Ed Kennell
What have you done to your Wheel Horse today?
cafoose
3 hours ago, Ed Kennell said:
Yes, I'm sure the Ber Vac would have chewed right thru it.
Fer sure, I cut right thru hard Penn Dot snow banks along Rt 30 with that thing taking small chunks at a time but it got the job done :handgestures-thumbupright:
ML3
3 hours ago, WHX?? said:
You just working the snot outta that thing this winter ain't ya. :)
Seems like it. Just hasn't really quit snowing here since New Year's Day. Working all the little bugs outta it right quick. Turning out to be more reliable than I thought it would be.
  • Like 4
ML3
5 hours ago, c-series don said:
As I predicted, all this snow is due to the fact that @Ed Kennell sold his Ber Vac blower 🤣
I like that its Ed's fault for selling Bervac & not my fault for buying it!! 😆
  • Haha 7
  • Confused 1
Ed Kennell
 It sat in my barn unused for 5 years so  I sold it to you so it would get used.   Not my fault your tractor puked and you can't use it.
So let's blame this nasty weather on Mike.  :teasing-poke:
  • Haha 4
squonk
On 2/4/2026 at 10:39 PM, 702854boy said:
Did you get your shorts, tang top, and flip flops out?
  • Haha 4
  • Heart 1
SylvanLakeWH
:text-yeahthat: :scared-eek: :scared-eek: :scared-eek:
  • Haha 2
WHX??
From the we've seen it all files. Why on earth would someone cut this off? Of all the :wh: come thru here this one has been cobbled the most.
Fortunately most are easy to reverse but still. :soapbox:
  • Sad 4
Dan 312-8
16 hours ago, c-series don said:
One time I woke up and the driveway was plowed, I asked if she saw someone do it and she said no I did it with your truck I couldn’t wait any longer!!
Plows driveways, AND allows you to have as many tractors as you want, AND puts up with your shenanigans!:hilarious:
She's a keeper!:handgestures-thumbupright:
Stan50
New, cheap Chinese fuel pump installed, everything looks OK for now.
  • Like 5
WHX??
Good job Stan now flip a coin and hope for the best. My experience is 50/50 on them.
You might know this but when installing make sure the lever goes UNDER the cam lobe. Ask me how I know ... :hide:
It helps when installing to tip the lever down when inserting and "feel" it hit the cam lobe.
Stan50
Upss, I just put the pump carefully, tractor started right up and I did some chores  and some driving in the snow...
Stan50
Upss, I just put the pump , tractor started right up and I did some chores  and some driving in the snow...
I'm beginner so i didn't pay much attention to this, just did it with some care :confusion-scratchheadblue:
  • Excellent 2
Stan50
What could go wrong if pump would be installed improperly? No gas to carburator or something worse?
Handy Don
Cam tries to push pump arm farther than its range of motion.
I could see it ripping the diaphragm or bending the pump arm or breaking the pump arm pivot, though I’ve never experienced this personally.
WHX??
Yep and like Don said might wreck the pump.
TonyToro
We had the same issue and one was to short to make contact with the cam.
Both situations I just bent the arm gingerly until they worked. That’s the problem with the China stuff. Not exactly correct but we have the knowledge to get them to work..
Stan50
I just put it in with some resistance, Lever is pushed against camshaft? a bit  so tighten the screws is little bit tricky. There is no other way to put that pump in,I can't do it differently. The tractor works OK, no leaks and no sputtering.
I will watch it anyway. I don't have swift (1-2 days) access to parts so I hope that will last :D
Handy Don
If my memory is correct, there are two different arm configurations that I’ve seen.
On my K181, the arm on the metal-bodied pump that came with it rides under the camshaft.
On others (301 and up ?), maybe with the newer plastic body and u-channel arms, the arm rides atop the camshaft.
Edited by Handy Don
Stan50
My serial number shows 141xxxx so this is 1984 year engine and model year 1985. This is what  I could read off that K series owners manual
Model year 1985 and 312-8
Edited by Stan50
