lynnmor 8,394 #25276 Posted January 10 49 minutes ago, cleat said: Yes, just pump it a few times and you will see the fuel filter fill up then you can start the tractor. It should start quickly at this point. You can then remove it and install the regular fuel cap. And as a bonus, you only need one so long as all your tractors use the same fuel cap. I'm gonna order some cheap caps and squeeze bulbs from the jungle site and see if I can come up with a system that will stay on the tractor. I'm thinking the cheap bulbs might hold up for awhile since they won't have more than fumes inside. I keep the tractors in 3 or 4 locations so installing the systems on each should save me considerable walking over having just one. Of course I will need a filter and a mounting position that prevents water and dirt from entering, plus a quick disconnect for the air line. 2 Share this post Link to post Share on other sites
peter lena 9,646 #25277 Posted January 10 @lynnmor have had fuel check valves ,https://www.google.com/search?q=fuel+check+valve+5%2F16&rlz=1C1CHBF_enUS866US866&oq=&gs_lcrp=EgZjaHJvbWUqGwgAEAAYQhiRAhi0AhjqAhiABBiMB on all my engines , with a standing / clear line holding point close to carb , for years , there is no doubt of its holing ability , also make sure that your related , choke / cable runs , function without any fault , that choke , full plate hold , has to be enhancing piston draw , have also hydraulic oil , super lubed all my cables , no dry scraping noise , also added spring assist , a regular , tweaked horse set up for me , stay at it , pete 2 1 Share this post Link to post Share on other sites
WHX?? 53,869 #25278 Posted January 10 48 minutes ago, lynnmor said: some cheap caps and squeeze bulbs from the jungle site Keep us posted on what you come up with. This one's in the shop now for multiple hydraulic leaks. Maybe try and clean up some hose mess. I think it was @Handy Don was asking about hard lines once and at the time I thought he was nutz. He ain't lookin too crazy now. Also fuel delivery issues including either electric pump or your route. 3 1 1 1 Share this post Link to post Share on other sites
ML3 2,081 #25279 Posted January 10 Doing some mid season maint/inspection on the 702. Relocated exhaust because it was originally turned down towards the snowblower controls. Used whatever pipe/connectors I had. Didn't wanna drive out in the rain to get parts......all the cars are washed & clean in garage 😆 Also installed some rear wheel weights that I cant even remember where they came from. There's only 2 bolt holes in weights & of course only 1 hole lines up. They really fit well into the rim tightly so I think just the 1 bolt is enough because they they fit so good. 5 Share this post Link to post Share on other sites
pfrederi 19,509 #25280 Posted January 10 (edited) Got my latest C-160-8 to pop off today. Think she was auctioned off because starter motor was bad. Fixed some wiring issues replaced starter and she popped.. ( can't spray carb cleaner and film at the same time) This is the tractor with the unique K 431 engine. Edited January 10 by pfrederi 9 1 Share this post Link to post Share on other sites
pfrederi 19,509 #25281 Posted Monday at 08:11 PM Turns out fuel pump doesn't pump. Runs pretty well with gravity feed. Not sure what I want to do with her yet. Do not have any validated requirement for another C-160-8 1 2 Share this post Link to post Share on other sites
ebinmaine 76,600 #25282 Posted Monday at 09:41 PM 1 hour ago, pfrederi said: Do not have any validated requirement for another C-160-* Me either but there's over half a dozen of em here. 1 Share this post Link to post Share on other sites
Bill D 2,515 #25283 Posted Monday at 11:58 PM 2 hours ago, ebinmaine said: Me either but there's over half a dozen of em here. Ship one to @kpinnc. 1 1 2 Share this post Link to post Share on other sites
ebinmaine 76,600 #25284 Posted Tuesday at 12:24 AM 25 minutes ago, Bill D said: Ship one to @kpinnc. He'd be welcome. 1 1 Share this post Link to post Share on other sites
kpinnc 16,658 #25285 Posted Tuesday at 03:49 AM 3 hours ago, ebinmaine said: He'd be welcome. Aw, thank you both! 2 Share this post Link to post Share on other sites
sqrlgtr 1,820 #25286 Posted Thursday at 03:47 PM Actually done this yesterday but forgot to post it. Mounted new Deestones tri rib’s on 73 12hp-8 also new front wheel brgs., made up a short frame snow plow, put snow plow and bracket on 857. Took 1257 home and 857 to Moms and waited on snow that never came. 6 1 Share this post Link to post Share on other sites
Sparky-(Admin) 24,277 #25287 Posted 8 hours ago Wanted to clean the new to me C-145auto but the garage was 28 degrees and it was even colder outside. So just a scraping, shop-vac and rag cleaning today. Also installed a belt engage/disengage lever (completely missing!) 2 10 Share this post Link to post Share on other sites
cleat 8,423 #25288 Posted 5 hours ago 2 hours ago, Sparky said: Wanted to clean the new to me C-145auto but the garage was 28 degrees and it was even colder outside. So just a scraping, shop-vac and rag cleaning today. Also installed a belt engage/disengage lever (completely missing!) Good job. Looking great ! 3 1 Share this post Link to post Share on other sites
Clayton 29 #25289 Posted 3 hours ago Does buying one count? 5 Share this post Link to post Share on other sites
ebinmaine 76,600 #25290 Posted 2 hours ago 38 minutes ago, Clayton said: Does buying one count? Absolutely!! Share this post Link to post Share on other sites
