Ed Kennell
What have you done to your Wheel Horse today?
ebinmaine
Got a little more done on @Natejc_98 's rig this evening.
Trina reinstalled the belt guard and right step.
I got the transmission drain plug cleaned out enough to righty tighty / lefty loosey repeat repeat repeat repeat  and dropped the nasty fluid. I've seen worse.
It'll do with a short hours repeated flush and new fluid again.
I also relocated the solenoid wire we were using for testing purposes. We had it laying around and over the gas tank. I got the harness loosened up enough to add it along side the factory taped up set and installed 3 terminals in it.
What's left.......?
Install hood.  Refill transmission and replace shifter boot and drain plug.
And.......????
  • Excellent 2
adsm08
I got started on patching the boy's deck tonight. Of course while I was grinding the welds down to inspect them the neighbor came over to complain that the compressor was too loud and it had "been loud for a really long time".
She is a stay at home mom who was trying to sit outside and read, which she can do at almost any time she wants. I work about 50 hours a week and get, maybe, 1.5 hours a day that I can actually work on these projects. Most days its closer to 45 minutes. I finished my grinding, filled in the one spot I found that I missed, and quit for the night because I was ready to be done anyway.
I'm hoping the next patch can be cut out with the plasma cutter because it will be much faster, and less air-intensive, and it's supposed to be HOT again tomorrow. The one I did tonight was too far from any edge and I don't have pincer clamps that would reach that far, so I had to use the grinder.
Edited by adsm08
EthanL
7 hours ago, ebinmaine said:
Yes please. Pics and measurements.
:handgestures-thumbupright:
Check it out
ebinmaine
7 minutes ago, EthanL said:
Check it out
Thanks for posting this.
What are the housings made of?
ebinmaine
47 minutes ago, adsm08 said:
neighbor
Ebinmaine.
✔️.   Does not play well with others.
:no:
EthanL
Hard plastic housing, lens are glass
adsm08
21 hours ago, ebinmaine said:
Ebinmaine.
:no:
I get it. Our neighborhood is a little closed in for my tastes, but it's what we could afford.
We usually get along with these neighbors pretty well, but when left to her own devices this woman is the kind of busy-body that got us things like the temperance movement.
