ebinmaine 79,550 #26451 Posted 3 hours ago Got a little more done on @Natejc_98 's rig this evening. Trina reinstalled the belt guard and right step. I got the transmission drain plug cleaned out enough to righty tighty / lefty loosey repeat repeat repeat repeat and dropped the nasty fluid. I've seen worse. It'll do with a short hours repeated flush and new fluid again. I also relocated the solenoid wire we were using for testing purposes. We had it laying around and over the gas tank. I got the harness loosened up enough to add it along side the factory taped up set and installed 3 terminals in it. What's left.......? Install hood. Refill transmission and replace shifter boot and drain plug. And.......???? 2 Share this post Link to post Share on other sites
adsm08 4,753 #26452 Posted 3 hours ago (edited) I got started on patching the boy's deck tonight. Of course while I was grinding the welds down to inspect them the neighbor came over to complain that the compressor was too loud and it had "been loud for a really long time". She is a stay at home mom who was trying to sit outside and read, which she can do at almost any time she wants. I work about 50 hours a week and get, maybe, 1.5 hours a day that I can actually work on these projects. Most days its closer to 45 minutes. I finished my grinding, filled in the one spot I found that I missed, and quit for the night because I was ready to be done anyway. I'm hoping the next patch can be cut out with the plasma cutter because it will be much faster, and less air-intensive, and it's supposed to be HOT again tomorrow. The one I did tonight was too far from any edge and I don't have pincer clamps that would reach that far, so I had to use the grinder. Edited 3 hours ago by adsm08 1 Share this post Link to post Share on other sites
EthanL 51 #26453 Posted 3 hours ago 7 hours ago, ebinmaine said: Yes please. Pics and measurements. Check it out 1 Share this post Link to post Share on other sites
ebinmaine 79,550 #26454 Posted 3 hours ago 7 minutes ago, EthanL said: Check it out Thanks for posting this. What are the housings made of? Share this post Link to post Share on other sites
ebinmaine 79,550 #26455 Posted 2 hours ago 47 minutes ago, adsm08 said: neighbor Ebinmaine. ✔️. Does not play well with others. Share this post Link to post Share on other sites
EthanL 51 #26456 Posted 2 hours ago 25 minutes ago, ebinmaine said: Thanks for posting this. What are the housings made of? Hard plastic housing, lens are glass Share this post Link to post Share on other sites
