peter lena 9,594 #25176 Posted Monday at 08:50 PM @Dan 312-8 recently got a set of those straps , was skeptical of grip against chains , but have to say they are very good at the job , and without the asphalt scratching , somethin added was tractor supply welded rings at wheel centers for added extension springs , the recommended tight fitting , with a long thin flat screwdriver , made spring additions simple easy. btw like everything else , spring prices are nuts , bought a couple of long 3/8 x 12" + springs and made a few of my own. pete 2 Share this post Link to post Share on other sites
rjg854 12,684 #25177 Posted Monday at 09:56 PM 2 hours ago, Handy Don said: Finished the fuel pump job And just where are the pictures of this so called fuel pump job 1 3 Share this post Link to post Share on other sites
sqrlgtr 1,556 #25178 Posted Monday at 10:03 PM On 12/23/2025 at 7:02 PM, sqrlgtr said: Kinda disappointed in the then and now auto kit (missing gaskets) and the top cover gasket is not included in kit although is in picture Just wanted touch base and say then and now mailed me missing gaskets and got in mail today. I had already made some and put back together the fuel pump, but they did make it right. 3 Share this post Link to post Share on other sites
ebinmaine 76,120 #25179 Posted Monday at 10:12 PM 9 minutes ago, sqrlgtr said: Just wanted touch base and say then and now mailed me missing gaskets and got in mail today. I had already made some and put back together the fuel pump, but they did make it right. Good to know. 1 Share this post Link to post Share on other sites
Handy Don 15,376 #25180 Posted yesterday at 12:03 AM 2 hours ago, rjg854 said: And just where are the pictures of this so called fuel pump job Yikes! I was entertaining two grandchildren in the shop (i.e. keeping them from hurting themselves or breaking something) while I did the work and pictures were not on my mind. 3 1 1 Share this post Link to post Share on other sites
ebinmaine 76,120 #25181 Posted yesterday at 12:15 AM 11 minutes ago, Handy Don said: Yikes! I was entertaining two grandchildren in the shop (i.e. keeping them from hurting themselves or breaking something) while I did the work and pictures were not on my mind. Get the kids to do the phone thing. 📱 3 Share this post Link to post Share on other sites
Lane Ranger 11,687 #25182 Posted yesterday at 12:54 AM On 12/28/2025 at 4:59 PM, Handy Don said: Bad news. Good news. So-so news. Yesterday only a couple minutes after I started up the tractor to do some touch-up plowing, I saw something leaking from near the carb on the 854. I quickly parked it and shut the fuel petcock to await time for diagnostics. This afternoon I had a couple of free hours (company went sightseeing in NYC!) Bad news: Started it up easily and within a minute or so saw gas-laced oil dripping from the breather and the governor shaft. Fuel pump diaphragm was the suspect. Drained the crankcase and stashed the output for the hazardous chemical pickup day. (Also the dots connected: yesterday after the 1st session I had a little fuel on the bottom of the tank but when I went to top off before starting the second session, it was dry. Duh, it was dripping into the crankcase!) Removed the fuel pump and with output plugged could easily blow through the (definitely holed) diaphragm. Good news: Had a spare diaphragm and put it in after touching up flatness of the mating pump halves. Garage was 30º but with the heat gun I was able to gently warm the fuel lines to get them back onto the pump without damage. So-so news: Went to grab the 30w oil off the shelf and I only had 10W-30. Yeah, that’d be ok for the next cold months, but I’ll just as soon be patient for a day until I can get my preferred stuff. Don one winter on my old 854 after snowplow. I checked gas tank and it was a lot lower than when i filled 3/4 up. Started looking around and i felt under the two piece gas tank and found a leak. i bought this 854 from a guy i knew and i helped him fix the tank! So i kew we sealed good and i recalled we pit bigger sheet metal screws in the bottom with the new seal. i got real luck as only two or three loosened up. I placed in garage and warmed tractor up and retightened the screws. By some pure luck as i added no more permatex or other sealant it never leaked again! At least for the three or four more years i had it! I sold this one at the Big Show this year! 3 2 Share this post Link to post Share on other sites
Blue Chips 438 #25183 Posted yesterday at 03:16 AM (edited) The leads going to the cruise control electromagnet on my 522xi showed definite signs of having served as a meal or nesting material for a mouse or some small furry critter. All but one or two strands of the wire were chewed through: Not a difficult repair job. Cut/strip/crimp: First layer of heat-shrink tubing: Second layer of heat-shrink tubing: Wires fixed. I managed to clean and save most of the original outer jacket/loom: Electromagnet reinstalled: Rounded up the usual suspects, but had to let this one go for lack of evidence: Edited yesterday at 03:50 AM by Blue Chips 3 8 Share this post Link to post Share on other sites
Red Stallion 211 #25184 Posted 19 hours ago Tried to stayed optimistic... that's the outcome of today. 4 Share this post Link to post Share on other sites
Bill D 2,466 #25185 Posted 18 hours ago 1 hour ago, Red Stallion said: Tried to stayed optimistic... that's the outcome of today. Is there an automotive machine shop nearby? Oversized valve seats are available. The block can be welded and machined for a new valve seat. @lynnmor may have some ideas. If repair is not an option look for a good P216. They generally have less problems and you probably won't miss the 4 HP. 1 Share this post Link to post Share on other sites
Bar Nuthin 1,919 #25186 Posted 7 hours ago Rearranged my horses in the garage in order of likelihood of them seeing use. Mounted a set of tri-ribs for the C-141 and stole the front weights off the C-120 and put on it. Moved Johnny over to the cold side of the garage until I get some hydraulic lines for the lift. First time all 3 tractors have been up and going at the same time! 1 4 Share this post Link to post Share on other sites
sqrlgtr 1,556 #25187 Posted 6 hours ago (edited) 47 minutes ago, Bar Nuthin said: Rearranged my horses in the garage in order of likelihood of them seeing use. Mounted a set of tri-ribs for the C-141 and stole the front weights off the C-120 and put on it. Moved Johnny over to the cold side of the garage until I get some hydraulic lines for the lift. First time all 3 tractors have been up and going at the same time! Who is wearing the snow plow and what size is it, 48 or ? and has it got a plastic cutting edge? Inquiring minds want to know. Edited 6 hours ago by sqrlgtr Share this post Link to post Share on other sites
lynnmor 8,303 #25188 Posted 5 hours ago (edited) 14 hours ago, Red Stallion said: Tried to stayed optimistic... that's the outcome of today. OUCH! Remove the valve and seat then take some more photos. Maybe we can offer better advice. Often a good automotive machine shop can repair seats. This site did offer oversize seats. Edited 5 hours ago by lynnmor Share this post Link to post Share on other sites
953 nut 63,320 #25189 Posted 5 hours ago @sqrlgtr, please kill that bug on your posts, I have finger smudges all over my screen trying to kill it. 1 Share this post Link to post Share on other sites
Bar Nuthin 1,919 #25190 Posted 2 hours ago (edited) 3 hours ago, sqrlgtr said: Who is wearing the snow plow and what size is it, 48 or ? and has it got a plastic cutting edge? Inquiring minds want to know. The C-120 was my original choice for the 48" plow, but axle and hub failure mid-plowing got the plow moved over to the C-141. My original plan was to have the snow thrower on it for standby. But I didn't feel like swapping them out, so I just moved the front weights over. Maybe if it warms up, I'll make the switch. Or if I pick up hydraulic lines for the 16-Auto, I might move it there. Yes, that's 6" strip of HDPE plastic. Edited 2 hours ago by Bar Nuthin typo 1 Share this post Link to post Share on other sites
sqrlgtr 1,556 #25191 Posted 2 hours ago 31 minutes ago, Bar Nuthin said: Yes, that's 6" strip of HDPE plastic. @Bar NuthinI have been thinking about doing that to my plow, just in case i need to plow a concrete driveway. Where would be good source for sumin like that? Share this post Link to post Share on other sites
sqrlgtr 1,556 #25192 Posted 2 hours ago 2 hours ago, 953 nut said: @sqrlgtr, please kill that bug on your posts, I have finger smudges all over my screen trying to kill it. @953 nut my teenage niece put that on there and I just about wore my screen out trying to kill it also until I figured out it wasn't alive. Share this post Link to post Share on other sites
Bar Nuthin 1,919 #25193 Posted 26 minutes ago (edited) 2 hours ago, sqrlgtr said: Where would be good source for sumin like that? I'll have to dig into my memory bank and see if I can remember where I got it. Cut-to-Size Plastic | Polycarbonate, Plexiglass, HDPE | ShapesPlastics I stand corrected on the size. FREE shipping. Edited 15 minutes ago by Bar Nuthin Share this post Link to post Share on other sites
