peter lena 9,591 #25176 Posted 10 hours ago @Dan 312-8 recently got a set of those straps , was skeptical of grip against chains , but have to say they are very good at the job , and without the asphalt scratching , somethin added was tractor supply welded rings at wheel centers for added extension springs , the recommended tight fitting , with a long thin flat screwdriver , made spring additions simple easy. btw like everything else , spring prices are nuts , bought a couple of long 3/8 x 12" + springs and made a few of my own. pete 1 Share this post Link to post Share on other sites
rjg854 12,673 #25177 Posted 9 hours ago 2 hours ago, Handy Don said: Finished the fuel pump job And just where are the pictures of this so called fuel pump job 2 Share this post Link to post Share on other sites
rjg854 12,673 #25178 Posted 9 hours ago (edited) Double post Edited 8 hours ago by rjg854 Cor 1 Share this post Link to post Share on other sites
rjg854 12,673 #25179 Posted 9 hours ago (edited) Triple post Edited 8 hours ago by rjg854 Cor 2 Share this post Link to post Share on other sites
sqrlgtr 1,551 #25180 Posted 8 hours ago On 12/23/2025 at 7:02 PM, sqrlgtr said: Kinda disappointed in the then and now auto kit (missing gaskets) and the top cover gasket is not included in kit although is in picture Just wanted touch base and say then and now mailed me missing gaskets and got in mail today. I had already made some and put back together the fuel pump, but they did make it right. 3 Share this post Link to post Share on other sites
ebinmaine 76,080 #25181 Posted 8 hours ago 9 minutes ago, sqrlgtr said: Just wanted touch base and say then and now mailed me missing gaskets and got in mail today. I had already made some and put back together the fuel pump, but they did make it right. Good to know. 1 Share this post Link to post Share on other sites
Handy Don 15,367 #25182 Posted 6 hours ago 2 hours ago, rjg854 said: And just where are the pictures of this so called fuel pump job Yikes! I was entertaining two grandchildren in the shop (i.e. keeping them from hurting themselves or breaking something) while I did the work and pictures were not on my mind. 2 1 Share this post Link to post Share on other sites
ebinmaine 76,080 #25183 Posted 6 hours ago 11 minutes ago, Handy Don said: Yikes! I was entertaining two grandchildren in the shop (i.e. keeping them from hurting themselves or breaking something) while I did the work and pictures were not on my mind. Get the kids to do the phone thing. 📱 1 Share this post Link to post Share on other sites
Lane Ranger 11,683 #25184 Posted 6 hours ago On 12/28/2025 at 4:59 PM, Handy Don said: Bad news. Good news. So-so news. Yesterday only a couple minutes after I started up the tractor to do some touch-up plowing, I saw something leaking from near the carb on the 854. I quickly parked it and shut the fuel petcock to await time for diagnostics. This afternoon I had a couple of free hours (company went sightseeing in NYC!) Bad news: Started it up easily and within a minute or so saw gas-laced oil dripping from the breather and the governor shaft. Fuel pump diaphragm was the suspect. Drained the crankcase and stashed the output for the hazardous chemical pickup day. (Also the dots connected: yesterday after the 1st session I had a little fuel on the bottom of the tank but when I went to top off before starting the second session, it was dry. Duh, it was dripping into the crankcase!) Removed the fuel pump and with output plugged could easily blow through the (definitely holed) diaphragm. Good news: Had a spare diaphragm and put it in after touching up flatness of the mating pump halves. Garage was 30º but with the heat gun I was able to gently warm the fuel lines to get them back onto the pump without damage. So-so news: Went to grab the 30w oil off the shelf and I only had 10W-30. Yeah, that’d be ok for the next cold months, but I’ll just as soon be patient for a day until I can get my preferred stuff. Don one winter on my old 854 after snowplow. I checked gas tank and it was a lot lower than when i filled 3/4 up. Started looking around and i felt under the two piece gas tank and found a leak. i bought this 854 from a guy i knew and i helped him fix the tank! So i kew we sealed good and i recalled we pit bigger sheet metal screws in the bottom with the new seal. i got real luck as only two or three loosened up. I placed in garage and warmed tractor up and retightened the screws. By some pure luck as i added no more permatex or other sealant it never leaked again! At least for the three or four more years i had it! I sold this one at the Big Show this year! 1 Share this post Link to post Share on other sites
Blue Chips 429 #25185 Posted 3 hours ago (edited) The leads going to the cruise control electromagnet on my 522xi showed definite signs of having served as a meal or nesting material for a mouse or some small furry critter. All but one or two strands of the wire were chewed through: Not a difficult repair job. Cut/strip/crimp: First layer of heat-shrink tubing: Second layer of heat-shrink tubing: Wires fixed. I managed to clean and save most of the original outer jacket/loom: Electromagnet reinstalled: Rounded up the usual suspects, but had to let this one go for lack of evidence: Edited 3 hours ago by Blue Chips 1 1 Share this post Link to post Share on other sites
