Ed Kennell
What have you done to your Wheel Horse today?
Ed Kennell
34 minutes ago, Fj40z said:
Any places to check online for the pulley covers?
Call Lincoln at A to Z tractor.     You can find his site in our vendor section.
ebinmaine
49 minutes ago, Fj40z said:
@pfrederi @DLF and @sqrlgtr thanks for the info! I’ll get the engine data when I get home from work.
@lynnmor I am going to definitely take your advice and find those pulley covers. Much appreciated!
What's the deck?
I have a couple covers here.
For Wheelhorse parts:
A#1... @76c12091520h Brian Badman. Excellent guy.
Or....
Place an ad in the Redsquare classifieds.
Also. CALL Lincoln at A to Z Tractor in PA.
Or..... Wheelhorsepartsandmore.
For OE replacement parts I've been having great success with
Billsplaceshop.com
lynnmor
Go to the Toro website using the model number of the deck, there you should be able to find the part number.  If the model number is missing from the deck, post a photo of it so we can identify.  Google the part number to see if you can find new or used covers.  Also, we have a classified section where you can post in the Wanted section.  We have a vendors section with folks that very well might have the covers.  The good thing about Wheel Horse is that so much is interchangeable and those covers were likely used on many models and years.
sqrlgtr
@Fj40z I would recommend becoming a supporter of the site makes it so much better of an experience and a lot easier to post pics. I 4 see more WH's in your future so you may as well join this support group :D.
It is well worth the price of admission in my opinion. So much help and knowledge on here.
CasaytheMann
I had my son-in-law make me some pully covers using his 3D printer.
DLF
I see you have a 42" side discharge deck.  They are bad to crack under the height adjuster then rust out.  My 1989 had a good size hole there when I got it
You need to check that, if not cracked add a 1/8" thick by 1 1/2" steel inside long enough to extend by both bolts.
Lee1977
Sparky
  C-105 Black Hood I purchased couple weeks ago..but the hood was all red :handgestures-thumbdown:
  Little amateur painting today to fix that.
  • Excellent 6
  • Heart 1
Sparky
Filnal paint used was this if anyone was curious.
SylvanLakeWH
Looks great @Sparky!!!
Tell your C-105 that her Michigan cousin says "Nice new coat! And Cheers"!!! :occasion-xmas:
Love the Black Hoods!!! :ph34r:
  • Excellent 2
sqrlgtr
Made me think of that ol song "take off the old coat and put on the new", that may not be correct title but is a great song either way....
HankB
  • Drained the engine oil on my 312-8.
  • I replaced a crappy aftermarket head gasket that blew out in about 1/2 hour of mowing.
  • Cleaned up the combustion chamber a bit.
  • Finished mowing the lawn.
I plan to change the gear oil too. I need to replace the fuel cap as well and so far my google-fu is not up to finding the correct replacement AFAIK. Oh, found it on the Toro site at https://www.toro.com/en/parts/partdetails?id=3418&iid=295761&pid=304458 "NOT AVAILABLE" but Amazon has the part number "55-3570 toro" listed for $18.20 US. At the Toro store no less! I should probably order a spare drive belt as well. Props to Toro for keeping some parts available but that is not as likely to last as long as my 314H.
Yesterday
  • Pulled the head to inspect. Mostly good, some evidence of blowby on the piston top.
  • Checked valve clearance - within spec.
  • Went through carb - likely the cause of poor performance and surging.
  • Replaced the air filter (and foam wrapper.)
It ran great! for half an hour whereupon it lost power and could not be restarted.
Chris689
Finally had the V61s mounted for the C120 and the AGs mounted for the 10-8
953 nut
eBay may your best bet. There is a pair listed for about $ 60.00 delivered.  You would probably do better by placing a free wanted ad on this site,   https://www.wheelhorseforum.com/classifieds/wanted/
Lots of members have a spare parts pile they would be glad to see go to someone who needs them. May find the flywheel cover that way too.
Ed Kennell
What did I do to my Wheel horse today this week.
I added a slot hitch so I could pull and lift the new tiller.
This required removing the weight rack and moving the support legs to the outside of the drawbar hitch to make room for the slot hitch.
IMG_20260505_101054659_BURST000_COVER_-_Copy.jpg.43baa4fdc8bedd587dd86d50a8281ae6.jpg
The seat and fender pan had to come off so this was a good time to clean the hydro and change oil and filter.    Nice surprise when I picked up the filter...NAPAs oil was on sale.
IMG_20260506_141355641_BURST000_COVER_-_Copy.jpg.ad88e4b01fad9c2d1d573b4b16f1bf1d.jpgIMG_20260506_074733839_BURST003.jpg.ce606ac9b1263ee6a18e4de67c5b7604.jpg
Also installed new fuel lines, e-pump, and filter rerouting everything outside the tunnel and ran it along the outside of the right frame rail.
  • Like 4
