Ed Kennell
What have you done to your Wheel Horse today?
WHX??
7 hours ago, sqrlgtr said:
mounted them on th ol 1257 (Vince). With the thrust bearings
This is why I now interview guys that wanna buy my horses. To make sure they get taken care of. Gives meaning to going to a good home. :thumbs2:
  • Heart 1
Pullstart
On 8/21/2026 at 7:27 AM, Bugzilla46310 said:
Ended up buying the 520xi I looked at a few weeks ago after doing a little more research on hydrostat whine. Ordered filters and will do fluid and greasing before anything. The charging light and mowing in reverse lights stay on so I will need to resolve those also. Best thing, no buyers remorse.
Congrats on the purchase!  If you haven’t already, I’d suggest checking out that front axle pivot pin.  You’ll need to jack up the tractor by the frame to check for slop.
https://www.wheelhorseforum.com/topic/92609-xi-series-front-axle-pivot-repair/
sqrlgtr
This picture taken at "interveiw"
  • Haha 8
Pullstart
On 9/10/2026 at 11:04 AM, WHX?? said:
Hope you like the color changes. Just something different.
I’m proud of you Uncle Jim!
Pullstart
19 hours ago, Bryan Morford said:
Added a receiver hitch to the rear of my RJ-59 to attach a garbage can hauler. I have a very steep driveway and at 66 it is difficult to get the heavy trash cans to the curb.
Worked better than expected and I still get joy out of driving my grandfather's tractor he purchased new. BTW this is how I learned to drive!
:text-welcomewave:  that’s a sweet paint job, on Grandpa’s old tractor!  :orcs-cheers:
  • Excellent 4
Bar Nuthin
Picked up some HEAVY Bolens front cast iron weights. They had "BOLENS" cast into the face, so I filled them with some JB Weld.
Decided while I was painting them, that my JD rear weights needed to be red too! Now all my iron weights are red. Just one set of plastic fronts are the odd-balls now.
IMG_5942.jpg.6e2fe2057aba1d5da113a6d0f3de07d2.jpg IMG_5668.jpg.15995c506c7f1b2a4bc08ea4af4ddebd.jpg
Started doing a little prep work for an upcoming parade in our local festival.
Edited by Bar Nuthin
  • Like 9
peter lena
@sqrlgtr  absolutely  love  functional  detailing , thats  where you find the  hang ups , regular  for me is , MAKING  A CHANGE , TO WHAT FAILED ? typically  its  lubrication , and set up , ever shimmed up the PTO , lever  start point ? battery tray side , that literally  shows you the way. ,    every  stage , enhanced , what a difference , pete
sqrlgtr
Finally got a chance to put C160 back together today. New brake lining, and painted brake drum and band. Got my new to me late model 1 1/8” two set screw hubs installed thx to @76c12091520h and @richmondred01 for da hubs and @rmaynard for brake lining. Made a drill guide so I could spot drill a place for the 2nd set screw on axle and worked out great. I feel a little better with the xtra set screws since Im running loaded tires and wheel weights now :D.
  • Excellent 5
cleat
A lot of industrial equipment has the shaft countersunk like that.
Really helps hold things in a proper location.
ebinmaine
It definitely made a difference on my own 1974 C160-8 Cinnamon Horse.
I run it VERY heavy ALL the time and on rough ground.
Single set screws would loosen after a few weeks.
sqrlgtr
This is first set of hubs that I have ever had with 2 set screws besides the ones that came on the 2 520's I acquired a few months back. These hubs are a lot beefier than the older star type one set screw type, I figured the dimple would work better than trying to grind a flat on the axle. I got to thinking they needed a dimple or flat on axle for future disassembly. I will tell on myself though; I was so tickled with my hubs I forgot to put brake drum and band back on before driving around the barn :angry-banghead:. Funny as heck though when I went to stop and no brakes.:auto-swerve:.
Edited by sqrlgtr
  • Haha 5
  • Confused 1
953 nut
:angry-tappingfoot:                   We want the video of that, don't hold out on us.                :scared-eek:
  • Haha 3
Wayne0
Finally pulled the motor from Ole Rusty. Now in the process of swapping parts before re-installing the Craftsman transplant.
Edited by Wayne0
sqrlgtr
All I got was this pic
Squirrel no Memes - Imgflip
  • Haha 6
cleat
2 hours ago, Sparky said:
  Had the frame/supports/rails welded on my C-145 Auto today. The plan is to use it this winter for snow plowing. While it’s apart I’ll power wash it and get the trans fluid and filter swapped out.
  Then install the frame to transmission supports that I bought from @ri702bill .
  Looking forward to having hydraulic lift this winter!
I don't know if I have ever got a machine that wasn't at least cracked here.
If I was to say what the weak link is on these machines it is here.
Fortunately it does not cause any great harm as the machines run along just fine like this but like Sparky, I just can't leave it and get them welded up.
  • Like 6
mrc
not only welded but, reinforced is a good idea too.
cleat
At the very least, installing a nice thick fender washer underneath when bolting the front fender bracket into place should help spread the load and possibly stop it from cracking again.
Lee1977
 It's a design problem, metal too thin. add a 1/8" x 1 1/2" flat on top all the way under the shifter plate. Then fender washers under the original cracked area.
This one also got the fender raised 1 3/4".
  • Excellent 4
squonk
Set screw theme. I have one hub on Big Oly that likes to walk so new screws. Have to take one pie weight off to do it. At the same time I changed the oil to Rotella 15/40 and installed the snows. Winter's coming! :rolleyes:
  • Excellent 4
MainelyWheelhorse
Today after work I started on figuring out how to retrofit and spruce up the 520H Hydraulic lift to my C-141 Auto. I've got the beginnings of a plan to build a bracket for the valve block. Once i take the seat off, and the rear sheet metal. I'll figure out if I need custom hard lines to the pump or can adapt the existing lines as they look in good condition. It looks close but I'll know for sure once I can see the pump better and run the lines. I'm off the next two days so I'll pick away at it.
IMG_2248.jpeg.4b3a74da6dc0351ce2ea329341c9b5c3.jpegIMG_2249.jpeg.d8d2a2e4fb77a35429eb4e063ce401a7.jpegIMG_2250.jpeg.54cbd37d49dd2a5b7bde89cc05aa6e70.jpeg
  • Excellent 3
