to post Share on other sites
AMC RULES 37,254 #5770 Posted July 17, 2020 1 hour ago, 19richie66 said: It’s been on my mind for a while. Got three designs already thought out. Hit me with an idea and we’ll see if it can happen Maybe something with the words WHEEL-HORSE and the horse head logo...LOL! 2 Share this post Link to post Share on other sites
19richie66 17,774 #5771 Posted July 17, 2020 Well that’s one of my ideas..... 1 Share this post Link to post Share on other sites
johnnymag3 2,634 #5772 Posted July 17, 2020 (edited) I have 5 plates I need to be done......Eddie, Snap, Covid, 19, JBOY Edited July 17, 2020 by johnnymag3 2 Share this post Link to post Share on other sites
johnnymag3 2,634 #5773 Posted July 17, 2020 PM me....Thanks, John Cost....etc.... Thanks Share this post Link to post Share on other sites
squonk 45,232 #5774 Posted July 17, 2020 Got the decals from Terry today so finished up the hood on the Wheel A Matic. Along with the hood latch and ornament. 6 6 2 Share this post Link to post Share on other sites
19richie66 17,774 #5775 Posted July 17, 2020 Looks great Mike! Share this post Link to post Share on other sites
