Ed Kennell
What have you done to your Wheel Horse today?
MainelyWheelhorse
A hour working on a Cricuit and one more step done.
  • Like 6
ineedanother
Not wanting to do too much to this c-161 that is mostly original, I'm making an exception for solid shaker mounts. That last one seems to always be a challenge but I loosened one of the mounting blocks and was able to start that last bolt. This shored up the primary ground wire while I was at it so that's a plus.
  • Like 7
  • Excellent 2
ebinmaine
Good add.
Ground is paramount to proper DC circuits.
I do realize you want to keep originality.
Adding wires to create a full ground loop from engine block to frame to steering tower will save many future headaches.
ineedanother
This is a lot of work without a machine shop but I really needed to get these made before I install the ARK on the 161 (the old one on the bench is from the junk pile!).
  • Excellent 2
Lee1977
Those will stay with you, I have one set that I built in 1989 and they are still tight, don't see any ware.
Edited by Lee1977
  • Excellent 3
ineedanother
Also on the 161, there are some mixed reviews for this but I went ahead and installed some radial bearings on the spindles. Added 1/8" that I took off the top to allow access to the groove for the clip. In the process I'm reminded how much I dislike grease guns. Are any of them reliable for those of us that use them 3-4 times a year? B)
Blaine
 To answer your question, no. Lol
Here’s a must watch.
