kpinnc 17,290 #25501 Posted Tuesday at 02:32 PM 6 minutes ago, Handy Don said: Cleaning Yep, cleaning this time. Those white PVC fences change over to green here. Usually more in fall than other times it seems. But I also spray with the same setup with weed killer a little later. 1 Share this post Link to post Share on other sites
MainelyWheelhorse 2,342 #25502 Posted Wednesday at 12:43 AM Today, in this preview of spring/summer which was an uncommonly warm 70 degree day. I got the 308, 312 and C-141 out, wiped the dust off, and went for a short spin on the C-141. I also did some cleaning out, raking crushed rock out of the lawn, and organizing tractor parts. Now to wait for another week and a half roughly until spring is official. Tomorrow, it’s supposed to be rain and 30 degrees cooler. 2 3 Share this post Link to post Share on other sites
BrianKoch 355 #25503 Posted yesterday at 12:31 PM (edited) Gentlemen, Today I begin the process to repair my 42" side discharge mower deck for my '68 Charger 12 and could use some help from you all. The issue at hand is I cannot seem to keep the belt from slipping off the center pulley and I do not understand why. A few years back, I modified my Charger to run the deck from a mule drive and have ran the setup without a problem since. However, last season I needed to remove the center spindle assembly and chase the threads on it to better hold the blade retaining nut. Ever since that minor surgery, something is off and the belt slips every time. Based on my photo, does anyone see anything off with the geometry or anything else...(pic is of belt slipped off pulley for the umpteenth time). I'd like to try fixing before searching for another deck, but that's not off the table for me either if anyone has one. Thank you, Brian Edited yesterday at 12:54 PM by BrianKoch Share this post Link to post Share on other sites
953 nut 64,328 #25504 Posted yesterday at 12:46 PM 13 minutes ago, BrianKoch said: Based on my photo, Your photo wouldn't open for me. Post the photo itself rather than a link to it. 1 Share this post Link to post Share on other sites
Ed Kennell 45,036 #25505 Posted 21 hours ago Is the belt tensioner working properly? The near bolt seems to be at the end of the slot. Could that broken spot in the upper pulley be catching the belt and throwing it off? I've used broken pulleys but always rounded off any sharp edges so the bels don't catch. 1 Share this post Link to post Share on other sites
Lee1977 7,573 #25506 Posted 20 hours ago That rusty slide might be keeping the belt tightner from working proper., That type of deck should have plastic bushing on the bolts holding the slide. 1 Share this post Link to post Share on other sites
ineedanother 1,905 #25507 Posted 20 hours ago 7 hours ago, BrianKoch said: Gentlemen, Today I begin the process to repair my 42" side discharge mower deck for my '68 Charger 12 and could use some help from you all. The issue at hand is I cannot seem to keep the belt from slipping off the center pulley and I do not understand why. A few years back, I modified my Charger to run the deck from a mule drive and have ran the setup without a problem since. However, last season I needed to remove the center spindle assembly and chase the threads on it to better hold the blade retaining nut. Ever since that minor surgery, something is off and the belt slips every time. Based on my photo, does anyone see anything off with the geometry or anything else...(pic is of belt slipped off pulley for the umpteenth time). I'd like to try fixing before searching for another deck, but that's not off the table for me either if anyone has one. Thank you, Brian I would start by removing the belt and sliding the tensioner by hand to see if it slides smoothly and that the spring is applying even pressure. Then I would sight across the deck to make sure the idler pulley is on the same plan as the spindle pullies. If that all checks out and all of it turns freely, I would want to leave the guards off and watch it run to see if I could tell what the cause is. 1 Share this post Link to post Share on other sites
Lane Ranger 11,820 #25508 Posted 19 hours ago (edited) I think your problem is in the metal slide that rides back snd forth! I have had this problem before! The oblong holes in the metal slide bar become wallowed out! You need a new or better used bar. I bought mine new from Toro as i had a good deck i wanted to preserve. That was about 8 years ago and i am still using that 48 inch deck with no belt issues! Replace the nylon busing also if they are worn! The lower hole in your photo shows a knotch that is a worn spot ! Edited 19 hours ago by Lane Ranger 4 Share this post Link to post Share on other sites
WHX?? 55,237 #25509 Posted 3 hours ago FYI @BrianKoch most of those parts mentioned above that may be worn are available from K & B horse parts. 2 Share this post Link to post Share on other sites
