Burnerman 759 #3076 Posted September 21, 2019 New battery and installed new safety switches. The PTO switch is a PIA to replace. 😁 1 Share this post Link to post Share on other sites
adsm08 5,013 #3077 Posted September 21, 2019 Got some work done to and with both horses today. First we got some wood piled and cleaned up. I used the wagon on the 855 to move it up to the porch, and once the pieces in the pile got too small I got the 800 out with the plow and just dozed the rest up to the edge of the porch. Then I yanked the implement handle out of the 800 and got it fixed. The two forward holes had the threads all rotted out, so drill, tap, and heli-coil. Works much better now. I also got a butterfly pin for the cross shaft, so now it doesn't fall out. I still need to grease the release button and it looks like the return spring for the button is pooched, so I need to replace that yet. Then I got my HY pump fixed. I finally found and fixed that. There was a roll pin not in the whole way hitting something it shouldn't have, and not allowing full rotation of the fluid valve. 5 Share this post Link to post Share on other sites
TonyToro 1,189 #3078 Posted September 22, 2019 Well..... that C-145 may end up staying. My son and I got it running today. It needed a few things and a good carburetor cleaning but within a few hours it was running. He got about 2hrs seat time🙄 driving around and mowing. It actually mowed nicely. The hydrostatic operation made it super easy for him to use. I guess no we are considered collectors! Lol 2 4 1 Share this post Link to post Share on other sites
cafoose 3,817 #3079 Posted September 22, 2019 Gas was leaking somewhere between the tank and carburetor on my 876. I would put some gas in the tank and the next day it was empty. I could not find any evidence of leaking gas and it runs great so I doubt it's in the float. I got a new shutoff from and used the new tank I got from @Ed Kennell at the big show a couple years ago. The fuel line was shot so I replaced that while it was apart. I noticed what looked like fresh oil around the governor shaft. I guess the seal is leaking 3 1 Share this post Link to post Share on other sites
ebinmaine 80,343 #3080 Posted September 22, 2019 9 minutes ago, cafoose said: governor shaft. .... seal There's a seal there?? Isn't one on my '74 8hp.... Share this post Link to post Share on other sites
cafoose 3,817 #3081 Posted September 22, 2019 Don't know just guessing why else would oil leak there? Share this post Link to post Share on other sites
adsm08 5,013 #3082 Posted September 22, 2019 I think I blew up the voltage regulator. It tipped back and hit the gas tank as I was cranking, and now my headlights don't work anymore. So I added some insulation. That is Coroplast tape. It is fabric tape, insulates like electrical tape, and is resistant to heat, gas, and oil. It doesn't always like to stick to things that aren't other pieces of Coroplast, but it seemed to adhere to the tank well enough. This was what Ford had us wrapping the wiring harnesses of the 1.6L Escapes in to keep fluids out of the wiring during the 11S16 recall when they were catching on fire. 1 Share this post Link to post Share on other sites
ebinmaine 80,343 #3083 Posted September 22, 2019 21 minutes ago, adsm08 said: blew up the voltage regulator 49 minutes ago, cafoose said: Don't know just guessing why else would oil leak there? Others could answer more accurately but maybe oil breather clogged? Oil level ok? Gas isn't mixing in there? Share this post Link to post Share on other sites
adsm08 5,013 #3084 Posted September 22, 2019 2 minutes ago, ebinmaine said: You are telling me. I just pulled the cover off, the one section of copper coil is burnt black and has a big piece busted out. Now if only I could find a part number. I have only found one Delco-Remy that looks like this one and it says it's for a 6V positive ground, which does not seem to describe my system. Share this post Link to post Share on other sites
ebinmaine 80,343 #3085 Posted September 22, 2019 3 minutes ago, adsm08 said: You are telling me. I just pulled the cover off, the one section of copper coil is burnt black and has a big piece busted out. Now if only I could find a part number. I have only found one Delco-Remy that looks like this one and it says it's for a 6V positive ground, which does not seem to describe my system. Post the question in the electrical section or do a search there. Someone around here will lead you the right way. Share this post Link to post Share on other sites
adsm08 5,013 #3086 Posted September 22, 2019 10 minutes ago, ebinmaine said: Post the question in the electrical section or do a search there. Someone around here will lead you the right way. I think I found it, this appears to be the right one. https://www.ebay.com/itm/12-Volt-Generator-Voltage-Regulator-1118266-1118306-1118791-1118983-For-Delco-/281159796267 1 Share this post Link to post Share on other sites
chip61 666 #3087 Posted September 23, 2019 Do you have a starter/generator shop around? They could get you fixed up Share this post Link to post Share on other sites
Stepney 2,356 #3088 Posted September 23, 2019 Got my leaf-season deck all done up and mounted on the GT1848.. just need some 8" rear wheels since the 10"'s rub the gauge wheels. Saved a 516-h from the woods.. 3 3 Share this post Link to post Share on other sites
Pullstart 71,108 #3089 Posted September 23, 2019 Looks like the woods won the battle on that hood... Share this post Link to post Share on other sites
cleat 9,230 #3090 Posted September 23, 2019 The poor thing took quite a punch in the nose. However, the GT1848 and deck (1842 now ?) looks great. Share this post Link to post Share on other sites
LengerichKA88 1,885 #3091 Posted September 23, 2019 Well, I’ve done a bit here and there recently, but it’s been hard to find the time now that I’m working again. FINALLY got the floor to the horse barn done, and was able to move everything in this weekend. Now I have my own space to work on my own things. I should be able to come out and work on things as I find the time. 1 1 2 Share this post Link to post Share on other sites
pfrederi 21,055 #3092 Posted September 23, 2019 16 hours ago, adsm08 said: I think I found it, this appears to be the right one. https://www.ebay.com/itm/12-Volt-Generator-Voltage-Regulator-1118266-1118306-1118791-1118983-For-Delco-/281159796267 That will work. On some i have the terminals to the front and some to the back to avoid contact with Engine shroud or fuel tank depends on the genny pulley size and the belt I have on the S/G 1 1 Share this post Link to post Share on other sites
Lane Ranger 12,094 #3093 Posted September 23, 2019 Hooked up my old Snapper dethatcher to the 702 today to do some much needed lawn dethatching! Dry weather the last six weeks has done a number on my normally green lawn! Put my set of three 12 lb weights on the back of the dethatcher and cleaned it off after two passes. Does a great job. 5 Share this post Link to post Share on other sites
TonyToro 1,189 #3094 Posted September 23, 2019 17 hours ago, Stepney said: Got my leaf-season deck all done up and mounted on the GT1848.. just need some 8" rear wheels since the 10"'s rub the gauge wheels. Saved a 516-h from the woods.. That’s a nice looking Work Horse. Can you tell me the color? 1 Share this post Link to post Share on other sites
Stepney 2,356 #3095 Posted September 23, 2019 3 minutes ago, TonyToro said: That’s a nice looking Work Horse. Can you tell me the color? Wish I could. The previous owner had it repainted and re-stickered at a dealer back in the late 90s. All I can say is it's a pewter color with a subtle metallic look. Not the factory paint. 1 Share this post Link to post Share on other sites
Blackhood Bill 728 #3096 Posted September 23, 2019 Well today I received my hitch from @wheelhorseman(Lowell) wheel horse parts and more), so I installed it on my C-145 auto and works great!!!!!!!! 2 2 3 Share this post Link to post Share on other sites
adsm08 5,013 #3097 Posted September 23, 2019 8 hours ago, pfrederi said: That will work. On some i have the terminals to the front and some to the back to avoid contact with Engine shroud or fuel tank depends on the genny pulley size and the belt I have on the S/G Yeah, I think my issue there was two-fold. 1) I have the longest belt that will work on there because it is the only one I could get without waiting a week. I am at the very end of the adjustment and it still slips a bit (cheap belt, stretched more than it should have once it was run in). 2) The rubber mount on my regulator is pooched. I think the vibrations of cranking and the engine puttering as it caught were enough to let it tip back and hit the L terminal on the gas tank. I know it hit because I could see the burn mark in the paint. I think the combination of those two things are what allowed it to happen though. Share this post Link to post Share on other sites
adsm08 5,013 #3098 Posted September 23, 2019 20 hours ago, chip61 said: Do you have a starter/generator shop around? They could get you fixed up Nope. I am the odds and ends electrical repair shop in my area. I don't stock that regulator because it is used on almost nothing I work on. Share this post Link to post Share on other sites
Lane Ranger 12,094 #3099 Posted September 24, 2019 Started working on a 36 inch rear discharge mower deck I got from Florida (by way of Rodney Burger) and an early mid-grader blade. Had another Mid-Grader blade needing paint so started on that too! Nice Kohler Motor Dealer Sign given to me by Rodney today! mostly has to do with the pivot handle. 3 Share this post Link to post Share on other sites
peter lena 10,016 #3100 Posted September 24, 2019 312-8 last couple of days , zero response to key start, thought it was a connection issue , because it usually starts instantly, got to it today , checked fuses and connections , seamed to react to trying to start with lights on. opened dash and checked out starting switch, bingo ! one of the plug on tabs was corroded . lightly sanded down all related tabs and used DIELECTRIC GREASE lightly to each connection point , back to instant starting . not a big deal , but when you are used to no starting issues at all , it really stands out . had a very good catch up day , taking advantage of the opportunity to do things , day just flew by , pete 3 Share this post Link to post Share on other sites
