Ed Kennell
What have you done to your Wheel Horse today?
sqrlgtr
20 minutes ago, Handy Don said:
I took the opportunity to strip and repaint the wheels using the Cottage White (formerly Navajo White).
I used to use the Navajo white all the time and liked it better than most others but have since went to the Canvass white over red primer, which is just a tad bit "whiter" than Navajo. I have seen the Navajo back on the shelves lately though and may go back. I believe the Cottage white your using looks to be a close match to the Canvas but hard to tell in pics. BTW looks great and really like the rear hides....
  • Like 4
peter lena
@sqrlgtr  tractor supply has the flat  pulleys , as well as  no thread shank shoulder bolts ? so the flat  pulley can easily spin move , only placement I did was a very slight  push in in longest unsupported area , you can barely see the deflexion . flat washer  top and bottom of bolt mount , with  elastic Lok nut on top side of deck .  this set up will also  help settle down the spring slide tensioner . done a number of "  gold mine repair areas ? "  . pto lever set up , mule drive bearing  improvement .  lots of related to frequent failures , love those ?  dicect  intended function , and  verifi /  insure it , plow frame lever swing ease , to / from  swing quadrant lever ?  thats an awesome  gain , good talkin , pete
Fj40z
Did a little more mowing this evening, really enjoyed operating it for a hour or so. The Toro zero turn seat is turning out to be very comfortable, the thought of an original seat is mighty tempting though.
  • Like 5
  • Excellent 4
WHX??
Given the scarcity of original seats i never give fault for deviating from orginal. I do get a charge and draw the line at boat seats tho. :lol:
  • Haha 6
702854boy
16 hours ago, Ed Kennell said:
Pappy told me to always pull up on the crank...never push down.
Last year my grandpa taught me how to crank start a tractor and he said pretty much that same thing along with don't grip the handle with your thumb to prevent injury from kick back, just make a cup shape with all of your hand and pull up.
  • Like 5
C100guy94
Started putting the deck on for my first time. The one in backround has always been good to me and me and Buddy's have done lots of beating mudd bogging and cut a lot of land with it but she's just had it.
So time to utilize the c100 for the reason I bought it. To work it like a horse
  • Like 4
  • Excellent 4
SylvanLakeWH
@ebinmaine... Um...
:confusion-confused:
Er...
Forget one of "Colossus" proportions...??? :angry-tappingfoot:
  • Haha 5
ebinmaine
4 minutes ago, SylvanLakeWH said:
@ebinmaine... Um...
Er...
OH WOWWOWOWOWOW.  I can't believe I forgetted the big boy!!
Thanks Jim.  List edited.
  • Haha 2
ineedanother
Took the deck off of the c-165. I just don't need that large of a deck and need to get to work on installing the FEL before fall. Not too much to do since this is in really good shape but I have to get started on some steering upgrades.
  • Like 4
  • Excellent 2
Sparky
  Pulled the K-181 off my C-81 (snapped connecting rod) this evening. Once on the bench I drained the oil…not much there :ranting:
 That last pic shows how much came out.
  • Sad 8
8ntruck
I blew the leaves out of the black raspberry patch today.  Created enough of a mess on the lawn that it required Morgan, the 14-8, to pull the lawn sweeper around for a bit.  As long as he was out, I hooked the garden cart up to him and moved the new section of dock from winter storage to the front yard of the lake house.
Set the dock section on saw horses to slop a couple coats of stain on it before putting it in the lake.
As long as the tractor was hooked out and hooked up to the cart, I went over to the neighbor's house and picked up 2 snow blades of unknown vintage and origin.  He had a project planned for them, but it died - he was planning on scrapping them.  There are trip spring assemblies that I can adapt to the plow that came with Pack Rat, the AC B-110, and frames that look like a good starting point to build a belly blade for the Wheel Horse.
I got the first coat of stain on the top side of the new dock section after dinner.  New gallon of stain.  When I took the color tag from the gallon I got 3 years ago Menardsfor another gallon, the guy at the paint counter informed me that the same stain was NLA.  Seems VOC regulations have tightened, forcing oil base stain out of Menards inventory.  He apologized, then grumped a bit about how times are changing.  When asked if they still sell lacquer thinner, he replied 'not the good stuff".
Edited by 8ntruck
  • Like 4
702854boy
I used my 864 to pull my dad's 1257 that I forgot to check the oil level in and snapped the rod on, on a 6 by 12 trailer to the garage with more room to hopefully get the tractor out back together soon. I had the trailer balanced so that my tractor was just pulling and not dealing with the tongue weight and bouncing of everything.
Edited by 702854boy
  • Like 5
sqrlgtr
2 hours ago, Stan50 said:
I bought aftermarket wheels for RD deck, $7 a piece, and I installed zerks . Slightly narrower than original but color is right.
I'm looking to do the same, would love to have some of the original style that is sold by wheel horse parts and more, but the store-bought ones are a lot more $$$ friendly.
702854boy
A few weeks ago we were able to find some of those wheels at rural king, all we had to do was hit them with some red spray paint because they were bright white.
Stan50
@sqrlgtr I don't have much choice here in Poland, I had only 1 original (pretty new) and another one was worn out so  a few months earlier I temporarily put even cheaper wheel,but now that red one fits perfectly.
Edited by Stan50
  • Like 5
WHX??
What is the matter with you :occasion-clown::occasion-clown: ... the manual says before every use... heck there might even be pictures in the manual!  Gonna have to have a day of the week where everyone checks their oil ... like oil check Saturday and if there are no pics it didn't happen. Sure does seem to be a rash of snapped rods lately.
C100guy94
New to me plow.
Thanks again @pfrederi for holding it for me.
Just gotta figure out the mounting for lift. But I'm looking into it all will be good soon.
ebinmaine
How so?
Chain or solid link...
