Handy Don 17,461 #26176 Posted June 1 Over the past two weeks the 854 got new Firestone Town & Country rear tires. Very pricey but so far they are just what I was hoping for. I took the opportunity to strip and repaint the wheels using the Cottage White (formerly Navajo White). Mounting always leaves marks, so in anticipation of the Big Show, I even did the touchups. Looked so good I got out the can of Regal Red and touched up a bunch of the scratches and scrapes that a worker acquires over time. 4 17 Share this post Link to post Share on other sites
sqrlgtr 3,860 #26177 Posted June 1 20 minutes ago, Handy Don said: I took the opportunity to strip and repaint the wheels using the Cottage White (formerly Navajo White). I used to use the Navajo white all the time and liked it better than most others but have since went to the Canvass white over red primer, which is just a tad bit "whiter" than Navajo. I have seen the Navajo back on the shelves lately though and may go back. I believe the Cottage white your using looks to be a close match to the Canvas but hard to tell in pics. BTW looks great and really like the rear hides.... 5 Share this post Link to post Share on other sites
peter lena 10,047 #26178 Posted June 1 @sqrlgtr tractor supply has the flat pulleys , as well as no thread shank shoulder bolts ? so the flat pulley can easily spin move , only placement I did was a very slight push in in longest unsupported area , you can barely see the deflexion . flat washer top and bottom of bolt mount , with elastic Lok nut on top side of deck . this set up will also help settle down the spring slide tensioner . done a number of " gold mine repair areas ? " . pto lever set up , mule drive bearing improvement . lots of related to frequent failures , love those ? dicect intended function , and verifi / insure it , plow frame lever swing ease , to / from swing quadrant lever ? thats an awesome gain , good talkin , pete 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,535 #26179 Posted June 2 Did the first actual working of the 1257 today. Hooked the land plow up and plowed where I will be attempting to grow a 1000lb pumpkin. I couldn’t get as deep as I wanted since I found out really quick that I need a new belt. But ran great otherwise! 10 7 Share this post Link to post Share on other sites
AlexR 3,099 #26180 Posted June 2 Replaced the ammeter on my one tractor, the one I replaced was a new one but it was a 30 amp gauge which is a bit high for these tractors and the needle just went everywhere with the vibrations. This one works much better! 8 4 Share this post Link to post Share on other sites
Fj40z 239 #26181 Posted June 2 Did a little more mowing this evening, really enjoyed operating it for a hour or so. The Toro zero turn seat is turning out to be very comfortable, the thought of an original seat is mighty tempting though. 5 4 Share this post Link to post Share on other sites
WHX?? 58,053 #26182 Posted June 2 1 hour ago, Fj40z said: thought of an original seat is mighty tempting though. Given the scarcity of original seats i never give fault for deviating from orginal. I do get a charge and draw the line at boat seats tho. 1 6 Share this post Link to post Share on other sites
702854boy 1,139 #26183 Posted June 2 16 hours ago, Ed Kennell said: Pappy told me to always pull up on the crank...never push down. Last year my grandpa taught me how to crank start a tractor and he said pretty much that same thing along with don't grip the handle with your thumb to prevent injury from kick back, just make a cup shape with all of your hand and pull up. 5 1 Share this post Link to post Share on other sites
Bar Nuthin 3,157 #26184 Posted June 2 My neighbor finally broke out his slot hitch plow and busted through the pack layer - then followed up with the tiller. Here is my new (to me) C-160 Auto leveling things out. A little later, we decided to get the herds together for a group photo. You can tell they're all workers. 3 13 Share this post Link to post Share on other sites
C100guy94 126 #26185 Posted June 2 Started putting the deck on for my first time. The one in backround has always been good to me and me and Buddy's have done lots of beating mudd bogging and cut a lot of land with it but she's just had it. So time to utilize the c100 for the reason I bought it. To work it like a horse 5 4 Share this post Link to post Share on other sites
ebinmaine 80,600 #26186 Posted June 2 (edited) @MainelyWheelhorse brought up today... and someone else I don't recall just recently... That I MAY have a few tractors. A problem? An addiction? No no no of course not. So I commenced to countin'.. Running and usable: 1. 1974 "Cinnamon Horse" C160-8. 2. My own fully restored 1975 C160 Automatic. 3. "The Ugly Bruce" tractor. 1978/9 C121 Automatic. Projects: 4. 1974 C160-8 Tecumseh/ Briggs Vanguard swap tractor. 5. 1977 B80 8 speed that needs an engine repair or swap. 6. "Hollis" 1975 C160-8. So named for the town it came from. 7. Pile o' parts to build a complete new (520-8 based with C series sheet metal) chassis for the Wally Digger Backhoe. 8. COLOSSUS PROJECT. (Thanks @SylvanLakeWH) 9. Enough other parts to build at least one more 8 speed mid 70s C series. Maybe two??? So maybe 10......??? Oh man..... Edited June 2 by ebinmaine ADDED COLOSSUS!!!! 3 3 4 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,457 #26187 Posted June 2 @ebinmaine... Um... Er... Forget one of "Colossus" proportions...??? 5 Share this post Link to post Share on other sites
ebinmaine 80,600 #26188 Posted June 2 4 minutes ago, SylvanLakeWH said: @ebinmaine... Um... Er... Forget one of "Colossus" proportions...??? OH WOWWOWOWOWOW. I can't believe I forgetted the big boy!! Thanks Jim. List edited. 1 2 Share this post Link to post Share on other sites
ineedanother 2,861 #26189 Posted June 2 Took the deck off of the c-165. I just don't need that large of a deck and need to get to work on installing the FEL before fall. Not too much to do since this is in really good shape but I have to get started on some steering upgrades. 4 2 Share this post Link to post Share on other sites
Sparky-(Admin) 26,299 #26190 Posted June 3 Pulled the K-181 off my C-81 (snapped connecting rod) this evening. Once on the bench I drained the oil…not much there That last pic shows how much came out. 1 1 10 Share this post Link to post Share on other sites
8ntruck 9,278 #26191 Posted June 3 (edited) I blew the leaves out of the black raspberry patch today. Created enough of a mess on the lawn that it required Morgan, the 14-8, to pull the lawn sweeper around for a bit. As long as he was out, I hooked the garden cart up to him and moved the new section of dock from winter storage to the front yard of the lake house. Set the dock section on saw horses to slop a couple coats of stain on it before putting it in the lake. As long as the tractor was hooked out and hooked up to the cart, I went over to the neighbor's house and picked up 2 snow blades of unknown vintage and origin. He had a project planned for them, but it died - he was planning on scrapping them. There are trip spring assemblies that I can adapt to the plow that came with Pack Rat, the AC B-110, and frames that look like a good starting point to build a belly blade for the Wheel Horse. I got the first coat of stain on the top side of the new dock section after dinner. New gallon of stain. When I took the color tag from the gallon I got 3 years ago Menardsfor another gallon, the guy at the paint counter informed me that the same stain was NLA. Seems VOC regulations have tightened, forcing oil base stain out of Menards inventory. He apologized, then grumped a bit about how times are changing. When asked if they still sell lacquer thinner, he replied 'not the good stuff". Edited June 3 by 8ntruck 5 Share this post Link to post Share on other sites
MainelyWheelhorse 3,129 #26192 Posted June 3 (edited) Today, I pulled 2 of the 3 usable tractors the 312 and the C-141 out to get to my ATV with a winch to move my Snowmobile around. Frank, The C-141 definitely likes the more constant use even if it is just moving it out of the way. I haven't had a problem starting it for months. Yesterday, I put a new deck belt for the 37"SD on the 308. I got a few years out of the same old one, and it wouldn't keep tension without needing to extend the adjustment screw on the mule drive. Edited June 3 by MainelyWheelhorse 12 1 Share this post Link to post Share on other sites
702854boy 1,139 #26193 Posted June 3 (edited) I used my 864 to pull my dad's 1257 that I forgot to check the oil level in and snapped the rod on, on a 6 by 12 trailer to the garage with more room to hopefully get the tractor out back together soon. I had the trailer balanced so that my tractor was just pulling and not dealing with the tongue weight and bouncing of everything. Edited June 4 by 702854boy 7 1 Share this post Link to post Share on other sites
Stan50 218 #26194 Posted June 3 (edited) I bought aftermarket wheels for RD deck, $7 a piece, and I installed zerks . Slightly narrower than original but color is right. Edited June 3 by Stan50 10 3 Share this post Link to post Share on other sites
sqrlgtr 3,860 #26195 Posted June 3 2 hours ago, Stan50 said: I bought aftermarket wheels for RD deck, $7 a piece, and I installed zerks . Slightly narrower than original but color is right. I'm looking to do the same, would love to have some of the original style that is sold by wheel horse parts and more, but the store-bought ones are a lot more $$$ friendly. 1 Share this post Link to post Share on other sites
702854boy 1,139 #26196 Posted June 3 A few weeks ago we were able to find some of those wheels at rural king, all we had to do was hit them with some red spray paint because they were bright white. 3 Share this post Link to post Share on other sites
Stan50 218 #26197 Posted June 3 (edited) @sqrlgtr I don't have much choice here in Poland, I had only 1 original (pretty new) and another one was worn out so a few months earlier I temporarily put even cheaper wheel,but now that red one fits perfectly. Edited June 3 by Stan50 7 Share this post Link to post Share on other sites
WHX?? 58,053 #26198 Posted June 4 On 6/2/2026 at 7:39 PM, Sparky said: drained the oil…not much there On 6/2/2026 at 10:33 PM, 702854boy said: forgot to check the oil level What is the matter with you ... the manual says before every use... heck there might even be pictures in the manual! Gonna have to have a day of the week where everyone checks their oil ... like oil check Saturday and if there are no pics it didn't happen. Sure does seem to be a rash of snapped rods lately. 6 Share this post Link to post Share on other sites
C100guy94 126 #26199 Posted June 4 New to me plow. Thanks again @pfrederi for holding it for me. Just gotta figure out the mounting for lift. But I'm looking into it all will be good soon. 2 Share this post Link to post Share on other sites
ebinmaine 80,600 #26200 Posted June 4 1 minute ago, C100guy94 said: Just gotta figure out the mounting for lift How so? Chain or solid link... Share this post Link to post Share on other sites
