squonk 47,133 #26326 Posted Tuesday at 09:08 PM 23 minutes ago, Sparky said: Old gear oil out, then a kerosene flush and drain…now the fresh stuff goes in. 1978 C-81 Something tells me you didn't spend the afternoon on a black roof in this heat! 2 2 Share this post Link to post Share on other sites
ebinmaine 79,359 #26327 Posted Tuesday at 09:34 PM Page number. 1054 !! 2 Share this post Link to post Share on other sites
Sparky-(Admin) 25,763 #26328 Posted Tuesday at 10:13 PM Was not a fan of these big goofy headlights on my 857, after two years of owning it I finally removed them. Much better looking! Too bad there’s a big ‘ol hole on both sides of the hood 4 Share this post Link to post Share on other sites
EthanL 17 #26329 Posted Tuesday at 10:23 PM 6 minutes ago, Sparky said: Was not a fan of these big goofy headlights on my 857, My tractor had the same round lights, they got old and burned out. Rather than replacing them I found new LEDs that looked very similar. Since this tractor is my work horse, the LEDs were a very functional upgrade. 4 3 Share this post Link to post Share on other sites
ebinmaine 79,359 #26330 Posted Tuesday at 10:27 PM 13 minutes ago, Sparky said: big goofy headlights If ya need a home for those.. I'd be interested. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 25,763 #26331 Posted Tuesday at 10:33 PM 9 minutes ago, EthanL said: My tractor had the same round lights, they got old and burned out. Rather than replacing them I found new LEDs that looked very similar. Since this tractor is my work horse, the LEDs were a very functional upgrade. And yes, if this was a worker I would have kept the headlights. But it’s pretty much just a show cruiser. Occasionally I’ll hook up a trailer and move firewood but never at night. 5 Share this post Link to post Share on other sites
Handy Don 16,816 #26332 Posted Tuesday at 10:44 PM 18 minutes ago, Sparky said: I'm sure you can find something to attach there that is more pleasing to look at, for example a side marker light or a simple reflector. You might consider, too, a reinforced filler covered by a decal from redoyourhorse--something custom, even, like your horse’s name. I do agree those lights look better in the parts bin than on the tractor! 1 1 Share this post Link to post Share on other sites
Handy Don 16,816 #26333 Posted Tuesday at 10:58 PM On 6/29/2026 at 6:05 AM, adsm08 said: In fact I may grab those ones and use them since that deck now has a broken cross shaft. I have found two potential “gotchas” on these decks when mixin’ & matchin’ apart from those driven by the 32 vs 36” sizes. In ’68, WH added shoulders on the bottoms of the cross-shaft bearing holders around the mounting bolt holes. I believe it was better for locking in cross shaft alignment. These then needed enlarged holes through the shell and into mating sockets in the cast iron bearing holder. In, I think, ’66 or ’68, the spindles were lengthened by ⅛” to accommodate a thrust bearing below the spindle gear--previously there was a simple thin thrust washer. Share this post Link to post Share on other sites
squonk 47,133 #26334 Posted Tuesday at 11:02 PM 48 minutes ago, Sparky said: Was not a fan of these big goofy headlights on my 857, after two years of owning it I finally removed them. Much better looking! Too bad there’s a big ‘ol hole on both sides of the hood Red Square stickers would cover them up! 2 Share this post Link to post Share on other sites
adsm08 4,710 #26335 Posted Tuesday at 11:31 PM 32 minutes ago, Handy Don said: WH added shoulders on the bottoms of the cross-shaft bearing holders I believe the ones on the 32 inch deck had them. I have not inspected the ones from the 36 we just took apart yet. Share this post Link to post Share on other sites
sqrlgtr 3,084 #26336 Posted Tuesday at 11:33 PM 1 hour ago, Sparky said: Too bad there’s a big ‘ol hole on both sides of the hood had a set of extra holes in my 1257 hood but added lights instead of removing 3 2 Share this post Link to post Share on other sites
ML3 2,354 #26337 Posted Tuesday at 11:46 PM 10 minutes ago, sqrlgtr said: had a set of extra holes in my 1257 hood but added lights instead of removing My free 702 already had holes w/no lights installed. Since its a functional tractor I installed led lamps. They definitely work great & at least I dont think they look too bad......It kinda ugly old tractor anyways! 🤣 3 1 Share this post Link to post Share on other sites
wfopete 39 #26338 Posted yesterday at 02:28 AM (edited) My "New to Me" D160 Kept pushing the dip stick out of the tube. I knew that wasn't right and did some digging about the Onan B43 in it. Took apart the breather reed valve assembly and was surprised that Lufkin made the reed; boy that reed was stiff too! You know what? Lufkin also made feeler gauges and this reed measured in at .0275". Me thinks bubba was at work here. My OEM replacement reed was a little more flexible at .0060". I think the reed problem is solved. Edited yesterday at 02:32 AM by wfopete 3 3 Share this post Link to post Share on other sites
CasaytheMann 169 #26339 Posted yesterday at 03:51 AM Pulled both mower blades and sharpened them. 2 1 Share this post Link to post Share on other sites
Lee1977 7,660 #26340 Posted 15 hours ago 16 hours ago, Sparky said: Was not a fan of these big goofy headlights on my 857, after two years of owning it I finally removed them. Much better looking! Too bad there’s a big ‘ol hole on both sides of the hood I had a couple hole drilled in my 312-8 when I got it. I pushed in a couple body panel plugs, mine were in the black so I didn't have to paint them. 5 Share this post Link to post Share on other sites
peter lena 9,921 #26341 Posted 15 hours ago @Lee1977 those body panel plugs make it easy , pete Share this post Link to post Share on other sites
RJR49 167 #26342 Posted 15 hours ago Installed a "go" pedal on my C-160 Auto. This is the 3rd, and I believe, the simplest, and most elegant of the three versions. Very easy to do. I'll create some drawings if anyone is interested. 2 3 Share this post Link to post Share on other sites
kdeatrick 158 #26343 Posted 12 hours ago Saturday after leaving the show, I pulled all the Work Horses out of the Horse Garage and clean the garage and them. I rebuilt the garage last fall 1 board at a time, only thing left original is the roof. I have another restored 1848 to bring over that will live here now also. Still 1 more GT1100 at home and 1 at the cabin. Plus a C175 disassembled and on pause of restoration. a bunch of decks for spares. I think the GT1600 shown here maybe next, I have the engine ready to reassemble after being bored. 6 Share this post Link to post Share on other sites
OutdoorEnvy 1,813 #26344 Posted 8 hours ago Haven't done much since snow plowing. But it was the time of year to mow and clean up the woods behind the yard. Had a downed tree to clean up as well so the chainsaw got in on the fun. It was hung up some so the 416 got some pulling fun too! 1 2 Share this post Link to post Share on other sites
Sparky-(Admin) 25,763 #26345 Posted 8 hours ago Picked up this two piece seat for cheap money at the WH Show. She’s ugly! Some gloss black rattle can and leather repair tape (lots of tape!) and she’s ready for service. Not show quality or anywhere close to it. But nothing so permanent that I couldn’t replace the seat back and seat cushion if I wanted in the future. 6 3 Share this post Link to post Share on other sites
wallfish 20,118 #26346 Posted 6 hours ago Much gooder! 3 Share this post Link to post Share on other sites
TonyToro 1,185 #26347 Posted 4 hours ago On 6/30/2026 at 5:34 PM, ebinmaine said: Page number. 1054 !! You beat me to it! I was going to say the same! 😆 Share this post Link to post Share on other sites
TonyToro 1,185 #26348 Posted 4 hours ago On 6/30/2026 at 6:13 PM, Sparky said: Was not a fan of these big goofy headlights on my 857, after two years of owning it I finally removed them. Much better looking! Too bad there’s a big ‘ol hole on both sides of the hood I would clean up the area and get a rubber grommet to fit that. I bet it would look almost factory. I just welded up a hood that had holes every where from hood ornament to lights. Share this post Link to post Share on other sites
