Ed Kennell
What have you done to your Wheel Horse today?
ebinmaine
Got a little more done on @Natejc_98 's rig this evening.
Trina reinstalled the belt guard and right step.
I got the transmission drain plug cleaned out enough to righty tighty / lefty loosey repeat repeat repeat repeat  and dropped the nasty fluid. I've seen worse.
It'll do with a short hours repeated flush and new fluid again.
I also relocated the solenoid wire we were using for testing purposes. We had it laying around and over the gas tank. I got the harness loosened up enough to add it along side the factory taped up set and installed 3 terminals in it.
What's left.......?
Install hood.  Refill transmission and replace shifter boot and drain plug.
And.......????
  • Excellent 5
adsm08
I got started on patching the boy's deck tonight. Of course while I was grinding the welds down to inspect them the neighbor came over to complain that the compressor was too loud and it had "been loud for a really long time".
She is a stay at home mom who was trying to sit outside and read, which she can do at almost any time she wants. I work about 50 hours a week and get, maybe, 1.5 hours a day that I can actually work on these projects. Most days its closer to 45 minutes. I finished my grinding, filled in the one spot I found that I missed, and quit for the night because I was ready to be done anyway.
I'm hoping the next patch can be cut out with the plasma cutter because it will be much faster, and less air-intensive, and it's supposed to be HOT again tomorrow. The one I did tonight was too far from any edge and I don't have pincer clamps that would reach that far, so I had to use the grinder.
Edited by adsm08
EthanL
7 hours ago, ebinmaine said:
Yes please. Pics and measurements.
:handgestures-thumbupright:
Check it out
ebinmaine
7 minutes ago, EthanL said:
Check it out
Thanks for posting this.
What are the housings made of?
ebinmaine
47 minutes ago, adsm08 said:
neighbor
Ebinmaine.
✔️.   Does not play well with others.
:no:
EthanL
Hard plastic housing, lens are glass
adsm08
21 hours ago, ebinmaine said:
Ebinmaine.
:no:
I get it. Our neighborhood is a little closed in for my tastes, but it's what we could afford.
We usually get along with these neighbors pretty well, but when left to her own devices this woman is the kind of busy-body that got us things like the temperance movement.
ML3
So you have a neighborhood "Karen"
Few years ago we moved into town off of 14acres. It was a big change but due to my girlfriends health issues shes unable to drive so we needed to be where transportation is available for her Dr appts.
Fortunately, we have great neighbors.  My driveway is really close to house on right side.  Shes retired clerk of court for our town & really nice lady. Shes not outside much but has a 5yr old Pug that just doesn't shut up! I dont ever say anything or complain because shes never complained about me making noise in garage or driveway. She told me I dont need her permission to drive up thru her back yard to easily access my trailer. Shes 82yrs old & I know she wont be my neighbor forever......I try to be respectful of time of day etc. Nice to have thas sorta "understanding"
  • Heart 5
MainelyWheelhorse
My two neighbors are some of my literal family members so we get along great. And neither like myself, care if something gets moved in or around. An example being having temporary parking spot for a trailer etc… things are going great.
squonk
Those look like regular garden variety rubber work lamp size
Edited by squonk
Fj40z
1 hour ago, squonk said:
Final stage of the Big Show seat resto.
I keep resisting the urge to replace the Toro zero turn seat on my C160 because it’s so comfortable it every time a see an original one like this I absolutely love it! Looks fantastic!
8ntruck
I replaced the solid pipe on my grease gun nozzle today with a hose, allowing me to grease the other 2 spindles on my 42" SD deck.  It is ready to go back on the tractor.
However, I noticed that the grass is really dry and crunchy.  Won't be worth the effort to mow, as the only thing to cut is the taller weeds.
Got to sharpen the blades I took off and put them on the shelf, ready for the next time.
I also splurged and bought a 6 liter ultrasonic cleaner from Harbour  Freight.  I've got several carbs lined up for cleaning.
What are you guys out there who have ultrasonic cleaners using for cleaning fluid?  Lacquer thinner? Simple Green? Beaman's carb cleaner?  Do you run it hot or cold?
squonk
In all reality, the seat I took off is more comfortable. But it's getting torn up. I've had it over 20 years.
Fj40z
I did the same thing to my grease gun years ago and it made life so much easier. I actually put a 3 foot hose on mine which allows me to be able to hold the coupling end on the zerk and lay the gun on the ground and use it with the other hand. Works great. The down side is it takes almost a half of tube of grease to fill the hose LOL.
ebinmaine
  Lacquer thinner
Works good.
Fj40z
Found a NOS shifter decal on eBay to replace my old one. Most of it was worn off. Didn’t bother me much since I had learned the gear pattern but if the wife or kids use it they’ll be able to quickly see it.
ebinmaine
12 minutes ago, Fj40z said:
shifter decal
If ya ever want new ones @Vinylguy sells em.  :handgestures-thumbupright:
Ed Kennell
I use two 1/8" street ells as a universal joint on mine.     I can get on some pretty tight zerks and still have a rigid pipe that helps to push it on the zerk.
  • Like 4
MainelyWheelhorse
I took the 42” deck off the 312 because after mowing the fire station lawn. It  started to make horrendous noises. After some investigation, the slack adjuster was loose and the bolts holding in the spindles were too. I tightened them down with a wrench this time, but still may put some blue locktite on the spindle bolts, as a bit of added insurance. I also checked and filled the spindles to the top with grease. The grease was coming out the center spindle, so I know that was full. I was being a bit like @peter lena and making sure moving things were lubed up non moving were tightened down and things were good.🙂 I had to fix the 308’s rear left tire as well. it had sat and lost air breaking the bead. My 9 year old nephew decided to stop by then so he got a lesson on how to fix and reattach a tire. I got another set of hands. He was all for moving the 308 out of the workshop in first gear so I could clean out a bit and start to put things back. No pics as it was a busy day.
Chris689
Picked up the remnants of this 310-8 today. At some point in its life it was repowered with a 12HP kohler that is currently stuck. Transmission is free though which is great. Not sure what direction I’m going to go in with it since the engine is stuck and it’s missing a bunch of stuff like wheels and tires,  carb, fuel tank… the important stuff. A part of me kinda wants to piece it back together. We’ll see what’s happens.IMG_3050.jpeg.503bb0fe59e58ae7e5f59f66c80e157f.jpeg
Edited by Chris689
EB-80/8inPA
I got the B-80 reshorn after taking the wheels, tubes & tires to my friendly local tire shop.  I just wasn’t in the mood for doing that.  He got them to seal up without the tubes.
The blowout:
Spare set waiting for the Sandman
Scrubbed & ready to paint, more or less.IMG_9597.jpeg.df032d29f326494689353b547a5dc391.jpeg
Third coat left, fourth on right (Krylon Ivory)
Just like new! (Sort of)
Another triumph!
I’m almost inspired to give her a lick of Penetrol and do something about that seat.
Oh, and paint and remount the weights.
Edited by EB-80/8inPA
  • Like 4
  • Excellent 3
Blaine
I ordered a $10 regulator from EBay for the Raider. The mounting holes are too narrow to use the existing holes in the tower and i wanted to use the original holes and carriage bolts. The terminals on the new one stick out the back also, so it can’t be mounted flush.
 The band saw made quick work of making an adapter mount out of the old regulator.
  • Excellent 6
